查看: 1956|回復: 1
基于單片機的溫濕度控制 main程序是否正確 求幫助
ID:319018 發表于 2018-4-29 17:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include "dht11.h"
#include "1602.h"
#include "delay.h"
sbit SET=P1^0;
sbit INC=P1^1;
sbit DEC=P1^2;
sbit Buzzer = P2^0;
sbit KM_T = P3^7;
sbit KM_W = P3^5;
void keyset();
unsigned char TD=0;
unsigned int TH=30;
unsigned int TL=20;
unsigned int WL=25;
unsigned int WH=70;
extern unsigned char temp_value,humi_value;
extern        void disptem();
extern        void dispwet();
void timerinit()
TMOD=0x01;
TH0=-(10000/256);
TL0=-(10000%256);
EA=1;
ET0=1;
/*****???0????,????10ms****/
timer0() interrupt 1
TD++;
if(TD>=100)
{ TH0=-(10000/256);
   TL0=-(10000%256);
   TR0=0;
   TD=0;
   keyset();
   TH0=-(10000/256);
   TL0=-(10000%256);
void bell()
if((temp_value>TH)||(temp_value<TL))
   Buzzer = 0;
   Delayms(10);
   else  Buzzer = 1;
if((humi_value>WH)||(humi_value<WL))
   Buzzer = 0;
   Delayms(10);
   else  Buzzer = 1;
void FM_W()
if(humi_value < WL)
KM_W = 0;
if(humi_value > WH)
KM_W = 1;
void FM_T()
if(temp_value <TL)
KM_T = 0;
if(temp_value >TH)
KM_T = 1;
  Buzzer = 1;
  KM_T   = 1;
  KM_W   = 1;
  LCD_Init();            //?????
  Delayms(10);           //???????
  Lcd_Userchar();             //???????
  LCD_Wstring(0,0,"Tem:");
  LCD_Wchar(6,0,0x01);  //????????
  LCD_Wchar(7,0,'C');
  LCD_Wstring(9,0,"H30");
  LCD_Wstring(13,0,"L20");
  LCD_Wstring(0,1,"Wet:");
  LCD_Wstring(6,1,"%R");
  LCD_Wstring(9,1,"H70");
  LCD_Wstring(13,1,"L25");
  timerinit();
         Read_DHT11();
         disptem();
         dispwet();
         Delayms(500);
     TR0=1;
         bell();
         FM_W();
         FM_T();
void keyset()
   unsigned char setcount;
   if(SET==0)
           Delayms(10);
           while(SET==0);
           setcount++;
    switch(setcount)
         case 1:
             char displaynum_1[8];
                 INC=1;
                 DEC=1;
                 if((INC==0)&(TH<50))
                 TH++;
                 while(INC==0);
       else if((DEC==0)&(TH>TL))
                  TH--;
                  while(DEC==0);
     sprintf(displaynum_1,"%2i",TH);
     LCD_Wstring(10,0,displaynum_1);
         LCD_Wcom(0x80+11);
         LCD_Wcom(0x0f);
         }break;
         case 2:
          char displaynum_2[8];
          INC=1;
          DEC=1;
          if((INC==0)&(TL<TH))
            if(INC==0)
            TL++;
                while(INC==0);
          else if((DEC==0)&(TL>0))
           if(DEC==0)
           TL--;
           while(DEC==0);
        sprintf(displaynum_2,"%2i",TL);
    LCD_Wstring(14,0,displaynum_2);
    LCD_Wcom(0x80+15);
    LCD_Wcom(0x0f);
   break;
   case 3:
    char displaynum_3[8];
    INC=1;
        DEC=1;
        if((INC==0)&(WH<95))
            WH++;
                while(INC==0);
          else if((DEC==0)&(WH>WL))
           WH--;
           while(DEC==0);
        sprintf(displaynum_3,"%2i",WH);
    LCD_Wstring(10,1,displaynum_3);
        LCD_Wcom(0x80+0x40+11);
        LCD_Wcom(0x0f);
        break;
case 4:
    char displaynum_4[8];
    INC=1;
        DEC=1;
        if((INC==0)&(WL<WH))
            WL++;
                while(INC==0);
          else if((DEC==0)&(WL>0))
           WL--;
           while(DEC==0);
        sprintf(displaynum_4,"%2i",WL);
    LCD_Wstring(14,1,displaynum_4);
    LCD_Wcom(0x80+0x40+15);
        LCD_Wcom(0x0f);
        break;
   case 5:
    setcount=0;
        LCD_Wcom(0x0c);
   break;
   default :break;
ID:303383 發表于 2018-4-29 18:49 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
