查看: 1810|回復(fù): 0
8051F58x引腳圖與數(shù)據(jù)手冊資料下載
ID:285234 發(fā)表于 2018-5-1 09:49 | 顯示全部樓層 |閱讀模式
8051F58x數(shù)據(jù)手冊資料供大家參考
2.  Ordering Information
The following features are common to all devices in this family:
50 MHz system clock and 50 MIPS throughput (peak)
8448 bytes of RAM (256 internal bytes and 8192 XRAM bytes
SMBus/I
2C, Enhanced SPI, Two UARTs
Six Timers
12 Programmable Counter Array channels
12-bit, 200 ksps ADC
Internal 24 MHz oscillator
Internal Voltage Regulator
Internal Voltage Reference and Temperature Sensor
Three Analog Comparators
Table 2.1 shows the feature that differentiate the devices in this family.
8051F58x引腳圖:
完整的pdf格式文檔51黑下載地址:
C8051F586-IM_datasheet.eeworld.com.cn.pdf (2.35 MB, 下載次數(shù): 4)
