查看: 4899|回復: 2
AT89S52單片機控制SIM800c發短信的源碼
ID:308386 發表于 2018-5-2 11:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include "UART.h"
#include "Delay.h"
#define Yes                1
#define No                0
sbit Power_key = P1 ^ 0;
/********??GSM????**********/
int test_boot;
/********??GSM??????**********/
int test_net_register;
/********GSM????????**********/
unsigned char GSM_receive[60];
/********GSM???????**********/
unsigned char GSMDATA_count;
void main(void)
        Power_key=0;
        test_boot=No;
        test_net_register=No;
        //GSM??
        Power_key=1;
        Delay_Ms(1000);
        Power_key=0;
        Uart_Init();
        while(test_boot==No)
                Send_String("AT\r\n");
                Delay_Ms(1000);
        while(test_net_register==No)
                Send_String("AT+COPS?\r\n");
                Delay_Ms(1000);
        Send_String("AT+CMGF=1\r\n");
        Delay_Ms(100);
        Send_String("AT+CSMP=17,167,2,25\r\n");//¶ìDÅÎı¾2Îêy
        Delay_Ms(100);
        Send_String("AT+CSCS=\"UCS2\"\r\n");
        Delay_Ms(100);
        Send_String("AT+CMGS=\"00310030003000380036\"\r\n");//·¢Ëí¶ìDÅ
        Delay_Ms(100);
        Send_String("8FD9662F4E0067616D4B8BD54FE1606F3002\r\n");
        Delay_Ms(100);
        Send_Char(0x1A);
        Delay_Ms(20000);
        //GSM??
        Power_key=1;
        Delay_Ms(1000);
        Power_key=0;
void uart(void) interrupt 4
        unsigned char UART_data;
        if(RI)
                UART_data=SBUF;
                if(UART_data=='\n')
                        if(GSM_receive[0]=='O'&&GSM_receive[1]=='K')
                                test_boot=Yes;
                                test_boot=No;
                        if(GSM_receive[12]=='C')
                                test_net_register=Yes;
                        GSMDATA_count=0;
                        GSM_receive[GSMDATA_count]=UART_data;
                        GSMDATA_count++;
        RI=0;
ID:338882 發表于 2019-3-19 19:39 | 只看該作者
第二個頭文件沒有啊
ID:264360 發表于 2019-5-10 10:50 | 只看該作者
如果來點注解那就最好不過了
