查看: 2027|回復: 0
大家幫忙看一下這個程序怎么把gsm模塊去掉
ID:321415 發表于 2018-5-6 13:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include<intrins.h>
uint num;
uchar port;
sbit Hong_sen=P1^0;
sbit AD_eoc=P2^0;
sbit AD_clk=P2^1;
sbit AD_add=P2^2;
sbit AD_dat=P2^3;
sbit AD_cs=P2^4;
sbit buzzer=P2^5;
sbit led_alarm=P2^6;
sbit GSM_led=P2^7;
sbit DUAN=P1^6;
sbit WEI=P1^7;
uchar code          led7[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar sms_text1[] = "Warning: Gas Leakage !";
uchar sms_text2[] = "Warning: Illegal Intrusion !" ;
uchar  num1[] = "ATD15236265397;\r";
void SerialInti()
        TMOD=0x20;
        TH1=0xf3;
        TL1=0xf3;
        TR1=1;
        SM0=0;
        SM1=1;
        REN=1;
        IP=0x10;
        EA=1;
        ES=1;
        EX0=1;
   IT0=0;
void Serial_interrupt() interrupt 4
        RI=0;
void Uart1Send(uchar c)
        SBUF=c;
        while(!TI);
        TI=0;
void Uart1Sends(uchar *str)
        while(*str!='\0')
                SBUF=*str;
                while(!TI);
                TI=0;
                str++;
void Delay_S(uint sec)
        uint i , j= 0;
        for(i=0; i<sec; i++)
                for(j=0; j<65535; j++);
void SMS_Send()
        Uart1Sends("AT+CMGF=1\r");
        Delay_S(3);
        Uart1Sends("AT+CSCS=\"GSM\"\r");
        Delay_S(3);
        Uart1Sends("AT+CSMP=17,167,0,250\r");
//        Uart1Sends("AT+CSMP=17,167,0,240\r");
        Delay_S(3);
        Uart1Sends("AT+CMGS=\"15236265397\"\r");
        Delay_S(5);
        Uart1Sends(sms_text1);
        Uart1Send(0x1a);
        GSM_led=0;
        Delay_S(5);
void delay(uint z)
        uint k;
        for(z;z>0;z--)
            for(k=110;k>0;k--);
void display()
        uchar ge,shi,bai,qian;
        qian=num/1000;
        bai=num/100%10;
        shi=num%100/10;
        ge=num%100%10;
        P0=0;
        P0=led7[qian];
        DUAN=1;
        DUAN=0;
        P0=0Xf7;
        WEI=1;
        WEI=0;
        delay(5);
        P0=0x00;
        P0=led7[bai];
        DUAN=1;
        DUAN=0;
        P0=0Xfb;
        WEI=1;
        WEI=0;
        delay(5);
        P0=0x00;
        P0=led7[shi];
        DUAN=1;
        DUAN=0;
        P0=0Xfd;
        WEI=1;
        WEI=0;
        delay(5);
        P0=0x00;
        P0=led7[ge];
        DUAN=1;
        DUAN=0;
        P0=0Xfe;
        WEI=1;
        WEI=0;
        delay(5);
        P0=0x00;
uint ADC(uchar chn1)
        uchar i;
        uchar addr8,m;
    uint ADresult;
        AD_eoc=1;
        AD_cs=0;
        _nop_();
        addr8=chn1;
        addr8<<=4;
        for(i=0;i<4;i++)
                AD_add=(bit)(addr8&0x80);
                AD_clk=1;
                AD_clk=0;
                addr8<<=1;
    for(i=0;i<6;i++)
                AD_clk=1;
                AD_clk=0;
        AD_cs=1;
        while(!AD_eoc);
        _nop_();
        ADresult=0;
        AD_cs=0;
        for(i=0;i<10;i++)
                AD_clk=1;
                ADresult<<=1;
                m=AD_dat;
                ADresult+=m;
                AD_clk=0;
        AD_cs=1;
        return(ADresult);
        GSM_led=1;
        Hong_sen=1;
        SerialInti();
                port=0x00;
                num=ADC(port);
                display();
                if(num>200)
                        buzzer=0;
                        led_alarm=0;
                        Uart1Sends(num1);
                        GSM_led=0;
                        Delay_S(10);
                          Uart1Sends("ATH\r");
                        GSM_led=1;
                        Delay_S(3);
                        SMS_Send();
void ISR_Key(void) interrupt 0 using 1
        buzzer=0;
        led_alarm=0;
        Uart1Sends(num1);
        GSM_led=0;
        Delay_S(10);
        GSM_led=1;
        Delay_S(3);
        Delay_S(3);
        Delay_S(3);
        Delay_S(3);
        Delay_S(5);
        Uart1Sends(sms_text2);
        Uart1Send(0x1a);
        GSM_led=0;
        Delay_S(5);
程序.docx
12.87 KB, 下載次數: 3
