只需一步,快速開(kāi)始
查看: 7950|回復(fù): 0
51單片機(jī)(P1與P0口)控制流水燈程序與仿真
接(P1與P0口)流水燈的程序
  1. #include   "reg52.h"
  3. #define uint unsigned int
  4. #define TimeDelay 60000
  5. void delay(uint n);
  6. void Flash0a(void);
  7. void Flash0b(void);
  8. void Flash1a(void);
  9. void Flash1b(void);
  10. void Flash2a(void);
  11. void Flash2b(void);
  12. void Flash3a(void);
  13. void Flash3b(void);
  14. /************************************************************
  15. *Function: 主函數(shù)
  16. *parameter:
  17. *Return:
  18. *Modify:
  19. *************************************************************/
  20. void main(void)
  21. {
  22. while(1)
  23. {
  24. Flash1b();
  25. Flash1a();
  26. delay(TimeDelay);
  27. delay(TimeDelay);
  28. Flash0b();
  29. Flash0a();
  30. Flash2b();
  31. Flash2a();
  32. Flash1b();
  33. Flash1a();
  34. Flash3b();
  35. Flash3a();
  36. }
  37. }
  38. /************************************************************
  39. *Function: 延時(shí)
  40. *parameter:
  41. *Return:
  42. *Modify:
  43. *************************************************************/
  44. void delay(uint n)
  45. {
  46. while(n!=0)
  47. {
  48. n--;
  49. }
  50. }
  51. void Flash0a(void)
  52. {
  53. uchar i;
  54. uchar Temp;
  55. Temp = 0x80;
  56. for(i=0;i<8;i++)
  57. {
  58. P0 = ~Temp;
  59. delay(TimeDelay);
  60. Temp = Temp >> 1;
  61. }
  62. P0 = 0xff;
  63. }
  64. void Flash0b(void)
  65. {
  66. uchar i;
  67. uchar Temp;
  68. Temp = 0x80;
  69. for(i=0;i<8;i++)
  70. {
  71. P0 = Temp;
  72. delay(TimeDelay);
  73. Temp = Temp >> 1;
  74. }
  75. P0 = 0;
  76. }
  77. void Flash1a(void)
  78. {
  79. uchar i;
  80. uchar Temp;
  81. P1 = 1;
  82. Temp = 0x80;
  83. for(i=0;i<8;i++)
  84. {
  85. P1 = ~Temp;
  86. delay(TimeDelay);
  87. Temp = Temp >> 1;
  88. }
  89. P1 = 0xff;
  90. }
  91. void Flash1b(void)
  92. {
  93. uchar i;
  94. uchar Temp;
  95. P1 = 1;
  96. Temp = 0x80;
  97. for(i=0;i<8;i++)
  98. {
  99. P1 = Temp;
  100. delay(TimeDelay);
  101. Temp = Temp >> 1;
  102. }
  103. P1 = 0;
  104. }
  105. void Flash2a(void)
  106. {
  107. uchar i;
  108. uchar Temp;
  109. P2 = 1;
  110. Temp = 0x80;
  111. for(i=0;i<8;i++)
  112. {
  113. P2 = ~Temp;
  114. delay(TimeDelay);
  115. Temp = Temp >> 1;
  116. }
  117. P2 = 0xff;
  118. }
  119. void Flash2b(void)
  120. {
  121. uchar i;
  122. uchar Temp;
  123. P2 = 1;
  124. Temp = 0x80;
  125. for(i=0;i<8;i++)
  126. {
  127. P2 = Temp;
  128. delay(TimeDelay);
  129. Temp = Temp >> 1;
  130. }
  131. P2 = 0;
  132. }
  133. void Flash3a(void)
  134. {
  135. uchar i;
  136. uchar Temp;
  137. P3 = 1;
  138. Temp = 0x80;
  139. for(i=0;i<8;i++)
  140. {
  141. P3 = ~Temp;
  142. delay(TimeDelay);
  143. Temp = Temp >> 1;
  144. }
  145. P3 = 0xff;
  146. }
  147. void Flash3b(void)
  148. {
  149. uchar i;
  150. uchar Temp;
  151. P3 = 1;
  152. Temp = 0x80;
  153. for(i=0;i<8;i++)
  154. {
  155. P3 = Temp;
  156. delay(TimeDelay);
  157. Temp = Temp >> 1;
  158. }
  159. P3 = 0;
  160. }
全部資料51hei下載地址:
lsd.rar (49.66 KB, 下載次數(shù): 14)
