查看: 5791|回復(fù): 0
XTR110引腳圖與電路圖及pdf芯片資料下載
ID:319221 發(fā)表于 2018-4-30 09:19 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
DESCRIPTION
The XTR110 is a precision voltage-to-current converterdesigned for analog signal transmission. It accepts inputsof 0 to 5V or 0 to 10V and can be connected for outputs of4mA to 20mA, 0mA to 20mA, 5mA to 25mA, and many othercommonly used ranges.
A precision on-chip metal film resistor network provides inputscaling and current offsetting. An internal 10V voltage refer-ence can be used to drive external circuitry.The XTR110 is available in 16-pin plastic DIP, ceramic DIPand SOL-16 surface-mount packages. Commercial and in-dustrial temperature range models are available.
XTR110引腳圖:
XTR110功能框圖:
XTR110電路圖:
我現(xiàn)在想把XTR110芯片加入到multisim中去。。
完整的pdf格式文檔51黑下載地址:
xtr110.pdf (603.07 KB, 下載次數(shù): 12)
