查看: 10174|回復: 2
基于51單片機智能小車尋跡程序
ID:322455 發表于 2018-5-4 22:46 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
uchar temp,signal,tt1,t0,t1,t2,t3,t4,t5,t6;
void delay_1ms(uint d)
    uint i;
    while(d--)
        for(i=0;i<75;i++);
void motor_run()           //電機起動
      P1=0x35;
    delay_1ms(200);
    P1=0x53;
    delay_1ms(10);
/*    ENA=1;
    OUT1=0;
    OUT2=1;
    delay_1ms(800);
    OUT2=0;
    delay_1ms(200);
    ENB=1;
    OUT4=0;
    OUT3=1;
    delay_1ms(800);
    OUT3=0;
    delay_1ms(200);
void motor_left()             //左進
    P1=0x30;
    delay_1ms(200);
    P1=0x00;
    delay_1ms(20);
void motor_right()           //右進
    P1=0x05;
    delay_1ms(200);
    P1=0x00;
    delay_1ms(20);
void motor_big_right()             //粗右進
    P1=0x55;
    delay_1ms(200);
    P1=0x00;
    delay_1ms(20);
void motor_big_left()
    P1=0x33;
    delay_1ms(200);
    P1=0x00;
    delay_1ms(20);
void motor_stop()                    //電機停止
     P1=0x00;
void motor_back()
    P1=0x53;
    t0=0;
    t1=0;
    t2=0;
    t3=0;
    t4=0;
    t5=0;
    t6=0;
    tt1=0;
    EA=1;
    ET1=1;
    TR1=1;
    TMOD=0x01;
    TH1=-(1000/256);
    TL1=-(1000%256);
         temp=P2;
        signal=temp&0xff;           //得到紅外反向信號
        switch(signal)
            case 0xff:       //無偏差
                motor_run();
                t0++;
                if(t0==10)
                    t0=0;
                    motor_left();
                    motor_right();
                t1=t2=t3=t4=t5=t6=0;
                break;
            case 0xfd:       //1輪右偏
                motor_big_left();
                t1++;
                if(t1==4)
                    t1=0;
                    motor_left();
                t0=t2=t3=t4=t5=t6=0;
                break;
            case 0xef:        //4輪左偏
                motor_big_right();
                t2++;
                if(t2==4)
                    t2=0;
                    motor_right();
                t0=t1=t3=t4=t5=t6=0;
                break;
            case 0xfb:     //2輪右偏出軌
            case 0xf9:       //1、2輪右偏
                 motor_big_left();
                t3++;
                if(t3==4)
                    t3=0;
                    motor_left();
                t0=t1=t2=t4=t5=t6=0;
//                delay_1ms(10);
                break;
            case 0xdf:       //5左偏出軌
            case 0xcf:      //4、5輪左偏
                 motor_big_right();
                t4++;
                if(t4==4)
                    t4=0;
                    motor_right();
                t0=t1=t2=t3=t5=t6=0;
//                delay_1ms(10);
                break;
            case 0xfe:       //0最右偏出軌
            case 0xfa:
                 motor_big_left();
                t5++;
                if(t5==1)
                    t5=0;
                    motor_left();
                    motor_left();
                t0=t1=t2=t3=t4=t6=0;
//                delay_1ms(10);
                break;
            case 0xbf:     //6最左偏出軌
             case 0x9f:
                motor_big_right();
                t6++;
                if(t6==1)
                    t6=0;
                    motor_right();
                    motor_right();
                t0=t1=t2=t3=t4=t5=0;
//                delay_1ms(10);
                break;
            case 0xeb:     //前兩傳感器壓在黑線上
            case 0xdb:     //后兩傳感器壓在黑線上
            case 0xbe:     //中間兩傳感器壓在黑線上
            case 0xac:         //前四傳感器壓在黑線上
            case 0x9a:        //后四傳感器壓在黑線上
                motor_back();
                delay_1ms(200);
                motor_stop();
//                delay_1ms(1000);
            default:
//                motor_back();
//                delay_1ms(50);
//                motor_left();
//                motor_right();
                break;
/*void time1() interrupt 3
    TH1=-(1000/256);
    TL1=-(1000%256);
    tt1++;
    if(tt1==300)
        motor_back();
    //    delay_1ms(1);
        tt1=0;
ID:873573 發表于 2021-1-8 13:11 | 顯示全部樓層
這個程序是什么意思uchar temp,signal,tt1,t0,t1,t2,t3,t4,t5,t6;
ID:873573 發表于 2021-1-8 13:12 | 顯示全部樓層
這個程序設計有六個輪子嗎
