- #include<reg52.h>//
- #define uchar unsigned char//字符型宏定義
- #define uint unsigned int//整型宏定義
- #define shudu 3 //LED漸變速度調(diào)整
- uchar yin0 =31;//LED變化等級調(diào)整
- uchar yin1 =63;//LED變化等級調(diào)整
- uchar yin2 =95;//LED變化等級調(diào)整
- uchar yin3 =127;//LED變化等級調(diào)整
- uchar yin4 =159;//LED變化等級調(diào)整
- uchar yin5 =191;//LED變化等級調(diào)整
- uchar yin6 =223;//LED變化等級調(diào)整
- uchar yin7 =255;//LED變化等級調(diào)整
- sbit led0=P3^5;//16個IO口
- sbit led1=P3^6;
- sbit led2=P3^0;
- sbit led3=P3^1;
- sbit led4=P3^2;
- sbit led5=P3^3;
- sbit led6=P3^4;
- sbit led7=P3^7;
- sbit led8=P1^0;
- sbit led9=P1^1;
- sbit led10=P1^2;
- sbit led11=P1^7;
- sbit led12=P1^6;
- sbit led13=P1^5;
- sbit led14=P1^4;
- sbit led15=P1^3;
- uchar d0,d1,d2,d3,d4,d5,d6,d7,d8,d9,d10,d11,d12,d13,d14,d15;//各IO口變量
- /**********************延時子程序*******************/
- void delay(uint z)
- uint x,y;//局部變量定義
- for(x=0;x<5;x++)//延時外循環(huán)
- for(y=0;y<z;y++);//延時內(nèi)循環(huán)
- /**********PWM控制紅綠藍3種燈亮滅時間*********/
- void RGBpwm(uchar d0,uchar d1,uchar d2,uchar d3,uchar d4,uchar d5,uchar d6,uchar d7,uchar d8,uchar d9,uchar d10,uchar d11,uchar d12,uchar d13,uchar d14,uchar d15)//3個局部變量,且部分為帶參數(shù)函數(shù)
- if(d0!=0)
- led0=0;
- delay(d0);
- led0=1;//1
- if(d1!=0)
- led1=0;
- delay(d1);
- led1=1;//1
- if(d2!=0)
- led2=0;
- delay(d2); //2
- led2=1;
- if(d3!=0)
- led3=0;
- delay(d3);
- led3=1;//3
- if(d4!=0)
- led4=0;
- delay(d4);
- led4=1;//4
- if(d5!=0)
- led5=0;
- delay(d5);
- led5=1;//5
- if(d6!=0)
- led6=0;
- delay(d6);
- led6=1;//6
- if(d7!=0)
- led7=0;
- delay(d7);
- led7=1;//7
- if(d8!=0)
- led8=0;
- delay(d8);
- led8=1;//8
- if(d9!=0)
- led9=0;
- delay(d9);
- led9=1;//9
- if(d10!=0)
- led10=0;
- delay(d10); //10
- led10=1;
- if(d11!=0)
- led11=0;
- delay(d11);
- led11=1;//11
- if(d12!=0)
- led12=0;
- delay(d12);
- led12=1;//12
- if(d13!=0)
- led13=0;
- delay(d13); //13
- led13=1;
- if(d14!=0)//14
- led14=0;
- delay(d14);
- led14=1;
- if(d15!=0)//15
- led15=0;
- delay(d15);
- led15=1;
- /********************主程序*********************/
- void main()
- TMOD=0x01;
- EA=1;
- ET0=1;
- TR0=1;
- TH0=(65536-56)/256;
- TL0=(65536-56)%256;
- while(1)//程序主循環(huán)
- RGBpwm(d0,d1,d2,d3,d4,d5,d6,d7,d8,d9,d10,d11,d12,d13,d14,d15);//調(diào)用RGBpwm子程序
- /*中斷服務(wù)程序(控制LED紅綠藍亮滅時間占空比)*/
- void zhong() interrupt 1//中斷向量位為1
- uint num;//定時計數(shù)器變量
- uint ji;//亮度等級控制變量
- TH0=(65536-500)/256;//給定時器高8位賦值
- TL0=(65536-500)%256;//給定時器低8位賦值
- num++;//將定時器計數(shù)變量自動加1
- if(num==shudu)//如果速度變量等于定時計數(shù)變量就不執(zhí)行下面大括號語句
- num=0;//將計數(shù)器清0
- ji++;//將亮度等級控制變量加1 if((ji>0)&&(ji<10))//移位移動流水.....
- d0=yin7;
- d1=0;
- d2=0;
- d3=0;
- d4=0; d5=0;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>10)&&(ji<20))//23456789
- d0=yin6;
- d1=yin7;
- d2=0;
- d3=0;
- d4=0; d5=0;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>20)&&(ji<30))//345678910
- d0=yin5;
- d1=yin6;
- d2=yin7;
- d3=0;
- d4=0; d5=0;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- } if((ji>30)&&(ji<40))//4567891011
- d0=yin4;
- d1=yin5;
- d2=yin6;
- d3=yin7;
- d4=0;
- d5=0;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- } if((ji>40)&&(ji<50))//12345678
- d0=yin3;
- d1=yin4;
- d2=yin5;
- d3=yin6; d4=yin7;
- d5=0;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>50)&&(ji<60))//23456789
- d0=yin2;
- d1=yin3;
- d2=yin4;
- d3=yin5; d4=yin6;
- d5=yin7;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>60)&&(ji<70))//345678910
- d0=yin1;
- d1=yin2;
- d2=yin3;
- d3=yin4; d4=yin5;
- d5=yin6;
- d6=yin7;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- } if((ji>70)&&(ji<80))//4567891011
- d0=yin0;
- d1=yin1;
- d2=yin2;
- d3=yin3; d4=yin4;
- d5=yin5;
- d6=yin6;
- d7=yin7;
- d8=0;
- d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>80)&&(ji<90))//12345678
- d0=0;
- d1=yin0;
- d2=yin1;
- d3=yin2; d4=yin3;
- d5=yin4;
- d6=yin5;
- d7=yin6; d8=yin7;
- d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>90)&&(ji<100))//345678910
- d2=yin0;
- d3=yin1;
- d4=yin2;
- d5=yin3; d6=yin4;
- d7=yin5;
- d8=yin6;
- d9=yin7;
- d0=0;
- d1=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if((ji>100)&&(ji<110))//345678910
- d3=yin0;
- d4=yin1;
- d5=yin2;
- d6=yin3; d7=yin4;
- d8=yin5;
- d9=yin6;
- d10=yin7;
- d0=0;
- d1=0;
- d2=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- } if((ji>110)&&(ji<120))//4567891011
- d4=yin0;
- d5=yin1;
- d6=yin2;
- d7=yin3; d8=yin4;
- d9=yin5;
- d10=yin6;
- d11=yin7; d1=0;
- d2=0;
- d3=0;
- d12=0;
- d0=0;
- d13=0;
- d14=0;
- d15=0;
- } if((ji>120)&&(ji<130))//56789101112
- d5=yin0;
- d6=yin1;
- d7=yin2;
- d8=yin3; d9=yin4;
- d10=yin5;
- d11=yin6;
- d12=yin7;
- d0=0;
- d1=0;
- d2=0;
- d3=0;
- d4=0; d13=0;
- d14=0;
- d15=0;
- } if((ji>130)&&(ji<140))//678910111213
- d6=yin0;
- d7=yin1;
- d8=yin2;
- d9=yin3; d10=yin4;
- d11=yin5;
- d12=yin6;
- d13=yin7;
- d0=0;
- d1=0;
- d2=0;
- d3=0;
- d4=0; d5=0;
- d14=0;
- d15=0;
- } if((ji>140)&&(ji<150))//
- d7=yin0;
- d8=yin1;
- d9=yin2;
- d10=yin3; d11=yin4;
- d12=yin5;
- d13=yin6;
- d14=yin7;
- d0=0;
- d1=0;
- d2=0;
- d3=0;
- d4=0; d5=0;
- d6=0;
- d15=0;
- } if((ji>150)&&(ji<160))//
- d8=yin0;
- d9=yin1;
- d10=yin2;
- d11=yin3; d12=yin4;
- d13=yin5;
- d14=yin6;
- d15=yin7;
- d0=0;
- d1=0;
- d2=0;
- d3=0;
- d4=0; d5=0;
- d6=0;
- d7=0;
- } if((ji>160)&&(ji<450))//讓所有LED都滅掉 等待下一次流星......
- d0=0;
- d1=0;
- d2=0;
- d3=0;
- d4=0; d5=0;
- d6=0;
- d7=0;
- d8=0; d9=0;
- d10=0;
- d11=0;
- d12=0; d13=0;
- d14=0;
- d15=0;
- if(ji>450)
- TR0=0;
- ji=0;
- TR0=1;
流星雨.rar
(33.64 KB, 下載次數(shù): 17)
2018-4-30 17:14 上傳
下載積分: 黑幣 -5
