早幾年用了SHT10的溫濕度傳感器,穩(wěn)定,可靠,就是更新數(shù)據(jù)時(shí)間比較長些,
電路很簡單,請看手冊,
已經(jīng)在產(chǎn)品中使用了,請放心使用和指正,- #include <iom64v.h>
- #include <macros.h>
- #include <math.h>
- #include "sht.h"
- #include "uart.h"
- #include "key.h"
- #include "IO.h"
- #include "Lcd.h"
- enum {TEMP,HUMI};
- //0: 溫度1, 1:濕度1 , 2 : 溫度2, 3: 濕度2
- float todao[4]; //{temp,rh}; 模擬量寄存器從1到2
- float humi_val1; //濕度變量
- float temp_val1; //溫度變量
- unsigned int humi_val; //濕度變量
- unsigned int temp_val; //溫度變量
- unsigned char checksum;
- const float C1=-4; // for 12 Bit RH
- const float C2=+0.0405; // for 12 Bit RH
- const float C3=-0.0000028; // for 12 Bit RH
- const float T1=+0.01; // for 12 Bit RH
- const float T2=+0.00008; // for 12 Bit RH
- const float C1=-2.0468; // for 12 Bit RH
- const float C2=+0.0367; // for 12 Bit RH
- const float C3=-0.0000015955; // for 12 Bit RH
- extern unsigned char wendu1_biaozhi;
- extern unsigned char wendu2_biaozhi;
- extern unsigned char R_KeyValue1;
- ** 函數(shù)名稱: s_write_byte()
- ** 函數(shù)功能: SHT10寫單個(gè)字節(jié), 寫一個(gè)字節(jié)并輸出ACK驗(yàn)證
- ** 入口參數(shù): 寫入單個(gè)字節(jié)
- ** 出口參數(shù): ACK驗(yàn)證
- ** 說 明: writes a byte on the Sensibus and checks the acknowledge
- unsigned char s_write_byte(unsigned char value)
- unsigned char i,j,error1=0;
- SHT10_SDA1_OUT;
- for(i=0x80;i>0;i/=2) //shift bit for masking
- if (i & value)
- SHT10_SDA1_OUT1; //masking value with i , write to SENSI-BUS
- else
- SHT10_SDA1_OUT0;
- SHT10_SCK1_OUT1; //clk for SENSI-BUS
- for(j = 0; j<40;j++)
- NOP(); //pulswith approx. 5 us
- SHT10_SCK1_OUT0;
- NOP();
- NOP();
- NOP();
- SHT10_SDA1_OUT1; //release DATA-line
- NOP();
- SHT10_SCK1_OUT1; //clk #9 for ack
- NOP();
- SHT10_SDA1_IN;
- NOP();
- if(SHT10_SDA1) //check ack (DATA will be pulled down by SHT11)
- error1 = 1;
- else
- error1 = 0;
- SHT10_SCK1_OUT0;
- return error1; //error=1 in case of no acknowledge
- ** 函數(shù)名稱: s_read_byte()
- ** 函數(shù)功能: SHT10讀單個(gè)字節(jié),
- ** 入口參數(shù): ACK驗(yàn)證
- ** 出口參數(shù): 讀單個(gè)字節(jié)
- ** 說 明: reads a byte form the Sensibus and gives an acknowledge in case of "ack=1" 讀字節(jié)并給一個(gè)ACK
- unsigned char s_read_byte(unsigned char ack)
- unsigned char i,j,val=0;
- SHT10_SDA1_OUT;
- NOP();
- NOP();
- NOP();
- SHT10_SDA1_IN;
- NOP();
- if(SHT10_SDA1)
- val = (val | i); //read bit
- SHT10_SCK1_OUT0;
- SHT10_SDA1_OUT;
- NOP();
- NOP();
- if(!ack)
- SHT10_SDA1_OUT1; //in case of "ack==1" pull down DATA-Line
- else
- SHT10_SDA1_OUT0;
- SHT10_SCK1_OUT0;
- NOP();
- NOP();
- return val;
- ** 函數(shù)名稱: s_transstart()
- ** 函數(shù)功能: 啟動傳輸
- ** 入口參數(shù): 無
- ** 出口參數(shù): 無
- ** 說 明: generates a transmission start //啟動傳輸
- // _____ ________
- // DATA: |_______|
- // ___ ___
- // SCK : ___| |___| |______
- void s_transstart(void)
- SHT10_SDA1_OUT;
- NOP();
- NOP();
- SHT10_SDA1_OUT1;
- NOP();
- SHT10_SCK1_OUT0; //Initial state
- NOP();
- NOP();
- SHT10_SCK1_OUT1;
- NOP();
- SHT10_SDA1_OUT0;
- NOP();
- SHT10_SCK1_OUT0;
- NOP();
- NOP();
- NOP();
- SHT10_SCK1_OUT1;
- NOP();
- SHT10_SDA1_OUT1;
- NOP();
- SHT10_SCK1_OUT0;
- ** 函數(shù)名稱: s_connectionreset()
- ** 函數(shù)功能: 復(fù)位SHT10 //復(fù)位通訊時(shí)序
- ** 入口參數(shù): 無
- ** 出口參數(shù): 無
- // communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
- // _____________________________________________________ ________
- // _ _ _ _ _ _ _ _ _ ___ ___
- // SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
- void s_connectionreset(void)
- unsigned char i;
- SHT10_SDA1_OUT;
- NOP();
- NOP();
- SHT10_SDA1_OUT1;
- NOP();
- NOP();
- NOP();
- NOP();
- for(i=0;i<9;i++) //9 SCK cycles
- SHT10_SCK1_OUT1;
- NOP();
- NOP();
- SHT10_SCK1_OUT0
- NOP();
- NOP();
- s_transstart(); //transmission start
- ** 函數(shù)名稱: s_measure()
- ** 函數(shù)功能: SHT10測量溫度 或者濕度 ,帶校驗(yàn)
- ** 入口參數(shù): 讀出溫濕度值存入地址,校驗(yàn)值存入地址,測量模式
- ** 出口參數(shù): 測量出錯(cuò)次數(shù)
- ** 說 明: makes a measurement (humidity/temperature) with checksum 產(chǎn)生算法
- unsigned char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
- unsigned char error1=0;
- unsigned long i;
- switch(mode)
- { //send command to sensor
- case TEMP : error1+=s_write_byte(MEASURE_TEMP); break;
- case HUMI : error1+=s_write_byte(MEASURE_HUMI); break;
- default : break;
- SHT10_SDA1_IN;
- NOP();
- NOP();
- //delay_nms(150);
- for(i=0;i<90000;i++)
- if(SHT10_SDA1 == 0) //wait until sensor has finished the measurement
- break;
- if(SHT10_SDA1)
- error1 += 1; // or timeout (~2 sec.) is reached
- *(p_value+1 ) =s_read_byte(ACK); // read the first byte (MSB)
- *(p_value)=s_read_byte(ACK); // read the second byte (LSB)
- *p_checksum =s_read_byte(noACK); // read checksum
- return error1;
- ** 函數(shù)名稱: s_write_byte_1()
- unsigned char s_write_byte_1(unsigned char value)
- unsigned char i,error1=0;
- SHT10_SDA2_OUT;
- if (i & value)
- SHT10_SDA2_OUT1; //masking value with i , write to SENSI-BUS
- else
- SHT10_SDA2_OUT0;
- SHT10_SCK2_OUT1; //clk for SENSI-BUS
- NOP();
- NOP();
- SHT10_SCK2_OUT0;
- SHT10_SDA2_OUT1; //release DATA_1-line
- NOP();
- NOP();
- SHT10_SCK2_OUT1; //clk #9 for ack
- NOP();
- NOP();
- SHT10_SDA2_IN;
- NOP();
- NOP();
- if(SHT10_SDA2) //check ack (DATA_1 will be pulled down by SHT11)
- error1 = 1;
- else
- error1 = 0;
- SHT10_SCK2_OUT0;
- ** 函數(shù)名稱: s_read_byte_1()
- unsigned char s_read_byte_1(unsigned char ack)
- unsigned char i,val=0;
- SHT10_SDA2_OUT;
- NOP();
- NOP();
- SHT10_SDA2_IN;
- NOP();
- NOP();
- if(SHT10_SDA2)
- val=(val | i); //read bit
- SHT10_SCK2_OUT0;
- SHT10_SDA2_OUT;
- NOP();
- NOP();
- if(!ack)
- SHT10_SDA2_OUT1; //in case of "ack==1" pull down DATA_1-Line
- else
- SHT10_SDA2_OUT0;
- NOP();
- NOP();
- SHT10_SCK2_OUT0;
- NOP();
- return val;
- ** 函數(shù)名稱: s_transstart_1()
- ** 入口參數(shù): 無
- ** 出口參數(shù): 無
- // _____ ________
- // ___ ___
- void s_transstart_1(void)
- SHT10_SDA2_OUT;
- SHT10_SDA2_OUT1;
- NOP();
- SHT10_SCK2_OUT0; //Initial state
- NOP();
- NOP();
- SHT10_SCK2_OUT1;
- NOP();
- SHT10_SDA2_OUT0;
- NOP();
- SHT10_SCK2_OUT0;
- NOP();
- NOP();
- NOP();
- SHT10_SCK2_OUT1;
- NOP();
- SHT10_SDA2_OUT1;
- NOP();
- SHT10_SCK2_OUT0;
- ** 函數(shù)名稱: s_connectionreset_1()
- ** 函數(shù)功能: 復(fù)位SHT10 ,復(fù)位通訊時(shí)序
- ** 入口參數(shù): 無
- ** 出口參數(shù): 無
- void s_connectionreset_1(void)
- unsigned char i;
- SHT10_SDA2_OUT;
- NOP();
- NOP();
- SHT10_SDA2_OUT1;
- NOP();
- NOP();
- NOP();
- NOP();
- SHT10_SCK2_OUT1;
- NOP();
- SHT10_SCK2_OUT0;
- NOP();
- s_transstart_1(); //transmission start
- ** 函數(shù)名稱: s_measure_1()
- unsigned char s_measure_1(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
- unsigned long i;
- switch(mode)
- case TEMP : error1+=s_write_byte_1(MEASURE_TEMP); break;
- case HUMI : error1+=s_write_byte_1(MEASURE_HUMI); break;
- default : break;
- SHT10_SDA2_IN;
- NOP();
- NOP();
- //delay_nms(150);
- for (i=0;i<90000;i++)
- if(SHT10_SDA2==0)
- break; //wait until sensor has finished the measurement
- if(SHT10_SDA2)
- *(p_value+1) =s_read_byte_1(ACK); //read the first byte (MSB)
- *(p_value)=s_read_byte_1(ACK); //read the second byte (LSB)
- *p_checksum =s_read_byte_1(noACK); //read checksum
- return error1;
- ** 函數(shù)名稱: calc_sht10()
- ** 函數(shù)功能: 計(jì)算溫度和濕度
- ** 入口參數(shù): 讀出濕度值存入地址,讀出溫度值存入地址
- ** 出口參數(shù): 無
- ** 說 明: See an application note Non-linearity Compensation from www.Sensirion.com for details
- // calculates temperature [Deg Cel] and humidity [%RH]
- // input : humi [Ticks] (12 bit)
- // temp [Ticks] (14 bit)
- // output: humi [10x %RH] for 1 decimal place
- // temp [100x Deg Cel] for 2 decimal places
- void calc_sht10( float *p_humidity ,float *p_temperature)
- float rh = *p_humidity;
- float t = *p_temperature;
- float t_C;
- float rh_lin;
- t_C=t*0.01-40.1;
- //multiplied by 100, t_C=t-4000
- //t_C = t - 4000;
- //58<=rh<=1720, (1430*rh-5120*16)/4096, in x10
- //1721<=rh<=3273, (1110*rh+28930*16)/4096, in x10
- //From : Application Note Non-Linearity compensation, Sensirion
- if(rh<=1720)
- rh_lin = (1430UL*(long)rh)>>12;
- (rh_lin>=20)?(rh_lin = rh_lin-20):(rh_lin=0);
- else
- //rh_lin = (1110*rh + 12320 + 4096*110)/4096, in x10
- rh_lin = ((1110UL*(long)rh + 12320UL) >> 12) + 110;
- if(rh_lin>1000)
- rh_lin=1000;
- //rh_true = (t_C-25)*(rh*0.00008+0.01)+rh_lin
- //~0.12 %RH /deg C, this factor has been ignored at this moment
- *p_temperature = t_C;
- *p_humidity = rh_lin;
- ** 出口參數(shù): 無
- void calc_sht10(float *p_humidity ,float *p_temperature)
- float rh=*p_humidity; // rh: Humidity [Ticks] 12 Bit
- float t=*p_temperature; // t: Temperature [Ticks] 14 Bit
- float rh_lin; // rh_lin: Humidity linear
- float rh_true; // rh_true: Temperature compensated humidity
- float t_C; // t_C : Temperature [°C]
- t_C=t*0.01 - 40.1; // calc. temperature[°C]from 14 bit temp.ticks @5V
- rh_lin=C3*rh*rh + C2*rh + C1; // calc. humidity from ticks to [%RH]
- rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; // calc. temperature compensated humidity[%RH]
- if(rh_true>100)rh_true=100; // cut if the value is outside of
- if(rh_true<0.1)rh_true=0.1; // the physical possible range
- *p_temperature=t_C; // return temperature [°C]
- *p_humidity=rh_true; // return humidity[%RH]
- ** 函數(shù)名稱: calc_dewpoint()
- ** 函數(shù)功能: 計(jì)算露點(diǎn)
- ** 入口參數(shù): humidity [%RH], temperature [°C]
- ** 出口參數(shù): dew point [°C]
- float calc_dewpoint(float h,float t)
- float k,dew_point ;
- k = (log10(h)-2)/0.4343 + (17.62*t)/(243.12+t);
- dew_point = 243.12*k/(17.62-k);
- return dew_point;
- ** 函數(shù)名稱: Temp_Humi_Check()
- ** 函數(shù)功能: 溫度濕度檢測
- ** 入口參數(shù): 無
- ** 出口參數(shù): 無
- ** 說 明:
- void Temp_Humi_Check(void)
- unsigned char error=0;
- if(wendu1_biaozhi==1)
- error=0;
- s_connectionreset(); //傳送重置
- error += s_measure((unsigned char*) &humi_val,&checksum,HUMI); //measure humidity 濕度測量
- error += s_measure((unsigned char*) &temp_val,&checksum,TEMP); //measure temperature 溫度測量
- if(error!=0)
- s_connectionreset(); //in case of an error: connection reset
- todao[0]=0; //濕度測量 1
- todao[1]=0; //溫度測量 1
- else
- humi_val1=(float)humi_val; //converts integer to float
- temp_val1=(float)temp_val; //converts integer to float
- calc_sht10(&humi_val1,&temp_val1); //calculate humidity, temperature
- //calc_dewpoint(humi_val1,temp_val1);
- todao[0]=temp_val1; //溫度測量 1
- todao[1]=humi_val1; //濕度測量 1
- if(wendu2_biaozhi==1)
- error=0;
- s_connectionreset_1(); ////傳送重置
- error+=s_measure_1((unsigned char*) &humi_val,&checksum,HUMI); //measure humidity 濕度測量
- error+=s_measure_1((unsigned char*) &temp_val,&checksum,TEMP); //measure temperature 溫度測量
- if(error!=0)
- s_connectionreset_1(); //in case of an error: connection reset
- todao[2]=0; //濕度測量 2
- todao[3]=0; //溫度測量 2
- return;
- else
- todao[2]=temp_val1; //溫度測量 2
- todao[3]=humi_val1; //濕度測量 2
- ** 函數(shù)名稱: Temp_Humi_Init()
- ** 入口參數(shù): 無
- ** 出口參數(shù): 無
- ** 說 明: 檢測到溫度時(shí) ,置 標(biāo)志位
- void Temp_Humi_Init(void)
- //float Dew_Point;
- error+=s_measure((unsigned char*) &humi_val,&checksum,HUMI); //measure humidity 濕度測量
- error+=s_measure((unsigned char*) &temp_val,&checksum,TEMP); //measure temperature 溫度測量
- if(error!=0)
- else
- //Dew_Point=calc_dewpoint(humi_val1,temp_val1);
- todao[0]=temp_val1; //濕度測量 1
- todao[1]=humi_val1; //溫度測量 1
- error=0;
- s_connectionreset_1(); //傳送重置
- if(error!=0)
- todao[2]=0; //溫度測量 2
- todao[3]=0; //濕度測量 2
- else
- todao[2] = temp_val1; //溫度測量 2
- todao[3] = humi_val1; //濕度測量 2
- if(todao[1]==0)
- if( todao[0]==0)
- wendu1_biaozhi = 0;
- else // 有濕度時(shí)一定有溫度
- wendu1_biaozhi = 1;
- if(todao[3]==0)
- if( todao[2]==0)
- wendu2_biaozhi = 0;
- } // 有濕度時(shí)一定有溫度?
- else
- wendu2_biaozhi = 1;
