#include<reg52.h> //51單片機(jī)常用的頭文件
#define uchar unsigned char //宏定義一個(gè)無(wú)符號(hào)的char類型
#define uint unsigned int //宏定義一個(gè)無(wú)符號(hào)的int類型
//發(fā)送一字節(jié)
void sendByte(uchar b)
SBUF = b;
while(!TI);
TI=0;
//發(fā)送字符串
void sendString(uchar *s)
while(*s != '\0') //字符串默認(rèn)結(jié)尾'\0',以此來(lái)判斷字符串的結(jié)束
sendByte(*s);
s++;
//初始化ESP8266WiFi模塊
void initEsp()
uint a;
SCON = 0x50; //8位數(shù)據(jù),可變波特率
TMOD = 0x20; //設(shè)置定時(shí)器1位16位自動(dòng)重裝模式
TL1 = 0xfd; //設(shè)置定時(shí)器初值,波特率為9600
TH1 = 0xfd;
ET1 = 0; //禁止定時(shí)器1中斷
TR1 = 1; //啟動(dòng)定時(shí)器1
EA = 1;
for (a=0; a<50000; a++); //延時(shí)幾秒,讓模塊有時(shí)間啟動(dòng)
sendString("AT+CWMODE=2\n"); //設(shè)置為softAP和station共存模式
//WiFi熱點(diǎn)不能通過(guò)代碼設(shè)置,可使用串口助手進(jìn)行設(shè)置,該設(shè)置斷電不丟失
for (a=0; a<20000; a++);
sendString("AT+CWSAP='TEST','12345678',1,3\n"); //建立WiFi熱點(diǎn)
sendString("AT+CIPMUX=1\n"); //啟動(dòng)多連接
sendString("AT+CIPSERVER=1,333\n");//建立server,端口為333
sendString("AT+CIPSTO=50\n"); //服務(wù)器超時(shí)時(shí)間設(shè)置
RI=0;
ES=1; //初始化完成,串行口中斷打開
//獲取數(shù)據(jù),數(shù)據(jù)格式示例:+IPD,0,14:"time":"11:11"
void getData()
uint a;
if(receiveFlag)
for(i=0; i<2; i++)
Hour[i]=Buffer[17+i];
Hour[2]='\0';
for(i=0; i<2; i++)
Minute[i]=Buffer[20+i];
Minute[2]='\0';
//將獲取到的數(shù)據(jù)發(fā)送到串口助手上顯示
for (a=0; a<10000; a++); //需要延時(shí),負(fù)責(zé)會(huì)造成數(shù)據(jù)錯(cuò)亂導(dǎo)致丟包
sendString(Hour);
sendString(Minute);
receiveFlag=0;
count=0;
for(i=0; i<22; i++)
Buffer[i]=0;
//主函數(shù)
initEsp(); //初始化WiFi模塊
receiveFlag = 0; //receiveFlag判斷執(zhí)行g(shù)etData() 的標(biāo)志
count = 0; //count緩沖區(qū)RXDdata[count]的索引
getData();
//利用中斷接收信息,且舍棄無(wú)效信息
void uart() interrupt 4
if(RI == 1)
ES = 0; //關(guān)閉串行中斷
RI = 0; //清除串口接收標(biāo)志位
temp = SBUF; //從串口緩沖區(qū)取得數(shù)據(jù)
if(count<20) //滿足需接收的信息長(zhǎng)度,將數(shù)據(jù)存入緩沖區(qū)
Buffer[count]=temp;
count++;
if(Buffer[0]=='+') //判斷是否為無(wú)效數(shù)據(jù),由于WiFi模塊會(huì)自動(dòng)加上"+PID.."開頭的字符串
receiveFlag = 1;
receiveFlag = 0;
count = 0;
ES = 1;
