查看: 9651|回復: 0
使用51單片機蜂鳴器模仿電子琴的程序
ID:318620 發表于 2018-5-1 18:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
使用51單片機蜂鳴器模仿電子琴的程序,附件有程序文件
/* Copyright (c) 2005, 通信工程學院      */
/* All rights reserved.                  */
/* 作    者:戴 佳                                                 */
#ifndef        _MUSINSTRU_H                 // 防止MusInstru.h被重復引用
#define        _MUSINSTRU_H
#include <reg52.h>
#include <absacc.h>
#include <stdio.h>
#include <math.h>
/* 音符與計數值對應表 */
uint code tab[]={64021,64103,64260,64400,
                 64524,64580,64684,64777,
                 64820,64898,64968,65030,
                 65058,65110,65157,65178};
sbit P36 = P3^6;                // 此引腳輸出脈沖
uchar STH0;
uchar STL0;
#endif
REG52.H
Header file for generic 80C52 and 80C32 microcontroller.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
#ifndef __REG52_H__
#define __REG52_H__
/*  BYTE Registers  */
sfr P0    = 0x80;
sfr P1    = 0x90;
sfr P2    = 0xA0;
sfr P3    = 0xB0;
sfr PSW   = 0xD0;
sfr ACC   = 0xE0;
sfr B     = 0xF0;
sfr SP    = 0x81;
sfr DPL   = 0x82;
sfr DPH   = 0x83;
sfr PCON  = 0x87;
sfr TCON  = 0x88;
sfr TMOD  = 0x89;
sfr TL0   = 0x8A;
sfr TL1   = 0x8B;
sfr TH0   = 0x8C;
sfr TH1   = 0x8D;
sfr IE    = 0xA8;
sfr IP    = 0xB8;
sfr SCON  = 0x98;
sfr SBUF  = 0x99;
/*  8052 Extensions  */
sfr T2CON  = 0xC8;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2    = 0xCC;
sfr TH2    = 0xCD;
/*  BIT Registers  */
/*  PSW  */
sbit CY    = PSW^7;
sbit AC    = PSW^6;
sbit F0    = PSW^5;
sbit RS1   = PSW^4;
sbit RS0   = PSW^3;
sbit OV    = PSW^2;
sbit P     = PSW^0; //8052 only
/*  TCON  */
sbit TF1   = TCON^7;
sbit TR1   = TCON^6;
sbit TF0   = TCON^5;
sbit TR0   = TCON^4;
sbit IE1   = TCON^3;
sbit IT1   = TCON^2;
sbit IE0   = TCON^1;
sbit IT0   = TCON^0;
/*  IE  */
sbit EA    = IE^7;
sbit ET2   = IE^5; //8052 only
sbit ES    = IE^4;
sbit ET1   = IE^3;
sbit EX1   = IE^2;
sbit ET0   = IE^1;
sbit EX0   = IE^0;
/*  IP  */
sbit PT2   = IP^5;
sbit PS    = IP^4;
sbit PT1   = IP^3;
sbit PX1   = IP^2;
sbit PT0   = IP^1;
sbit PX0   = IP^0;
/*  P3  */
sbit RD    = P3^7;
sbit WR    = P3^6;
sbit T1    = P3^5;
sbit T0    = P3^4;
sbit INT1  = P3^3;
sbit INT0  = P3^2;
sbit TXD   = P3^1;
sbit RXD   = P3^0;
/*  SCON  */
sbit SM0   = SCON^7;
sbit SM1   = SCON^6;
sbit SM2   = SCON^5;
sbit REN   = SCON^4;
sbit TB8   = SCON^3;
sbit RB8   = SCON^2;
sbit TI    = SCON^1;
sbit RI    = SCON^0;
/*  P1  */
sbit T2EX  = P1^1; // 8052 only
sbit T2    = P1^0; // 8052 only
/*  T2CON  */
sbit TF2    = T2CON^7;
sbit EXF2   = T2CON^6;
sbit RCLK   = T2CON^5;
sbit TCLK   = T2CON^4;
sbit EXEN2  = T2CON^3;
sbit TR2    = T2CON^2;
sbit C_T2   = T2CON^1;
sbit CP_RL2 = T2CON^0;
#endif
ABSACC.H
Direct access to 8051, extended 8051 and Philips 80C51MX memory areas.
#ifndef __ABSACC_H__
#define __ABSACC_H__
#define CBYTE ((unsigned char volatile code  *) 0)
#define DBYTE ((unsigned char volatile data  *) 0)
#define PBYTE ((unsigned char volatile pdata *) 0)
#define XBYTE ((unsigned char volatile xdata *) 0)
#define CWORD ((unsigned int volatile code  *) 0)
#define DWORD ((unsigned int volatile data  *) 0)
#define PWORD ((unsigned int volatile pdata *) 0)
#define XWORD ((unsigned int volatile xdata *) 0)
#ifdef __CX51__
#define FVAR(object, addr)   (*((object volatile far *) (addr)))
#define FARRAY(object, base) ((object volatile far *) (base))
#define FCVAR(object, addr)   (*((object const far *) (addr)))
#define FCARRAY(object, base) ((object const far *) (base))
#else
#define FVAR(object, addr)    (*((object volatile far *) ((addr)+0x10000L)))
#define FCVAR(object, addr)   (*((object const far *) ((addr)+0x810000L)))
#define FARRAY(object, base)  ((object volatile far *) ((base)+0x10000L))
#define FCARRAY(object, base) ((object const far *) ((base)+0x810000L))
#endif
#endif
模擬電子琴.rar
21.04 KB, 下載次數: 31, 下載積分: 黑幣 -5
