#include "oled.h"
#include "stdlib.h"
#include "delay.h"
//¶¨òåASCII¿a
#include "Asc5x8.h" //ascii 8*16×Ö¿a
#include "Asc6x12.h" //ascii 8*16×Ö¿a
#include "Asc8x16.h" //ascii 8*16×Ö¿a
#include "Asc12x24.h" //ascii 12*24×Ö¿a
#include "Asc20x40.h" //ascii 20*40×Ö¿a
//×Ô¶¨òåoo×Ö¿a
#include "HZ12X12_S.h" //12*12ËÎìå×Ô¶¨òåoo×Ö¿a
#include "HZ16X16_S.h" //16*16ËÎìå×Ô¶¨òåoo×Ö¿a
#include "HZ24X24_S.h" //24*24ËÎìå×Ô¶¨òåoo×Ö¿a
// #include "HZ24X24_H.h" //24*24ËÎìå×Ô¶¨òåoo×Ö¿a
// #include "HZ24X24_K.h" //24*24ËÎìå×Ô¶¨òåoo×Ö¿a
//ÏòSSD1322D′èëò»¸ö×Ö½ú¡£
//dat:òaD′èëμÄêy¾Y/Ãüáî
//cmd:êy¾Y/Ãüáî±êÖ¾ 0,±íê¾Ãüáî;1,±íê¾êy¾Y;
void OLED_WR_Byte(u8 dat,u8 cmd,u8 cs)
u8 i;
if(cmd)
OLED_DC_Set();
OLED_DC_Clr();
if(cs==2)
OLED_CS2_Clr();
for(i=0;i<8;i++)
OLED_SCLK_Clr();
if(dat&0x80)
OLED_SDIN_Set();
OLED_SDIN_Clr();
OLED_SCLK_Set();
dat<<=1;
OLED_CS2_Set();
OLED_DC_Set();
if(cs==1)
OLED_CS1_Clr();
for(i=0;i<8;i++)
OLED_SCLK_Clr();
if(dat&0x80)
OLED_SDIN_Set();
OLED_SDIN_Clr();
OLED_SCLK_Set();
dat<<=1;
OLED_CS1_Set();
OLED_DC_Set();
//-----------------OLED¶Ë¿ú¶¨òå 4ÏßSPI----------------
/* 2éóÃIO¿úÄ£ÄaSPIí¨Ñ¶·½ê½Çy¶ˉoledÄ£¿é
CS1 ~ PE6
RES ~ PE5
DC ~ PE4
CLK ~ PE3
DIN ~ PE2
CS2 ~ PE1
//3õê¼»ˉSSD1322
void OLED_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); //ê1ÄüE¶Ë¿úê±Öó
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_4|GPIO_Pin_1; //PE4,PE6,PE1 CS1 DC CS2
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //íÆíìêä3ö
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//Ëù¶è50MHz
GPIO_Init(GPIOE, &GPIO_InitStructure); //3õê¼»ˉPE4,PE6
GPIO_SetBits(GPIOE,GPIO_Pin_6|GPIO_Pin_4|GPIO_Pin_1); //PE4,PE6,PE1êä3ö¸ß
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_5|GPIO_Pin_2; //PE2,PE3,PE5íÆíìêä3ö RES CLK DIN
GPIO_SetBits(GPIOE,GPIO_Pin_3|GPIO_Pin_5|GPIO_Pin_2); //PE2,PE3,PE5 êä3ö¸ß
OLED_RST_Set();
delay_ms(100);
OLED_RST_Clr();
delay_ms(100);
OLED_RST_Set();
//cs1 3õê¼»ˉ
OLED_WR_Byte(0xAE,OLED_CMD,CS1); // Display Off
OLED_WR_Byte(0xFD,OLED_CMD,CS1); // Set Command Lock
OLED_WR_Byte(0x12,OLED_DATA,CS1); //
OLED_WR_Byte(0xB3,OLED_CMD,CS1); // Set Clock as 80 Frames/Sec
OLED_WR_Byte(0x91,OLED_DATA,CS1); //
OLED_WR_Byte(0xCA,OLED_CMD,CS1); // Set Multiplex Ratio
OLED_WR_Byte(0x3F,OLED_DATA,CS1); // 1/64 Duty (0x0F~0x5F)
OLED_WR_Byte(0xA2,OLED_CMD,CS1); // Shift Mapping RAM Counter (0x00~0x3F)
OLED_WR_Byte(0x00,OLED_DATA,CS1); //
OLED_WR_Byte(0xA1,OLED_CMD,CS1); // Set Mapping RAM Display Start Line (0x00~0x7F)
OLED_WR_Byte(0xA0,OLED_CMD,CS1); //Set Column Address 0 Mapped to SEG0
OLED_WR_Byte(0x04,OLED_DATA,CS1); // Default => 0x40
// Horizontal Address Increment
// Column Address 0 Mapped to SEG0
// Disable Nibble Remap
// Scan from COM0 to COM[N-1]
// Disable COM Split Odd Even
OLED_WR_Byte(0x11,OLED_DATA,CS1); // Default => 0x01 (Disable Dual COM Mode)
OLED_WR_Byte(0xB5,OLED_CMD,CS1); // Disable GPIO Pins Input
OLED_WR_Byte(0xAB,OLED_CMD,CS1); // Enable Internal VDD Regulator
OLED_WR_Byte(0x01,OLED_DATA,CS1); //
OLED_WR_Byte(0xB4,OLED_CMD,CS1); // Display Enhancement
OLED_WR_Byte(0xA0,OLED_DATA,CS1); // Enable External VSL
OLED_WR_Byte(0xFD,OLED_DATA,CS1); // Enhance Low Gray Scale Display Quality
OLED_WR_Byte(0xC1,OLED_CMD,CS1); // Set Contrast Current
OLED_WR_Byte(0xEF,OLED_DATA,CS1); // Default => 0x7F
OLED_WR_Byte(0xC7,OLED_CMD,CS1); // Master Contrast Current Control
OLED_WR_Byte(Brightness,OLED_DATA,CS1); // Default => 0x0f (Maximum)
Set_Gray_Scale_Table(CS1); // Set Gray Scale Table
OLED_WR_Byte(0xB1,OLED_CMD,CS1); // Set Phase 1 as 5 Clocks & Phase 2 as 14 Clocks
OLED_WR_Byte(0xE2,OLED_DATA,CS1); // Default => 0x74 (7 Display Clocks [Phase 2] / 9 Display Clocks [Phase 1])
OLED_WR_Byte(0xD1,OLED_CMD,CS1); // Enhance Driving Scheme Capability (0x00/0x20)
OLED_WR_Byte(0xA2,OLED_DATA,CS1); // Normal
OLED_WR_Byte(0x20,OLED_DATA,CS1); //
OLED_WR_Byte(0xBB,OLED_CMD,CS1); // Set Pre-Charge Voltage Level as 0.60*VCC
OLED_WR_Byte(0x1F,OLED_DATA,CS1); //
OLED_WR_Byte(0xB6,OLED_CMD,CS1); // // Set Second Pre-Charge Period as 8 Clocks
OLED_WR_Byte(0x08,OLED_DATA,CS1); //
OLED_WR_Byte(0xBE,OLED_CMD,CS1); // Set Common Pins Deselect Voltage Level as 0.86*VCC
OLED_WR_Byte(0x07,OLED_DATA,CS1); // Default => 0x04 (0.80*VCC)
OLED_WR_Byte(0xA6,OLED_CMD,CS1); // Normal Display Mode (0x00/0x01/0x02/0x03)
// Default => 0xA4
// 0xA4 => Entire Display Off, All Pixels Turn Off
// 0xA5 => Entire Display On, All Pixels Turn On at GS Level 15
// 0xA6 => Normal Display
// 0xA7 => Inverse Display
OLED_WR_Byte(0xA9,OLED_CMD,CS1); // Disable Partial Display
//CS2 3õê¼»ˉ
OLED_WR_Byte(0xAE,OLED_CMD,CS2); // Display Off
OLED_WR_Byte(0xFD,OLED_CMD,CS2); // Set Command Lock
OLED_WR_Byte(0x12,OLED_DATA,CS2); //
OLED_WR_Byte(0xB3,OLED_CMD,CS2); // Set Clock as 80 Frames/Sec
OLED_WR_Byte(0x91,OLED_DATA,CS2); //
OLED_WR_Byte(0xCA,OLED_CMD,CS2); // Set Multiplex Ratio
OLED_WR_Byte(0x3F,OLED_DATA,CS2); // 1/64 Duty (0x0F~0x5F)
OLED_WR_Byte(0xA2,OLED_CMD,CS2); // Shift Mapping RAM Counter (0x00~0x3F)
OLED_WR_Byte(0x00,OLED_DATA,CS2); //
OLED_WR_Byte(0xA1,OLED_CMD,CS2); // Set Mapping RAM Display Start Line (0x00~0x7F)
OLED_WR_Byte(0xA0,OLED_CMD,CS2); //Set Column Address 0 Mapped to SEG0
OLED_WR_Byte(0x16,OLED_DATA,CS2); // Default => 0x40
OLED_WR_Byte(0x11,OLED_DATA,CS2); // Default => 0x01 (Disable Dual COM Mode)
OLED_WR_Byte(0xB5,OLED_CMD,CS2); // Disable GPIO Pins Input
OLED_WR_Byte(0xAB,OLED_CMD,CS2); // Enable Internal VDD Regulator
OLED_WR_Byte(0x01,OLED_DATA,CS2); //
OLED_WR_Byte(0xB4,OLED_CMD,CS2); // Display Enhancement
OLED_WR_Byte(0xA0,OLED_DATA,CS2); // Enable External VSL
OLED_WR_Byte(0xFD,OLED_DATA,CS2); // Enhance Low Gray Scale Display Quality
OLED_WR_Byte(0xC1,OLED_CMD,CS2); // Set Contrast Current
OLED_WR_Byte(0xEF,OLED_DATA,CS2); // Default => 0x7F
OLED_WR_Byte(0xC7,OLED_CMD,CS2); // Master Contrast Current Control
OLED_WR_Byte(Brightness,OLED_DATA,CS2); // Default => 0x0f (Maximum)
Set_Gray_Scale_Table(CS2); // Set Gray Scale Table
OLED_WR_Byte(0xB1,OLED_CMD,CS2); // Set Phase 1 as 5 Clocks & Phase 2 as 14 Clocks
OLED_WR_Byte(0xE2,OLED_DATA,CS2); // Default => 0x74 (7 Display Clocks [Phase 2] / 9 Display Clocks [Phase 1])
OLED_WR_Byte(0xD1,OLED_CMD,CS2); // Enhance Driving Scheme Capability (0x00/0x20)
OLED_WR_Byte(0xA2,OLED_DATA,CS2); // Normal
OLED_WR_Byte(0x20,OLED_DATA,CS2); //
OLED_WR_Byte(0xBB,OLED_CMD,CS2); // Set Pre-Charge Voltage Level as 0.60*VCC
OLED_WR_Byte(0x1F,OLED_DATA,CS2); //
OLED_WR_Byte(0xB6,OLED_CMD,CS2); // // Set Second Pre-Charge Period as 8 Clocks
OLED_WR_Byte(0x08,OLED_DATA,CS2); //
OLED_WR_Byte(0xBE,OLED_CMD,CS2); // Set Common Pins Deselect Voltage Level as 0.86*VCC
OLED_WR_Byte(0x07,OLED_DATA,CS2); // Default => 0x04 (0.80*VCC)
OLED_WR_Byte(0xA6,OLED_CMD,CS2); // Normal Display Mode (0x00/0x01/0x02/0x03)
// Default => 0xA4
OLED_WR_Byte(0xA9,OLED_CMD,CS2); // Disable Partial Display
Fill_RAM(0x00,CS1);
Fill_RAM(0x00,CS2);
OLED_WR_Byte(0xAF,OLED_CMD,CS2); // Display On
OLED_WR_Byte(0xAF,OLED_CMD,CS1); // Display On
void Set_Column_Address(unsigned char a, unsigned char b ,unsigned char cs)
OLED_WR_Byte(0x15,OLED_CMD,cs); // Set Column Address
OLED_WR_Byte(a,OLED_DATA,cs); // Default => 0x00
OLED_WR_Byte(b,OLED_DATA,cs); // Default => 0x77
void Set_Row_Address(unsigned char a, unsigned char b, unsigned char cs)
OLED_WR_Byte(0x75,OLED_CMD,cs); // Set Row Address
OLED_WR_Byte(b,OLED_DATA,cs); // Default => 0x7F
void Set_Write_RAM(unsigned char cs)
OLED_WR_Byte(0x5C,OLED_CMD,cs); // Enable MCU to Write into RAM
void Set_Read_RAM(unsigned char cs)
OLED_WR_Byte(0x5D,OLED_CMD,cs); // Enable MCU to Read from RAM
void Set_Remap_Format(unsigned char d ,unsigned char cs)
OLED_WR_Byte(0xA0,OLED_CMD,cs); // Set Re-Map / Dual COM Line Mode
OLED_WR_Byte(d,OLED_DATA,cs); // Default => 0x40
OLED_WR_Byte(0x11,OLED_DATA,cs); // Default => 0x01 (Disable Dual COM Mode)
void Set_Partial_Display(unsigned char a, unsigned char b, unsigned char c,unsigned char cs)
OLED_WR_Byte((0xA8|a),OLED_CMD,cs);
// Default => 0x8F
// Select Internal Booster at Display On
if(a == 0x00)
OLED_WR_Byte(c,OLED_DATA,cs);
void Set_Display_Offset(unsigned char d,unsigned char cs)
OLED_WR_Byte(0xA2,OLED_CMD,cs);
void Set_Start_Line(unsigned char d,unsigned char cs)
OLED_WR_Byte(0xA1,OLED_CMD,cs); // Set Vertical Scroll by RAM
void Set_Master_Current(unsigned char d,unsigned char cs)
OLED_WR_Byte(0xC7,OLED_CMD,cs); // Master Contrast Current Control
void Set_Linear_Gray_Scale_Table(unsigned char cs)
OLED_WR_Byte(0xB9,OLED_CMD,cs); // Set Default Linear Gray Scale Table
// Gray Scale Table Setting
void Set_Gray_Scale_Table(unsigned char cs)
OLED_WR_Byte(0xB8,OLED_CMD,cs); // // Set Gray Scale Table
OLED_WR_Byte(0x0C,OLED_DATA,cs); //
OLED_WR_Byte(0x18,OLED_DATA,cs); //
OLED_WR_Byte(0x24,OLED_DATA,cs); //
OLED_WR_Byte(0x30,OLED_DATA,cs); //
OLED_WR_Byte(0x3C,OLED_DATA,cs); //
OLED_WR_Byte(0x48,OLED_DATA,cs); //
OLED_WR_Byte(0x54,OLED_DATA,cs); //
OLED_WR_Byte(0x60,OLED_DATA,cs); //
OLED_WR_Byte(0x6C,OLED_DATA,cs); //
OLED_WR_Byte(0x78,OLED_DATA,cs); //
OLED_WR_Byte(0x84,OLED_DATA,cs); //
OLED_WR_Byte(0x90,OLED_DATA,cs); //
OLED_WR_Byte(0x9C,OLED_DATA,cs); //
OLED_WR_Byte(0xA8,OLED_DATA,cs); //
OLED_WR_Byte(0xB4,OLED_DATA,cs); //
OLED_WR_Byte(0x00,OLED_CMD,cs); // Enable Gray Scale Table
//ÇåÆáoˉêy,ÇåÆáoó,Õû¸öÆáÄ»êÇoúμÄ
// Show Regular Pattern (°ëÆáÇåÆá)
void Fill_RAM(unsigned char Data,unsigned char cs)
unsigned char i,j;
Set_Column_Address(0x00,0x77,cs);
Set_Row_Address(0x00,0x7F,cs);
Set_Write_RAM(cs);
for(i=0;i<128;i++)
for(j=0;j<120;j++)
OLED_WR_Byte(Data,OLED_DATA,cs);
// è«Æá»òÕß2¿·Öìî3䣬¸ù¾YDataÖ죨¼û»ò¶è±í£©ÏÔê¾£¬0x00ÎaÇåÆá£¬0xffÎa×îáá
// a: Column Address of Start
// b: Column Address of End (Total Columns Devided by 4)
// c: Row Address of Start
// d: Row Address of End
void Fill_Block(unsigned char Data, unsigned char a, unsigned char b, unsigned char c, unsigned char d )
unsigned char i,j;
if (d <= 63 ) //c<=d
Set_Column_Address(Shift+a,Shift+b,CS1);
Set_Row_Address(c,d,CS1);
Set_Write_RAM(CS1);
for(i=0;i<(d-c+1);i++)
for(j=0;j<(b-a+1);j++)
OLED_WR_Byte(Data,OLED_DATA,CS1);
if ( c<=63 ) // d>=64
Set_Row_Address(c,63,CS1);
Set_Write_RAM(CS1);
for(i=0;i<(63-c+1);i++)
Set_Column_Address(Shift+a,Shift+b,CS2);
Set_Row_Address(0,(d-63),CS2);
Set_Write_RAM(CS2);
for(i=0;i<(d-63+1);i++)
OLED_WR_Byte(Data,OLED_DATA,CS2);
else // ÖD¼äλÖÃ
Set_Row_Address((c-64),(d-64),CS2);
Set_Write_RAM(CS2);
// Show Gray Scale Bar (°ëÆá)
void Grayscale(unsigned char cs)
if(cs==1) //éϰëÆá
// Level 16 => Column 1~16
Fill_Block(0xFF,0x00,0x03,0x00,0x3F);
// Level 15 => Column 17~32
Fill_Block(0xEE,0x04,0x07,0x00,0x3F);
// Level 14 => Column 33~48
Fill_Block(0xDD,0x08,0x0B,0x00,0x3F);
// Level 13 => Column 49~64
Fill_Block(0xCC,0x0C,0x0F,0x00,0x3F);
// Level 12 => Column 65~80
Fill_Block(0xBB,0x10,0x13,0x00,0x3F);
// Level 11 => Column 81~96
Fill_Block(0xAA,0x14,0x17,0x00,0x3F);
// Level 10 => Column 97~112
Fill_Block(0x99,0x18,0x1B,0x00,0x3F);
// Level 9 => Column 113~128
Fill_Block(0x88,0x1C,0x1F,0x00,0x3F);
// Level 8 => Column 129~144
Fill_Block(0x77,0x20,0x23,0x00,0x3F);
// Level 7 => Column 145~160
Fill_Block(0x66,0x24,0x27,0x00,0x3F);
// Level 6 => Column 161~176
Fill_Block(0x55,0x28,0x2B,0x00,0x3F);
// Level 5 => Column 177~192
Fill_Block(0x44,0x2C,0x2F,0x00,0x3F);
// Level 4 => Column 193~208
Fill_Block(0x33,0x30,0x33,0x00,0x3F);
// Level 3 => Column 209~224
Fill_Block(0x22,0x34,0x37,0x00,0x3F);
// Level 2 => Column 225~240
Fill_Block(0x11,0x38,0x3B,0x00,0x3F);
// Level 1 => Column 241~256
Fill_Block(0x00,0x3C,Max_Column,0x00,0x3F);
if(cs==2) //ϰëÆá
Fill_Block(0xFF,0x00,0x03,0x40,0x7F);
Fill_Block(0xEE,0x04,0x07,0x40,0x7F);
Fill_Block(0xDD,0x08,0x0B,0x40,0x7F);
Fill_Block(0xCC,0x0C,0x0F,0x40,0x7F);
Fill_Block(0xBB,0x10,0x13,0x40,0x7F);
Fill_Block(0xAA,0x14,0x17,0x40,0x7F);
Fill_Block(0x99,0x18,0x1B,0x40,0x7F);
Fill_Block(0x88,0x1C,0x1F,0x40,0x7F);
Fill_Block(0x77,0x20,0x23,0x40,0x7F);
Fill_Block(0x66,0x24,0x27,0x40,0x7F);
Fill_Block(0x55,0x28,0x2B,0x40,0x7F);
Fill_Block(0x44,0x2C,0x2F,0x40,0x7F);
Fill_Block(0x33,0x30,0x33,0x40,0x7F);
Fill_Block(0x22,0x34,0x37,0x40,0x7F);
Fill_Block(0x11,0x38,0x3B,0x40,0x7F);
Fill_Block(0x00,0x3C,Max_Column,0x40,0x7F);
// Show Pattern (Partial or Full Screen)
// »ò¶èÄ£ê½ÏÂÏÔê¾ò»¸±í¼Æ¬
void Show_Pattern(unsigned char *Data_Pointer, unsigned char a, unsigned char b, unsigned char c, unsigned char d)
unsigned char *Src_Pointer;
unsigned char i,j;
//è¡Ä£ê±oòÏñËØÕyDò £¨2»Äü·′Dòóë2.72»í¬£©
Src_Pointer=Data_Pointer;
Set_Write_RAM(CS1);
OLED_WR_Byte(*Src_Pointer,OLED_DATA,CS1);
Src_Pointer++;
Src_Pointer++;
Set_Write_RAM(CS1);
Src_Pointer++;
Src_Pointer++;
Set_Write_RAM(CS2);
OLED_WR_Byte(*Src_Pointer,OLED_DATA,CS2);
Src_Pointer++;
Src_Pointer++;
else // ÔúÖD¼ä
Set_Row_Address((c-63),(d-63),CS2);
Set_Write_RAM(CS2);
Src_Pointer++;
Src_Pointer++;
êy¾Y×a»»3ìDò£o½«2λ·Ö3é1¸ö×Ö½ú′æèëÏÔ′棬óéóú1¸öseg±íê¾4¸öáDËùòÔòaí¬ê±D′2¸ö×Ö½ú¼′4¸öÏñËØ
uchar DATA£oè¡Ä£à′μÄ×ÖÄ£êy¾Y
void Con_4_byte(unsigned char DATA,unsigned char cs)
unsigned char d1_4byte[4],d2_4byte[4];
unsigned char i;
unsigned char d,k1,k2;
d=DATA;
for(i=0;i<2;i++) // ò»á½Î»μÄ·½ê½D′èë 2*4=8λ
k1=d&0xc0; //μ±i=0ê± ÎaD7,D6λ μ±i=1ê± ÎaD5,D4λ
/****óD4ÖÖ¿éÄü£¬16¼¶»ò¶è,ò»¸ö×Ö½úêy¾Y±íê¾á½¸öÏñËØ£¬ò»¸öÏñËØ¶Ôó|ò»¸ö×Ö½úμÄ4λ***/
switch(k1)
case 0x00:
d1_4byte=0x00;
break;
case 0x40: // 0100,0000
d1_4byte=0x0f;
break;
case 0x80: //1000,0000
d1_4byte=0xf0;
break;
case 0xc0: //1100,0000
d1_4byte=0xff;
break;
default:
break;
d=d<<2;
k2=d&0xc0; //μ±i=0ê± ÎaD7,D6λ μ±i=1ê± ÎaD5,D4λ
switch(k2)
case 0x00:
d2_4byte=0x00;
break;
d2_4byte=0x0f;
break;
d2_4byte=0xf0;
break;
d2_4byte=0xff;
break;
default:
break;
d=d<<2; //×óòÆá½Î»
OLED_WR_Byte(d1_4byte,OLED_DATA,cs); //D′ǰ2áD
OLED_WR_Byte(d2_4byte,OLED_DATA,cs); //D′oó2áD 12¼Æ4áD
/*======================oo×ÖÏÔê¾×óoˉêy¼ˉoÏ=====================================*/
// ÏÔê¾12*12μãÕóoo×Ö 2015-05¾§°Â2aêÔí¨1y
// è¡Ä£·½ê½Îa£ooáÏòè¡Ä£×ó¸ßλ,êy¾YÅÅáD:′ó×óμ½óò′óéÏμ½Ï 16áD 12DD
// num£ooo×ÖÔú×Ö¿aÖDμÄλÖÃ
// x: Start Column ¿aê¼áD ·¶Î§ 0~£¨256-16£©
// y: Start Row ¿aê¼DD 0~127-12
void HZ12_12( unsigned char x, unsigned char y, unsigned char num)
unsigned int j;
unsigned char x1;
x1=x/4;
if (y <=52) //63-11
Set_Column_Address(Shift+x1,Shift+x1+3,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£3Îa16/4-1
Set_Row_Address(y,y+11,CS1); //
Set_Write_RAM(CS1); // D′ÏÔ′æ
for(j=0;j<24;j++)
Con_4_byte(HZ12X12_S[num*24+j],CS1);
if (y >=64 )
Set_Column_Address(Shift+x1,Shift+x1+3,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£3Îa16/4-1
Set_Row_Address((y-63),(y-63+11),CS2); //
Set_Write_RAM(CS2); // D′ÏÔ′æ
for(j=0;j<24;j++)
Con_4_byte(HZ12X12_S[num*24+j],CS2);
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
Set_Row_Address(y,63,CS1); //
Set_Write_RAM(CS1); // D′CS1ÏÔ′æ
for(j=0;j<(64-y)*2;j++)
//×ÖÔúϰëÆá2¿·Ö
Set_Row_Address(0,(y+11-64),CS2); //
Set_Write_RAM(CS2); // D′CS2ÏÔ′æ
for(j=(64-y)*2;j<24;j++)
// D′èëò»′®12*12oo×Ö www.lcdsoc.com x×ø±êoí×Ö¼ä¾àdòaÎa4μı¶êy
// num1,num2£ooo×ÖÔú×Ö¿aÖDμÄλÖà ′ónum1ÏÔê¾μ½num2
// x: Start Column ¿aê¼áD ·¶Î§ 0~£¨255-16£©
// y: Start Row ¿aê¼DD 0~127-16
// d:×Ö¼ä¾ààë 0ÎaÎT¼ä¾à
void Show_HZ12_12(unsigned char x,unsigned char y, unsigned char d,unsigned char num1,unsigned char num2)
unsigned char i,d1;
d1=d+16;
for(i=num1;i<num2+1;i++)
if(x>(239-d)) {x=0;y=y+12;} //»»DD
HZ12_12(x,y,i);
x=x+d1;
// D′èëò»′®16*16oo×Ö www.lcdsoc.com
// x×ø±êoí×Ö¼ä¾àdòaÎa4μı¶êy
void Show_HZ16_16(unsigned char x,unsigned char y, unsigned char d,unsigned char num1,unsigned char num2)
unsigned char i,d1;
d1=d+16;
if(x>(239-d)) {x=0;y=y+16;} //»»DD
HZ16_16(x,y,i);
x=x+d1;
// ÏÔê¾16*16μãÕóoo×Ö 2015-05¾§°Â2aêÔí¨1y
// è¡Ä£·½ê½Îa£ooáÏòè¡Ä£×ó¸ßλ,êy¾YÅÅáD:′ó×óμ½óò′óéÏμ½Ï 16áD 16DD
void HZ16_16( unsigned char x, unsigned char y, unsigned char num)
unsigned int j;
unsigned char x1;
x1=x/4;
if (y <=48) //63-15
Set_Row_Address(y,y+15,CS1); //
for(j=0;j<32;j++)
Con_4_byte(HZ16X16_S[num*32+j],CS1);
if (y >=64 )
Set_Row_Address((y-63),(y-63+15),CS2); //
for(j=0;j<32;j++)
Con_4_byte(HZ16X16_S[num*32+j],CS2);
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
//×ÖÔúϰëÆá2¿·Ö
Set_Row_Address(0,(y+15-64),CS2); //
for(j=(64-y)*2;j<32;j++)
// ÏÔê¾24*24μãÕóoo×Ö 2015-05¾§°Â2aêÔí¨1y
// è¡Ä£·½ê½Îa£ooáÏòè¡Ä£×ó¸ßλ,êy¾YÅÅáD:′ó×óμ½óò′óéÏμ½Ï 24áD 24DD
// y: Start Row ¿aê¼DD 0~127-24
void HZ24_24( unsigned char x, unsigned char y, unsigned char num)
unsigned int j;
unsigned char x1;
x1=x/4;
if (y <=40) //63-23
Set_Column_Address(Shift+x1,Shift+x1+5,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£5Îa24/4-1
Set_Row_Address(y,y+23,CS1); //
Set_Write_RAM(CS1); // D′ÏÔ′æCS1
for(j=0;j<72;j++)
Con_4_byte(HZ24X24_S[num*72+j],CS1); //ËÎìå24*24 ¡¤¡¤¡¤¡¤èçDèòa¿¬ìå24*24£¨HZ24X24_K.h£© ,oúìå24*24£¨HZ24X24_H.h£©°üo¬Ïàó|μÄí·Îļt2¢DT¸Ä′Ë′|êy×éÃû
if (y >=64 )
Set_Column_Address(Shift+x1,Shift+x1+5,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£5Îa24/4-1
Set_Row_Address((y-63),(y-63+23),CS2); //
Set_Write_RAM(CS2); // D′ÏÔ′æCS2
for(j=0;j<72;j++)
Con_4_byte(HZ24X24_S[num*72+j],CS2); //ËÎìå24*24 ¡¤¡¤¡¤¡¤èçDèòa¿¬ìå24*24£¨HZ24X24_K.h£© ,oúìå24*24£¨HZ24X24_H.h£©°üo¬Ïàó|μÄí·Îļt2¢DT¸Ä′Ë′|êy×éÃû
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
for(j=0;j<(64-y)*3;j++)
//×ÖÔúϰëÆá2¿·Ö
Set_Row_Address(0,(y+23-64),CS2); //
for(j=(64-y)*3;j<72;j++)
// D′èëò»′®24*24oo×Ö www.lcdsoc.com
void Show_HZ24_24(unsigned char x,unsigned char y, unsigned char d,unsigned char num1,unsigned char num2)
unsigned char i,d1;
d1=d+24;
if(x>(231-d)) {x=0;y=y+24;} //»»DD
HZ24_24(x,y,i);
x=x+d1;
/*======================ASCII×óoˉêy¼ˉoÏ=====================================*/
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′® 5x8 êμ¼êμãÕó8*8
//2Îêy£oÏÔê¾μÄλÖã¨x,y£©£¬ch[]òaÏÔê¾μÄ×Ö·û′®
//·μ»Ø£oÎT
void Asc5_8(unsigned char x,unsigned char y,unsigned char ch[])
unsigned char x1,c=0, i=0,j;
while (ch!='\0')
x1=x/4;
c =ch-32;
i++; //ÏÂò»¸ö×Ö·û
if(x1>61)
{x=0;
x1=x/4;
y=y+8;
} //»»DD
if (y <=48) //63-15
Set_Column_Address(Shift+x1,Shift+x1+1,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
for(j=0;j<8;j++)
Con_4_byte(ASC5X8[c*8+j],CS1); //êy¾Y×a»»
if (y >=64 )
Set_Column_Address(Shift+x1,Shift+x1+1,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
Set_Row_Address((y-63),(y-63+7),CS2); //
for(j=0;j<8;j++)
Con_4_byte(ASC5X8[c*8+j],CS2); //êy¾Y×a»»
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
for(j=0;j<(64-y);j++)
//×ÖÔúϰëÆá2¿·Ö
Set_Row_Address(0,(y+7-64),CS2); //
for(j=(64-y);j<8;j++)
x=x+8; //ϸö×Ö·ûx×ø±ê
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′® 6x12 êμ¼êμãÕó8*12
//·μ»Ø£oÎT
void Asc6_12(unsigned char x,unsigned char y,unsigned char ch[])
while (ch!='\0')
x1=x/4;
c =ch-32;
i++; //ÏÂò»¸ö×Ö·û
if(x1>61)
{x=0;
x1=x/4;
y=y+12;
} //»»DD
if (y <=48) //63-15
for(j=0;j<12;j++)
Con_4_byte(ASC6X12[c*12+j],CS1); //êy¾Y×a»»
if (y >=64 )
for(j=0;j<12;j++)
Con_4_byte(ASC6X12[c*12+j],CS2); //êy¾Y×a»»
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
//×ÖÔúϰëÆá2¿·Ö
for(j=(64-y);j<12;j++)
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′® 8x16
// x: Start Column ¿aê¼áD ·¶Î§ 0~£¨255-8£©
void Asc8_16(unsigned char x,unsigned char y,unsigned char ch[])
while (ch!='\0')
x1=x/4;
c =ch-32;
i++; //ÏÂò»¸ö×Ö·û
if(x1>61)
{x=0;
x1=x/4;
y=y+16;
} //»»DD
if (y <=48) //63-15
for(j=0;j<16;j++)
Con_4_byte(ASC8X16[c*16+j],CS1); //êy¾Y×a»»
if (y >=64 )
for(j=0;j<16;j++)
Con_4_byte(ASC8X16[c*16+j],CS2); //êy¾Y×a»»
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
//×ÖÔúϰëÆá2¿·Ö
for(j=(64-y);j<16;j++)
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′® 12x24 êμ¼êμãÕó16*24
//·μ»Ø£oÎT
void Asc12_24(unsigned char x,unsigned char y,unsigned char ch[])
while (ch!='\0')
x1=x/4;
c =ch-32;
i++; //ÏÂò»¸ö×Ö·û
if(x1>59)
{x=0;
x1=x/4;
y=y+24;
} //»»DD
if (y <=48) //63-15
Set_Column_Address(Shift+x1,Shift+x1+3,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
for(j=0;j<48;j++)
Con_4_byte(ASC12X24[c*48+j],CS1); //êy¾Y×a»»
if (y >=64 )
Set_Column_Address(Shift+x1,Shift+x1+3,CS2); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa8/4-1
for(j=0;j<48;j++)
Con_4_byte(ASC12X24[c*48+j],CS2); //êy¾Y×a»»
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
//×ÖÔúϰëÆá2¿·Ö
for(j=(64-y)*2;j<48;j++)
x=x+16; //ϸö×Ö·ûx×ø±ê
//1|ÄüÃèêö£oD′èëò»×é±ê×¼ASCII×Ö·û′® 20x40 êμ¼êμãÕó24*40
//·μ»Ø£oÎT
void Asc20_40(unsigned char x,unsigned char y,unsigned char ch[])
while (ch!='\0')
x1=x/4;
c =ch-32;
i++; //ÏÂò»¸ö×Ö·û
if(x1>58)
{x=0;
x1=x/4;
y=y+40;
} //»»DD
if (y <=24) //63-23
Set_Column_Address(Shift+x1,Shift+x1+5,CS1); // éèÖÃáD×ø±ê£¬shiftÎaáDÆ«òÆá¿óé1322¾ö¶¨¡£1Îa24/4-1
Set_Row_Address(y,y+39,CS1); //
for(j=0;j<120;j++)
Con_4_byte(ASC20X40[c*120+j],CS1); //êy¾Y×a»»
if (y >=64 )
Set_Row_Address((y-63),(y-63+39),CS2); //
for(j=0;j<120;j++)
Con_4_byte(ASC20X40[c*120+j],CS2); //êy¾Y×a»»
else //×ÖÔúÖD¼äλÖÃ
{ //×ÖÔúéϰëÆá2¿·Ö
//×ÖÔúϰëÆá2¿·Ö
Set_Row_Address(0,(y+39-63),CS2); //
for(j=((64-y)*3);j<120;j++)
x=x+24; //ϸö×Ö·ûx×ø±ê
