oled 128*64顯示驅動源碼
- // FET113011 (2864-91H) Reference Code
- // Dot Matrix: 128*64
- // Driver IC : SSD1306 (Solomon Systech)
- // Interface : 8-bit 68XX/80XX Parallel, 3-/4-wire SPI
- // Revision :
- // Date : 2011/07/15
- // Author :
- // Editor : Humphrey Lin
- // Copyright (c) WiseChip Semiconductor Inc.
- #include <at89x51.h>
- //#define M68 // 8-bit 68XX Parallel
- // BS0=0; BS1=1; BS2=1
- #define I80 // 8-bit 80XX Parallel
- // BS0=0; BS1=0; BS2=1
- //#define SPI // 4-wire SPI
- // BS0=0; BS1=0; BS2=0
- // The unused pins should be connected with VSS mostly or floating (D2).
- // Please refer to the SSD1306 specification for detail.
- // Pin Definition
- #define xData P1 // Parallel Data Input/Output
- #define SCLK P1_0 // Serial Clock Input
- #define SDIN P1_1 // Serial Data Input
- #define RES P3_3 // Reset
- #define CS P3_4 // Chip Select
- #define DC P3_2 // Data/Command Control
- #define E P3_0 // Read/Write Enable
- #define RW P3_1 // Read/Write Select
- #define RD P3_0 // Read Signal
- #define WR P3_1 // Write Signal
- // Delay Time
- void uDelay(unsigned char l)
- while(l--);
- void Delay(unsigned char n)
- unsigned char i,j,k;
- for(k=0;k<n;k++)
- for(i=0;i<131;i++)
- for(j=0;j<15;j++)
- uDelay(203);
- // Read/Write Sequence
- #ifdef M68 // 8-bit 68XX Parallel
- void Write_Command(unsigned char Data)
- DC=0;
- CS=0;
- RW=0;
- E=1;
- xData=Data;
- E=0;
- RW=1;
- CS=1;
- DC=1;
- void Write_Data(unsigned char Data)
- DC=1;
- CS=0;
- RW=0;
- E=1;
- xData=Data;
- E=0;
- RW=1;
- CS=1;
- DC=1;
- #endif
- #ifdef I80 // 8-bit 80XX Parallel
- DC=0;
- CS=0;
- WR=0;
- xData=Data;
- WR=1;
- CS=1;
- DC=1;
- DC=1;
- CS=0;
- WR=0;
- xData=Data;
- WR=1;
- CS=1;
- DC=1;
- #endif
- #ifdef SPI // 4-wire SPI
- unsigned char i;
- CS=0;
- DC=0;
- for (i=0; i<8; i++)
- SCLK=0;
- SDIN=(Data&0x80)>>7;
- Data = Data << 1;
- // uDelay(1);
- SCLK=1;
- // uDelay(1);
- // SCLK=0;
- DC=1;
- CS=1;
- unsigned char i;
- CS=0;
- DC=1;
- SCLK=0;
- Data = Data << 1;
- // uDelay(1);
- SCLK=1;
- // uDelay(1);
- // SCLK=0;
- DC=1;
- CS=1;
- #endif
- // Instruction Setting
- void Set_Start_Column(unsigned char d)
- Write_Command(0x00+d%16); // Set Lower Column Start Address for Page Addressing Mode
- // Default => 0x00
- Write_Command(0x10+d/16); // Set Higher Column Start Address for Page Addressing Mode
- // Default => 0x10
- void Set_Addressing_Mode(unsigned char d)
- Write_Command(0x20); // Set Memory Addressing Mode
- Write_Command(d); // Default => 0x02
- // 0x00 => Horizontal Addressing Mode
- // 0x01 => Vertical Addressing Mode
- // 0x02 => Page Addressing Mode
- void Set_Column_Address(unsigned char a, unsigned char b)
- Write_Command(0x21); // Set Column Address
- Write_Command(a); // Default => 0x00 (Column Start Address)
- Write_Command(b); // Default => 0x7F (Column End Address)
- void Set_Page_Address(unsigned char a, unsigned char b)
- Write_Command(0x22); // Set Page Address
- Write_Command(a); // Default => 0x00 (Page Start Address)
- Write_Command(b); // Default => 0x07 (Page End Address)
- void Set_Start_Line(unsigned char d)
- Write_Command(0x40|d); // Set Display Start Line
- // Default => 0x40 (0x00)
- void Set_Contrast_Control(unsigned char d)
- Write_Command(0x81); // Set Contrast Control
- Write_Command(d); // Default => 0x7F
- void Set_Charge_Pump(unsigned char d)
- Write_Command(0x8D); // Set Charge Pump
- Write_Command(d); // Default => 0x10
- // 0x10 => Disable Charge Pump
- // 0x14 => Enable Charge Pump
- void Set_Segment_Remap(unsigned char d)
- Write_Command(d); // Set Segment Re-Map
- // Default => 0xA0
- // 0xA0 => Column Address 0 Mapped to SEG0
- // 0xA1 => Column Address 0 Mapped to SEG127
- void Set_Entire_Display(unsigned char d)
- Write_Command(d); // Set Entire Display On / Off
- // Default => 0xA4
- // 0xA4 => Normal Display
- // 0xA5 => Entire Display On
- void Set_Inverse_Display(unsigned char d)
- Write_Command(d); // Set Inverse Display On/Off
- // Default => 0xA6
- // 0xA6 => Normal Display
- // 0xA7 => Inverse Display On
- void Set_Multiplex_Ratio(unsigned char d)
- Write_Command(0xA8); // Set Multiplex Ratio
- Write_Command(d); // Default => 0x3F (1/64 Duty)
- void Set_Display_On_Off(unsigned char d)
- Write_Command(d); // Set Display On/Off
- // Default => 0xAE
- // 0xAE => Display Off
- // 0xAF => Display On
- void Set_Start_Page(unsigned char d)
- Write_Command(0xB0|d); // Set Page Start Address for Page Addressing Mode
- // Default => 0xB0 (0x00)
- void Set_Common_Remap(unsigned char d)
- Write_Command(d); // Set COM Output Scan Direction
- // Default => 0xC0
- // 0xC0 => Scan from COM0 to 63
- // 0xC8 => Scan from COM63 to 0
- void Set_Display_Offset(unsigned char d)
- Write_Command(0xD3); // Set Display Offset
- Write_Command(d); // Default => 0x00
- void Set_Display_Clock(unsigned char d)
- Write_Command(0xD5); // Set Display Clock Divide Ratio / Oscillator Frequency
- Write_Command(d); // Default => 0x80
- // D[3:0] => Display Clock Divider
- // D[7:4] => Oscillator Frequency
- void Set_Precharge_Period(unsigned char d)
- Write_Command(0xD9); // Set Pre-Charge Period
- Write_Command(d); // Default => 0x22 (2 Display Clocks [Phase 2] / 2 Display Clocks [Phase 1])
- // D[3:0] => Phase 1 Period in 1~15 Display Clocks
- // D[7:4] => Phase 2 Period in 1~15 Display Clocks
- void Set_Common_Config(unsigned char d)
- Write_Command(0xDA); // Set COM Pins Hardware Configuration
- Write_Command(d); // Default => 0x12
- // Alternative COM Pin Configuration
- // Disable COM Left/Right Re-Map
- void Set_VCOMH(unsigned char d)
- Write_Command(0xDB); // Set VCOMH Deselect Level
- Write_Command(d); // Default => 0x20 (0.77*VCC)
- void Set_NOP()
- Write_Command(0xE3); // Command for No Operation
- // Global Variables
- #define XLevelL 0x00
- #define XLevelH 0x10
- #define XLevel ((XLevelH&0x0F)*16+XLevelL)
- #define Max_Column 128
- #define Max_Row 64
- #define Brightness 0xFF
- // Patterns
- unsigned char code UniV[][48]={ // UniV OLED
- 0x00,0x00,0xFC,0xFC,0xFC,0xFC,0x00,0x00,0x00,0xFC,0xFC,0xFC,0xFC,0x00,0x00,0x00,0xE0,0xE0,0xE0,0xE0,0x60,0xE0,0xE0,0xE0,0xC0,0x00,0x00,0x00,0xEC,0xEC,0xEC,0xEC,0x00,0x00,0x00,0x04,0x3C,0xFC,0xFC,0xF0,0x80,0x80,0xF0,0xFC,0xFC,0x3C,0x04,0x00,
- 0x00,0x00,0x07,0x0F,0x1F,0x1F,0x1C,0x18,0x1C,0x1F,0x1F,0x0F,0x07,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x00,0x1F,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x00,0x00,0x01,0x0F,0x1F,0x1F,0x1F,0x1F,0x0F,0x01,0x00,0x00,0x00,
- 0x00,0x80,0xE0,0xE0,0xF0,0x70,0x30,0x70,0xF0,0xE0,0xE0,0x80,0x00,0x00,0x00,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,0xF0,0xF0,0x30,0x30,0x30,0x30,0x30,0x00,0x00,0x00,0xF0,0xF0,0xF0,0xF0,0x30,0x70,0xF0,0xF0,0xE0,0x80,
- 0x00,0x0F,0x3F,0x3F,0x7F,0x70,0x60,0x70,0x7F,0x3F,0x3F,0x0F,0x00,0x00,0x00,0x7F,0x7F,0x7F,0x7F,0x60,0x60,0x60,0x60,0x00,0x00,0x00,0x7F,0x7F,0x7F,0x7F,0x63,0x63,0x63,0x63,0x60,0x00,0x00,0x00,0x7F,0x7F,0x7F,0x7F,0x60,0x70,0x7F,0x7F,0x3F,0x0F,
- unsigned char code Ascii_1[240][5]={ // Refer to "Times New Roman" Font Database...
- // Basic Characters
- {0x00,0x00,0x4F,0x00,0x00}, // ( 1) ! - 0x0021 Exclamation Mark
- {0x00,0x07,0x00,0x07,0x00}, // ( 2) " - 0x0022 Quotation Mark
- {0x14,0x7F,0x14,0x7F,0x14}, // ( 3) # - 0x0023 Number Sign
- {0x24,0x2A,0x7F,0x2A,0x12}, // ( 4) $ - 0x0024 Dollar Sign
- {0x23,0x13,0x08,0x64,0x62}, // ( 5) % - 0x0025 Percent Sign
- {0x36,0x49,0x55,0x22,0x50}, // ( 6) & - 0x0026 Ampersand
- {0x00,0x05,0x03,0x00,0x00}, // ( 7) ' - 0x0027 Apostrophe
- {0x00,0x1C,0x22,0x41,0x00}, // ( 8) ( - 0x0028 Left Parenthesis
- {0x00,0x41,0x22,0x1C,0x00}, // ( 9) ) - 0x0029 Right Parenthesis
- {0x14,0x08,0x3E,0x08,0x14}, // ( 10) * - 0x002A Asterisk
- {0x08,0x08,0x3E,0x08,0x08}, // ( 11) + - 0x002B Plus Sign
- {0x00,0x50,0x30,0x00,0x00}, // ( 12) , - 0x002C Comma
- {0x08,0x08,0x08,0x08,0x08}, // ( 13) - - 0x002D Hyphen-Minus
- {0x00,0x60,0x60,0x00,0x00}, // ( 14) . - 0x002E Full Stop
- {0x20,0x10,0x08,0x04,0x02}, // ( 15) / - 0x002F Solidus
- {0x3E,0x51,0x49,0x45,0x3E}, // ( 16) 0 - 0x0030 Digit Zero
- {0x00,0x42,0x7F,0x40,0x00}, // ( 17) 1 - 0x0031 Digit One
- {0x42,0x61,0x51,0x49,0x46}, // ( 18) 2 - 0x0032 Digit Two
- {0x21,0x41,0x45,0x4B,0x31}, // ( 19) 3 - 0x0033 Digit Three
- {0x18,0x14,0x12,0x7F,0x10}, // ( 20) 4 - 0x0034 Digit Four
- {0x27,0x45,0x45,0x45,0x39}, // ( 21) 5 - 0x0035 Digit Five
- {0x3C,0x4A,0x49,0x49,0x30}, // ( 22) 6 - 0x0036 Digit Six
- {0x01,0x71,0x09,0x05,0x03}, // ( 23) 7 - 0x0037 Digit Seven
- {0x36,0x49,0x49,0x49,0x36}, // ( 24) 8 - 0x0038 Digit Eight
- {0x06,0x49,0x49,0x29,0x1E}, // ( 25) 9 - 0x0039 Dight Nine
- {0x00,0x36,0x36,0x00,0x00}, // ( 26) : - 0x003A Colon
- {0x00,0x56,0x36,0x00,0x00}, // ( 27) ; - 0x003B Semicolon
- {0x08,0x14,0x22,0x41,0x00}, // ( 28) < - 0x003C Less-Than Sign
- {0x14,0x14,0x14,0x14,0x14}, // ( 29) = - 0x003D Equals Sign
- {0x00,0x41,0x22,0x14,0x08}, // ( 30) > - 0x003E Greater-Than Sign
- {0x02,0x01,0x51,0x09,0x06}, // ( 31) ? - 0x003F Question Mark
- {0x32,0x49,0x79,0x41,0x3E}, // ( 32) @ - 0x0040 Commercial At
- {0x7E,0x11,0x11,0x11,0x7E}, // ( 33) A - 0x0041 Latin Capital Letter A
- {0x7F,0x49,0x49,0x49,0x36}, // ( 34) B - 0x0042 Latin Capital Letter B
- {0x3E,0x41,0x41,0x41,0x22}, // ( 35) C - 0x0043 Latin Capital Letter C
- {0x7F,0x41,0x41,0x22,0x1C}, // ( 36) D - 0x0044 Latin Capital Letter D
- {0x7F,0x49,0x49,0x49,0x41}, // ( 37) E - 0x0045 Latin Capital Letter E
- {0x7F,0x09,0x09,0x09,0x01}, // ( 38) F - 0x0046 Latin Capital Letter F
- {0x3E,0x41,0x49,0x49,0x7A}, // ( 39) G - 0x0047 Latin Capital Letter G
- {0x7F,0x08,0x08,0x08,0x7F}, // ( 40) H - 0x0048 Latin Capital Letter H
- {0x00,0x41,0x7F,0x41,0x00}, // ( 41) I - 0x0049 Latin Capital Letter I
- {0x20,0x40,0x41,0x3F,0x01}, // ( 42) J - 0x004A Latin Capital Letter J
- {0x7F,0x08,0x14,0x22,0x41}, // ( 43) K - 0x004B Latin Capital Letter K
- {0x7F,0x40,0x40,0x40,0x40}, // ( 44) L - 0x004C Latin Capital Letter L
- {0x7F,0x02,0x0C,0x02,0x7F}, // ( 45) M - 0x004D Latin Capital Letter M
- {0x7F,0x04,0x08,0x10,0x7F}, // ( 46) N - 0x004E Latin Capital Letter N
- {0x3E,0x41,0x41,0x41,0x3E}, // ( 47) O - 0x004F Latin Capital Letter O
- {0x7F,0x09,0x09,0x09,0x06}, // ( 48) P - 0x0050 Latin Capital Letter P
- {0x3E,0x41,0x51,0x21,0x5E}, // ( 49) Q - 0x0051 Latin Capital Letter Q
- {0x7F,0x09,0x19,0x29,0x46}, // ( 50) R - 0x0052 Latin Capital Letter R
- {0x46,0x49,0x49,0x49,0x31}, // ( 51) S - 0x0053 Latin Capital Letter S
- {0x01,0x01,0x7F,0x01,0x01}, // ( 52) T - 0x0054 Latin Capital Letter T
- {0x3F,0x40,0x40,0x40,0x3F}, // ( 53) U - 0x0055 Latin Capital Letter U
- {0x1F,0x20,0x40,0x20,0x1F}, // ( 54) V - 0x0056 Latin Capital Letter V
- {0x3F,0x40,0x38,0x40,0x3F}, // ( 55) W - 0x0057 Latin Capital Letter W
- {0x63,0x14,0x08,0x14,0x63}, // ( 56) X - 0x0058 Latin Capital Letter X
- {0x07,0x08,0x70,0x08,0x07}, // ( 57) Y - 0x0059 Latin Capital Letter Y
- {0x61,0x51,0x49,0x45,0x43}, // ( 58) Z - 0x005A Latin Capital Letter Z
- {0x00,0x7F,0x41,0x41,0x00}, // ( 59) [ - 0x005B Left Square Bracket
- {0x02,0x04,0x08,0x10,0x20}, // ( 60) \ - 0x005C Reverse Solidus
- {0x00,0x41,0x41,0x7F,0x00}, // ( 61) ] - 0x005D Right Square Bracket
- {0x04,0x02,0x01,0x02,0x04}, // ( 62) ^ - 0x005E Circumflex Accent
- {0x40,0x40,0x40,0x40,0x40}, // ( 63) _ - 0x005F Low Line
- {0x01,0x02,0x04,0x00,0x00}, // ( 64) ` - 0x0060 Grave Accent
- {0x20,0x54,0x54,0x54,0x78}, // ( 65) a - 0x0061 Latin Small Letter A
- {0x7F,0x48,0x44,0x44,0x38}, // ( 66) b - 0x0062 Latin Small Letter B
- {0x38,0x44,0x44,0x44,0x20}, // ( 67) c - 0x0063 Latin Small Letter C
- {0x38,0x44,0x44,0x48,0x7F}, // ( 68) d - 0x0064 Latin Small Letter D
- {0x38,0x54,0x54,0x54,0x18}, // ( 69) e - 0x0065 Latin Small Letter E
- {0x08,0x7E,0x09,0x01,0x02}, // ( 70) f - 0x0066 Latin Small Letter F
- {0x06,0x49,0x49,0x49,0x3F}, // ( 71) g - 0x0067 Latin Small Letter G
- {0x7F,0x08,0x04,0x04,0x78}, // ( 72) h - 0x0068 Latin Small Letter H
- {0x00,0x44,0x7D,0x40,0x00}, // ( 73) i - 0x0069 Latin Small Letter I
- {0x20,0x40,0x44,0x3D,0x00}, // ( 74) j - 0x006A Latin Small Letter J
- {0x7F,0x10,0x28,0x44,0x00}, // ( 75) k - 0x006B Latin Small Letter K
- {0x00,0x41,0x7F,0x40,0x00}, // ( 76) l - 0x006C Latin Small Letter L
- {0x7C,0x04,0x18,0x04,0x7C}, // ( 77) m - 0x006D Latin Small Letter M
- {0x7C,0x08,0x04,0x04,0x78}, // ( 78) n - 0x006E Latin Small Letter N
- {0x38,0x44,0x44,0x44,0x38}, // ( 79) o - 0x006F Latin Small Letter O
- {0x7C,0x14,0x14,0x14,0x08}, // ( 80) p - 0x0070 Latin Small Letter P
- {0x08,0x14,0x14,0x18,0x7C}, // ( 81) q - 0x0071 Latin Small Letter Q
- {0x7C,0x08,0x04,0x04,0x08}, // ( 82) r - 0x0072 Latin Small Letter R
- {0x48,0x54,0x54,0x54,0x20}, // ( 83) s - 0x0073 Latin Small Letter S
- {0x04,0x3F,0x44,0x40,0x20}, // ( 84) t - 0x0074 Latin Small Letter T
- {0x3C,0x40,0x40,0x20,0x7C}, // ( 85) u - 0x0075 Latin Small Letter U
- {0x1C,0x20,0x40,0x20,0x1C}, // ( 86) v - 0x0076 Latin Small Letter V
- {0x3C,0x40,0x30,0x40,0x3C}, // ( 87) w - 0x0077 Latin Small Letter W
- {0x44,0x28,0x10,0x28,0x44}, // ( 88) x - 0x0078 Latin Small Letter X
- {0x0C,0x50,0x50,0x50,0x3C}, // ( 89) y - 0x0079 Latin Small Letter Y
- {0x44,0x64,0x54,0x4C,0x44}, // ( 90) z - 0x007A Latin Small Letter Z
- {0x00,0x08,0x36,0x41,0x00}, // ( 91) { - 0x007B Left Curly Bracket
- {0x00,0x00,0x7F,0x00,0x00}, // ( 92) | - 0x007C Vertical Line
- {0x00,0x41,0x36,0x08,0x00}, // ( 93) } - 0x007D Right Curly Bracket
- {0x02,0x01,0x02,0x04,0x02}, // ( 94) ~ - 0x007E Tilde
- {0x3E,0x55,0x55,0x41,0x22}, // ( 95) C - 0x0080 <Control>
- {0x00,0x00,0x00,0x00,0x00}, // ( 96) - 0x00A0 No-Break Space
- {0x00,0x00,0x79,0x00,0x00}, // ( 97) ! - 0x00A1 Inverted Exclamation Mark
- {0x18,0x24,0x74,0x2E,0x24}, // ( 98) c - 0x00A2 Cent Sign
- {0x48,0x7E,0x49,0x42,0x40}, // ( 99) L - 0x00A3 Pound Sign
- {0x5D,0x22,0x22,0x22,0x5D}, // (100) o - 0x00A4 Currency Sign
- {0x15,0x16,0x7C,0x16,0x15}, // (101) Y - 0x00A5 Yen Sign
- {0x00,0x00,0x77,0x00,0x00}, // (102) | - 0x00A6 Broken Bar
- {0x0A,0x55,0x55,0x55,0x28}, // (103) - 0x00A7 Section Sign
- {0x00,0x01,0x00,0x01,0x00}, // (104) " - 0x00A8 Diaeresis
- {0x00,0x0A,0x0D,0x0A,0x04}, // (105) - 0x00AA Feminine Ordinal Indicator
- {0x08,0x14,0x2A,0x14,0x22}, // (106) << - 0x00AB Left-Pointing Double Angle Quotation Mark
- {0x04,0x04,0x04,0x04,0x1C}, // (107) - 0x00AC Not Sign
- {0x00,0x08,0x08,0x08,0x00}, // (108) - - 0x00AD Soft Hyphen
- {0x01,0x01,0x01,0x01,0x01}, // (109) - 0x00AF Macron
- {0x00,0x02,0x05,0x02,0x00}, // (110) - 0x00B0 Degree Sign
- {0x44,0x44,0x5F,0x44,0x44}, // (111) +- - 0x00B1 Plus-Minus Sign
- {0x00,0x00,0x04,0x02,0x01}, // (112) ` - 0x00B4 Acute Accent
- {0x7E,0x20,0x20,0x10,0x3E}, // (113) u - 0x00B5 Micro Sign
- {0x06,0x0F,0x7F,0x00,0x7F}, // (114) - 0x00B6 Pilcrow Sign
- {0x00,0x18,0x18,0x00,0x00}, // (115) . - 0x00B7 Middle Dot
- {0x00,0x40,0x50,0x20,0x00}, // (116) - 0x00B8 Cedilla
- {0x00,0x0A,0x0D,0x0A,0x00}, // (117) - 0x00BA Masculine Ordinal Indicator
- {0x22,0x14,0x2A,0x14,0x08}, // (118) >> - 0x00BB Right-Pointing Double Angle Quotation Mark
- {0x17,0x08,0x34,0x2A,0x7D}, // (119) /4 - 0x00BC Vulgar Fraction One Quarter
- {0x17,0x08,0x04,0x6A,0x59}, // (120) /2 - 0x00BD Vulgar Fraction One Half
- {0x30,0x48,0x45,0x40,0x20}, // (121) ? - 0x00BF Inverted Question Mark
- {0x70,0x29,0x26,0x28,0x70}, // (122) `A - 0x00C0 Latin Capital Letter A with Grave
- {0x70,0x28,0x26,0x29,0x70}, // (123) 'A - 0x00C1 Latin Capital Letter A with Acute
- {0x70,0x2A,0x25,0x2A,0x70}, // (124) ^A - 0x00C2 Latin Capital Letter A with Circumflex
- {0x72,0x29,0x26,0x29,0x70}, // (125) ~A - 0x00C3 Latin Capital Letter A with Tilde
- {0x70,0x29,0x24,0x29,0x70}, // (126) "A - 0x00C4 Latin Capital Letter A with Diaeresis
- {0x70,0x2A,0x2D,0x2A,0x70}, // (127) A - 0x00C5 Latin Capital Letter A with Ring Above
- {0x7E,0x11,0x7F,0x49,0x49}, // (128) AE - 0x00C6 Latin Capital Letter Ae
- {0x0E,0x51,0x51,0x71,0x11}, // (129) C - 0x00C7 Latin Capital Letter C with Cedilla
- {0x7C,0x55,0x56,0x54,0x44}, // (130) `E - 0x00C8 Latin Capital Letter E with Grave
- {0x7C,0x55,0x56,0x54,0x44}, // (131) 'E - 0x00C9 Latin Capital Letter E with Acute
- {0x7C,0x56,0x55,0x56,0x44}, // (132) ^E - 0x00CA Latin Capital Letter E with Circumflex
- {0x7C,0x55,0x54,0x55,0x44}, // (133) "E - 0x00CB Latin Capital Letter E with Diaeresis
- {0x00,0x45,0x7E,0x44,0x00}, // (134) `I - 0x00CC Latin Capital Letter I with Grave
- {0x00,0x44,0x7E,0x45,0x00}, // (135) 'I - 0x00CD Latin Capital Letter I with Acute
- {0x00,0x46,0x7D,0x46,0x00}, // (136) ^I - 0x00CE Latin Capital Letter I with Circumflex
- {0x00,0x45,0x7C,0x45,0x00}, // (137) "I - 0x00CF Latin Capital Letter I with Diaeresis
- {0x7F,0x49,0x49,0x41,0x3E}, // (138) D - 0x00D0 Latin Capital Letter Eth
- {0x7C,0x0A,0x11,0x22,0x7D}, // (139) ~N - 0x00D1 Latin Capital Letter N with Tilde
- {0x38,0x45,0x46,0x44,0x38}, // (140) `O - 0x00D2 Latin Capital Letter O with Grave
- {0x38,0x44,0x46,0x45,0x38}, // (141) 'O - 0x00D3 Latin Capital Letter O with Acute
- {0x38,0x46,0x45,0x46,0x38}, // (142) ^O - 0x00D4 Latin Capital Letter O with Circumflex
- {0x38,0x46,0x45,0x46,0x39}, // (143) ~O - 0x00D5 Latin Capital Letter O with Tilde
- {0x38,0x45,0x44,0x45,0x38}, // (144) "O - 0x00D6 Latin Capital Letter O with Diaeresis
- {0x22,0x14,0x08,0x14,0x22}, // (145) x - 0x00D7 Multiplcation Sign
- {0x2E,0x51,0x49,0x45,0x3A}, // (146) O - 0x00D8 Latin Capital Letter O with Stroke
- {0x3C,0x41,0x42,0x40,0x3C}, // (147) `U - 0x00D9 Latin Capital Letter U with Grave
- {0x3C,0x40,0x42,0x41,0x3C}, // (148) 'U - 0x00DA Latin Capital Letter U with Acute
- {0x3C,0x42,0x41,0x42,0x3C}, // (149) ^U - 0x00DB Latin Capital Letter U with Circumflex
- {0x3C,0x41,0x40,0x41,0x3C}, // (150) "U - 0x00DC Latin Capital Letter U with Diaeresis
- {0x0C,0x10,0x62,0x11,0x0C}, // (151) `Y - 0x00DD Latin Capital Letter Y with Acute
- {0x7F,0x12,0x12,0x12,0x0C}, // (152) P - 0x00DE Latin Capital Letter Thom
- {0x40,0x3E,0x01,0x49,0x36}, // (153) B - 0x00DF Latin Capital Letter Sharp S
- {0x20,0x55,0x56,0x54,0x78}, // (154) `a - 0x00E0 Latin Small Letter A with Grave
- {0x20,0x54,0x56,0x55,0x78}, // (155) 'a - 0x00E1 Latin Small Letter A with Acute
- {0x20,0x56,0x55,0x56,0x78}, // (156) ^a - 0x00E2 Latin Small Letter A with Circumflex
- {0x20,0x55,0x56,0x55,0x78}, // (157) ~a - 0x00E3 Latin Small Letter A with Tilde
- {0x20,0x55,0x54,0x55,0x78}, // (158) "a - 0x00E4 Latin Small Letter A with Diaeresis
- {0x20,0x56,0x57,0x56,0x78}, // (159) a - 0x00E5 Latin Small Letter A with Ring Above
- {0x24,0x54,0x78,0x54,0x58}, // (160) ae - 0x00E6 Latin Small Letter Ae
- {0x0C,0x52,0x52,0x72,0x13}, // (161) c - 0x00E7 Latin Small Letter c with Cedilla
- {0x38,0x55,0x56,0x54,0x18}, // (162) `e - 0x00E8 Latin Small Letter E with Grave
- {0x38,0x54,0x56,0x55,0x18}, // (163) 'e - 0x00E9 Latin Small Letter E with Acute
- {0x38,0x56,0x55,0x56,0x18}, // (164) ^e - 0x00EA Latin Small Letter E with Circumflex
- {0x38,0x55,0x54,0x55,0x18}, // (165) "e - 0x00EB Latin Small Letter E with Diaeresis
- {0x00,0x49,0x7A,0x40,0x00}, // (166) `i - 0x00EC Latin Small Letter I with Grave
- {0x00,0x48,0x7A,0x41,0x00}, // (167) 'i - 0x00ED Latin Small Letter I with Acute
- {0x00,0x4A,0x79,0x42,0x00}, // (168) ^i - 0x00EE Latin Small Letter I with Circumflex
- {0x00,0x4A,0x78,0x42,0x00}, // (169) "i - 0x00EF Latin Small Letter I with Diaeresis
- {0x31,0x4A,0x4E,0x4A,0x30}, // (170) - 0x00F0 Latin Small Letter Eth
- {0x7A,0x11,0x0A,0x09,0x70}, // (171) ~n - 0x00F1 Latin Small Letter N with Tilde
- {0x30,0x49,0x4A,0x48,0x30}, // (172) `o - 0x00F2 Latin Small Letter O with Grave
- {0x30,0x48,0x4A,0x49,0x30}, // (173) 'o - 0x00F3 Latin Small Letter O with Acute
- {0x30,0x4A,0x49,0x4A,0x30}, // (174) ^o - 0x00F4 Latin Small Letter O with Circumflex
- {0x30,0x4A,0x49,0x4A,0x31}, // (175) ~o - 0x00F5 Latin Small Letter O with Tilde
- {0x30,0x4A,0x48,0x4A,0x30}, // (176) "o - 0x00F6 Latin Small Letter O with Diaeresis
- {0x08,0x08,0x2A,0x08,0x08}, // (177) + - 0x00F7 Division Sign
- {0x38,0x64,0x54,0x4C,0x38}, // (178) o - 0x00F8 Latin Small Letter O with Stroke
- {0x38,0x41,0x42,0x20,0x78}, // (179) `u - 0x00F9 Latin Small Letter U with Grave
- {0x38,0x40,0x42,0x21,0x78}, // (180) 'u - 0x00FA Latin Small Letter U with Acute
- {0x38,0x42,0x41,0x22,0x78}, // (181) ^u - 0x00FB Latin Small Letter U with Circumflex
- {0x38,0x42,0x40,0x22,0x78}, // (182) "u - 0x00FC Latin Small Letter U with Diaeresis
- {0x0C,0x50,0x52,0x51,0x3C}, // (183) 'y - 0x00FD Latin Small Letter Y with Acute
- {0x7E,0x14,0x14,0x14,0x08}, // (184) p - 0x00FE Latin Small Letter Thom
- {0x0C,0x51,0x50,0x51,0x3C}, // (185) "y - 0x00FF Latin Small Letter Y with Diaeresis
- {0x1E,0x09,0x09,0x29,0x5E}, // (186) A - 0x0104 Latin Capital Letter A with Ogonek
- {0x08,0x15,0x15,0x35,0x4E}, // (187) a - 0x0105 Latin Small Letter A with Ogonek
- {0x38,0x44,0x46,0x45,0x20}, // (188) 'C - 0x0106 Latin Capital Letter C with Acute
- {0x30,0x48,0x4A,0x49,0x20}, // (189) 'c - 0x0107 Latin Small Letter C with Acute
- {0x38,0x45,0x46,0x45,0x20}, // (190) C - 0x010C Latin Capital Letter C with Caron
- {0x30,0x49,0x4A,0x49,0x20}, // (191) c - 0x010D Latin Small Letter C with Caron
- {0x7C,0x45,0x46,0x45,0x38}, // (192) D - 0x010E Latin Capital Letter D with Caron
- {0x20,0x50,0x50,0x7C,0x03}, // (193) d' - 0x010F Latin Small Letter D with Caron
- {0x1F,0x15,0x15,0x35,0x51}, // (194) E - 0x0118 Latin Capital Letter E with Ogonek
- {0x0E,0x15,0x15,0x35,0x46}, // (195) e - 0x0119 Latin Small Letter E with Ogonek
- {0x7C,0x55,0x56,0x55,0x44}, // (196) E - 0x011A Latin Capital Letter E with Caron
- {0x38,0x55,0x56,0x55,0x18}, // (197) e - 0x011B Latin Small Letter E with Caron
- {0x00,0x44,0x7C,0x40,0x00}, // (198) i - 0x0131 Latin Small Letter Dotless I
- {0x7F,0x48,0x44,0x40,0x40}, // (199) L - 0x0141 Latin Capital Letter L with Stroke
- {0x00,0x49,0x7F,0x44,0x00}, // (200) l - 0x0142 Latin Small Letter L with Stroke
- {0x7C,0x08,0x12,0x21,0x7C}, // (201) 'N - 0x0143 Latin Capital Letter N with Acute
- {0x78,0x10,0x0A,0x09,0x70}, // (202) 'n - 0x0144 Latin Small Letter N with Acute
- {0x7C,0x09,0x12,0x21,0x7C}, // (203) N - 0x0147 Latin Capital Letter N with Caron
- {0x78,0x11,0x0A,0x09,0x70}, // (204) n - 0x0148 Latin Small Letter N with Caron
- {0x38,0x47,0x44,0x47,0x38}, // (205) "O - 0x0150 Latin Capital Letter O with Double Acute
- {0x30,0x4B,0x48,0x4B,0x30}, // (206) "o - 0x0151 Latin Small Letter O with Double Acute
- {0x3E,0x41,0x7F,0x49,0x49}, // (207) OE - 0x0152 Latin Capital Ligature Oe
- {0x38,0x44,0x38,0x54,0x58}, // (208) oe - 0x0153 Latin Small Ligature Oe
- {0x7C,0x15,0x16,0x35,0x48}, // (209) R - 0x0158 Latin Capital Letter R with Caron
- {0x78,0x11,0x0A,0x09,0x10}, // (210) r - 0x0159 Latin Small Letter R with Caron
- {0x48,0x54,0x56,0x55,0x20}, // (211) 'S - 0x015A Latin Capital Letter S with Acute
- {0x20,0x48,0x56,0x55,0x20}, // (212) 's - 0x015B Latin Small Letter S with Acute
- {0x48,0x55,0x56,0x55,0x20}, // (213) S - 0x0160 Latin Capital Letter S with Caron
- {0x20,0x49,0x56,0x55,0x20}, // (214) s - 0x0161 Latin Small Letter S with Caron
- {0x04,0x05,0x7E,0x05,0x04}, // (215) T - 0x0164 Latin Capital Letter T with Caron
- {0x08,0x3C,0x48,0x22,0x01}, // (216) t' - 0x0165 Latin Small Letter T with Caron
- {0x3C,0x42,0x45,0x42,0x3C}, // (217) U - 0x016E Latin Capital Letter U with Ring Above
- {0x38,0x42,0x45,0x22,0x78}, // (218) u - 0x016F Latin Small Letter U with Ring Above
- {0x3C,0x43,0x40,0x43,0x3C}, // (219) "U - 0x0170 Latin Capital Letter U with Double Acute
- {0x38,0x43,0x40,0x23,0x78}, // (220) "u - 0x0171 Latin Small Letter U with Double Acute
- {0x0C,0x11,0x60,0x11,0x0C}, // (221) "Y - 0x0178 Latin Capital Letter Y with Diaeresis
- {0x44,0x66,0x55,0x4C,0x44}, // (222) 'Z - 0x0179 Latin Capital Letter Z with Acute
- {0x48,0x6A,0x59,0x48,0x00}, // (223) 'z - 0x017A Latin Small Letter Z with Acute
- {0x44,0x64,0x55,0x4C,0x44}, // (224) Z - 0x017B Latin Capital Letter Z with Dot Above
- {0x48,0x68,0x5A,0x48,0x00}, // (225) z - 0x017C Latin Small Letter Z with Dot Above
- {0x44,0x65,0x56,0x4D,0x44}, // (226) Z - 0x017D Latin Capital Letter Z with Caron
- {0x48,0x69,0x5A,0x49,0x00}, // (227) z - 0x017E Latin Small Letter Z with Caron
- {0x00,0x02,0x01,0x02,0x00}, // (228) ^ - 0x02C6 Modifier Letter Circumflex Accent
- {0x00,0x01,0x02,0x01,0x00}, // (229) - 0x02C7 Caron
- {0x00,0x01,0x01,0x01,0x00}, // (230) - 0x02C9 Modifier Letter Macron
- {0x01,0x02,0x02,0x01,0x00}, // (231) - 0x02D8 Breve
- {0x00,0x00,0x01,0x00,0x00}, // (232) - 0x02D9 Dot Above
- {0x00,0x02,0x05,0x02,0x00}, // (233) - 0x02DA Ring Above
- {0x02,0x01,0x02,0x01,0x00}, // (234) ~ - 0x02DC Small Tilde
- {0x7F,0x05,0x15,0x3A,0x50}, // (235) Pt - 0x20A7 Peseta Sign
- {0x3E,0x55,0x55,0x41,0x22}, // (236) C - 0x20AC Euro Sign
- {0x18,0x14,0x08,0x14,0x0C}, // (237) - 0x221E Infinity
- {0x44,0x4A,0x4A,0x51,0x51}, // (238) < - 0x2264 Less-Than or Equal to
- {0x51,0x51,0x4A,0x4A,0x44}, // (239) > - 0x2265 Greater-Than or Equal to
- {0x74,0x42,0x41,0x42,0x74}, // (240) - 0x2302 House
- unsigned char code Ascii_2[107][5]={ // Refer to "Times New Roman" Font Database...
- // Greek & Japanese Letters
- {0x7E,0x11,0x11,0x11,0x7E}, // ( 1) A - 0x0391 Greek Capital Letter Alpha
- {0x7F,0x49,0x49,0x49,0x36}, // ( 2) B - 0x0392 Greek Capital Letter Beta
- {0x7F,0x02,0x01,0x01,0x03}, // ( 3) - 0x0393 Greek Capital Letter Gamma
- {0x70,0x4E,0x41,0x4E,0x70}, // ( 4) - 0x0394 Greek Capital Letter Delta
- {0x7F,0x49,0x49,0x49,0x41}, // ( 5) E - 0x0395 Greek Capital Letter Epsilon
- {0x61,0x51,0x49,0x45,0x43}, // ( 6) Z - 0x0396 Greek Capital Letter Zeta
- {0x7F,0x08,0x08,0x08,0x7F}, // ( 7) H - 0x0397 Greek Capital Letter Eta
- {0x3E,0x49,0x49,0x49,0x3E}, // ( 8) - 0x0398 Greek Capital Letter Theta
- {0x00,0x41,0x7F,0x41,0x00}, // ( 9) I - 0x0399 Greek Capital Letter Iota
- {0x7F,0x08,0x14,0x22,0x41}, // ( 10) K - 0x039A Greek Capital Letter Kappa
- {0x70,0x0E,0x01,0x0E,0x70}, // ( 11) - 0x039B Greek Capital Letter Lamda
- {0x7F,0x02,0x0C,0x02,0x7F}, // ( 12) M - 0x039C Greek Capital Letter Mu
- {0x7F,0x04,0x08,0x10,0x7F}, // ( 13) N - 0x039D Greek Capital Letter Nu
- {0x63,0x5D,0x49,0x5D,0x63}, // ( 14) - 0x039E Greek Capital Letter Xi
- {0x3E,0x41,0x41,0x41,0x3E}, // ( 15) O - 0x039F Greek Capital Letter Omicron
- {0x41,0x3F,0x01,0x3F,0x41}, // ( 16) - 0x03A0 Greek Capital Letter Pi
- {0x7F,0x09,0x09,0x09,0x06}, // ( 17) P - 0x03A1 Greek Capital Letter Rho
- {0x63,0x55,0x49,0x41,0x41}, // ( 18) - 0x03A3 Greek Capital Letter Sigma
- {0x01,0x01,0x7F,0x01,0x01}, // ( 19) T - 0x03A4 Greek Capital Letter Tau
- {0x03,0x01,0x7E,0x01,0x03}, // ( 20) - 0x03A5 Greek Capital Letter Upsilon
- {0x08,0x55,0x7F,0x55,0x08}, // ( 21) - 0x03A6 Greek Capital Letter Phi
- {0x63,0x14,0x08,0x14,0x63}, // ( 22) X - 0x03A7 Greek Capital Letter Chi
- {0x07,0x48,0x7F,0x48,0x07}, // ( 23) - 0x03A8 Greek Capital Letter Psi
- {0x5E,0x61,0x01,0x61,0x5E}, // ( 24) - 0x03A9 Greek Capital Letter Omega
- {0x38,0x44,0x48,0x30,0x4C}, // ( 25) a - 0x03B1 Greek Small Letter Alpha
- {0x7C,0x2A,0x2A,0x2A,0x14}, // ( 26) B - 0x03B2 Greek Small Letter Beta
- {0x44,0x38,0x04,0x04,0x08}, // ( 27) r - 0x03B3 Greek Small Letter Gamma
- {0x30,0x4B,0x4D,0x59,0x30}, // ( 28) - 0x03B4 Greek Small Letter Delta
- {0x28,0x54,0x54,0x44,0x20}, // ( 29) - 0x03B5 Greek Small Letter Epsilon
- {0x00,0x18,0x55,0x52,0x22}, // ( 30) - 0x03B6 Greek Small Letter Zeta
- {0x3E,0x04,0x02,0x02,0x7C}, // ( 31) n - 0x03B7 Greek Small Letter Eta
- {0x3C,0x4A,0x4A,0x4A,0x3C}, // ( 32) - 0x03B8 Greek Small Letter Theta
- {0x00,0x3C,0x40,0x20,0x00}, // ( 33) i - 0x03B9 Greek Small Letter Iota
- {0x7C,0x10,0x28,0x44,0x40}, // ( 34) k - 0x03BA Greek Small Letter Kappa
- {0x41,0x32,0x0C,0x30,0x40}, // ( 35) - 0x03BB Greek Small Letter Lamda
- {0x7E,0x20,0x20,0x10,0x3E}, // ( 36) u - 0x03BC Greek Small Letter Mu
- {0x1C,0x20,0x40,0x20,0x1C}, // ( 37) v - 0x03BD Greek Small Letter Nu
- {0x14,0x2B,0x2A,0x2A,0x60}, // ( 38) - 0x03BE Greek Small Letter Xi
- {0x38,0x44,0x44,0x44,0x38}, // ( 39) o - 0x03BF Greek Small Letter Omicron
- {0x44,0x3C,0x04,0x7C,0x44}, // ( 40) - 0x03C0 Greek Small Letter Pi
- {0x70,0x28,0x24,0x24,0x18}, // ( 41) p - 0x03C1 Greek Small Letter Rho
- {0x0C,0x12,0x12,0x52,0x60}, // ( 42) - 0x03C2 Greek Small Letter Final Sigma
- {0x38,0x44,0x4C,0x54,0x24}, // ( 43) - 0x03C3 Greek Small Letter Sigma
- {0x04,0x3C,0x44,0x20,0x00}, // ( 44) t - 0x03C4 Greek Small Letter Tau
- {0x3C,0x40,0x40,0x20,0x1C}, // ( 45) v - 0x03C5 Greek Small Letter Upsilon
- {0x18,0x24,0x7E,0x24,0x18}, // ( 46) - 0x03C6 Greek Small Letter Phi
- {0x44,0x28,0x10,0x28,0x44}, // ( 47) x - 0x03C7 Greek Small Letter Chi
- {0x0C,0x10,0x7E,0x10,0x0C}, // ( 48) - 0x03C8 Greek Small Letter Psi
- {0x38,0x44,0x30,0x44,0x38}, // ( 49) w - 0x03C9 Greek Small Letter Omega
- {0x0A,0x0A,0x4A,0x2A,0x1E}, // ( 50) - 0xFF66 Katakana Letter Wo
- {0x04,0x44,0x34,0x14,0x0C}, // ( 51) - 0xFF67 Katakana Letter Small A
- {0x20,0x10,0x78,0x04,0x00}, // ( 52) - 0xFF68 Katakana Letter Small I
- {0x18,0x08,0x4C,0x48,0x38}, // ( 53) - 0xFF69 Katakana Letter Small U
- {0x48,0x48,0x78,0x48,0x48}, // ( 54) - 0xFF6A Katakana Letter Small E
- {0x48,0x28,0x18,0x7C,0x08}, // ( 55) - 0xFF6B Katakana Letter Small O
- {0x08,0x7C,0x08,0x28,0x18}, // ( 56) - 0xFF6C Katakana Letter Small Ya
- {0x40,0x48,0x48,0x78,0x40}, // ( 57) - 0xFF6D Katakana Letter Small Yu
- {0x54,0x54,0x54,0x7C,0x00}, // ( 58) - 0xFF6E Katakana Letter Small Yo
- {0x18,0x00,0x58,0x40,0x38}, // ( 59) - 0xFF6F Katakana Letter Small Tu
- {0x08,0x08,0x08,0x08,0x08}, // ( 60) - 0xFF70 Katakana-Hiragana Prolonged Sound Mark
- {0x01,0x41,0x3D,0x09,0x07}, // ( 61) - 0xFF71 Katakana Letter A
- {0x10,0x08,0x7C,0x02,0x01}, // ( 62) - 0xFF72 Katakana Letter I
- {0x0E,0x02,0x43,0x22,0x1E}, // ( 63) - 0xFF73 Katakana Letter U
- {0x42,0x42,0x7E,0x42,0x42}, // ( 64) - 0xFF74 Katakana Letter E
- {0x22,0x12,0x0A,0x7F,0x02}, // ( 65) - 0xFF75 Katakana Letter O
- {0x42,0x3F,0x02,0x42,0x3E}, // ( 66) - 0xFF76 Katakana Letter Ka
- {0x0A,0x0A,0x7F,0x0A,0x0A}, // ( 67) - 0xFF77 Katakana Letter Ki
- {0x08,0x46,0x42,0x22,0x1E}, // ( 68) - 0xFF78 Katakana Letter Ku
- {0x04,0x03,0x42,0x3E,0x02}, // ( 69) - 0xFF79 Katakana Letter Ke
- {0x42,0x42,0x42,0x42,0x7E}, // ( 70) - 0xFF7A Katakana Letter Ko
- {0x02,0x4F,0x22,0x1F,0x02}, // ( 71) - 0xFF7B Katakana Letter Sa
- {0x4A,0x4A,0x40,0x20,0x1C}, // ( 72) - 0xFF7C Katakana Letter Shi
- {0x42,0x22,0x12,0x2A,0x46}, // ( 73) - 0xFF7D Katakana Letter Su
- {0x02,0x3F,0x42,0x4A,0x46}, // ( 74) - 0xFF7E Katakana Letter Se
- {0x06,0x48,0x40,0x20,0x1E}, // ( 75) - 0xFF7F Katakana Letter So
- {0x08,0x46,0x4A,0x32,0x1E}, // ( 76) - 0xFF80 Katakana Letter Ta
- {0x0A,0x4A,0x3E,0x09,0x08}, // ( 77) - 0xFF81 Katakana Letter Chi
- {0x0E,0x00,0x4E,0x20,0x1E}, // ( 78) - 0xFF82 Katakana Letter Tsu
- {0x04,0x45,0x3D,0x05,0x04}, // ( 79) - 0xFF83 Katakana Letter Te
- {0x00,0x7F,0x08,0x10,0x00}, // ( 80) - 0xFF84 Katakana Letter To
- {0x44,0x24,0x1F,0x04,0x04}, // ( 81) - 0xFF85 Katakana Letter Na
- {0x40,0x42,0x42,0x42,0x40}, // ( 82) - 0xFF86 Katakana Letter Ni
- {0x42,0x2A,0x12,0x2A,0x06}, // ( 83) - 0xFF87 Katakana Letter Nu
- {0x22,0x12,0x7B,0x16,0x22}, // ( 84) - 0xFF88 Katakana Letter Ne
- {0x00,0x40,0x20,0x1F,0x00}, // ( 85) - 0xFF89 Katakana Letter No
- {0x78,0x00,0x02,0x04,0x78}, // ( 86) - 0xFF8A Katakana Letter Ha
- {0x3F,0x44,0x44,0x44,0x44}, // ( 87) - 0xFF8B Katakana Letter Hi
- {0x02,0x42,0x42,0x22,0x1E}, // ( 88) - 0xFF8C Katakana Letter Fu
- {0x04,0x02,0x04,0x08,0x30}, // ( 89) - 0xFF8D Katakana Letter He
- {0x32,0x02,0x7F,0x02,0x32}, // ( 90) - 0xFF8E Katakana Letter Ho
- {0x02,0x12,0x22,0x52,0x0E}, // ( 91) - 0xFF8F Katakana Letter Ma
- {0x00,0x2A,0x2A,0x2A,0x40}, // ( 92) - 0xFF90 Katakana Letter Mi
- {0x38,0x24,0x22,0x20,0x70}, // ( 93) - 0xFF91 Katakana Letter Mu
- {0x40,0x28,0x10,0x28,0x06}, // ( 94) - 0xFF92 Katakana Letter Me
- {0x0A,0x3E,0x4A,0x4A,0x4A}, // ( 95) - 0xFF93 Katakana Letter Mo
- {0x04,0x7F,0x04,0x14,0x0C}, // ( 96) - 0xFF94 Katakana Letter Ya
- {0x40,0x42,0x42,0x7E,0x40}, // ( 97) - 0xFF95 Katakana Letter Yu
- {0x4A,0x4A,0x4A,0x4A,0x7E}, // ( 98) - 0xFF96 Katakana Letter Yo
- {0x04,0x05,0x45,0x25,0x1C}, // ( 99) - 0xFF97 Katakana Letter Ra
- {0x0F,0x40,0x20,0x1F,0x00}, // (100) - 0xFF98 Katakana Letter Ri
- {0x7C,0x00,0x7E,0x40,0x30}, // (101) - 0xFF99 Katakana Letter Ru
- {0x7E,0x40,0x20,0x10,0x08}, // (102) - 0xFF9A Katakana Letter Re
- {0x7E,0x42,0x42,0x42,0x7E}, // (103) - 0xFF9B Katakana Letter Ro
- {0x0E,0x02,0x42,0x22,0x1E}, // (104) - 0xFF9C Katakana Letter Wa
- {0x42,0x42,0x40,0x20,0x18}, // (105) - 0xFF9D Katakana Letter N
- {0x02,0x04,0x01,0x02,0x00}, // (106) - 0xFF9E Katakana Voiced Sound Mark
- {0x07,0x05,0x07,0x00,0x00}, // (107) - 0xFF9F Katakana Semi-Voiced Sound Mark
- // Show Regular Pattern (Full Screen)
- void Fill_RAM(unsigned char Data)
- unsigned char i,j;
- for(i=0;i<8;i++)
- Set_Start_Page(i);
- Set_Start_Column(0x00);
- for(j=0;j<128;j++)
- Write_Data(Data);
- // Show Regular Pattern (Partial or Full Screen)
- // a: Start Page
- // b: End Page
- // c: Start Column
- // d: Total Columns
- void Fill_Block(unsigned char Data, unsigned char a, unsigned char b, unsigned char c, unsigned char d)
- for(i=a;i<(b+1);i++)
- Set_Start_Column(c);
- for(j=0;j<d;j++)
- Write_Data(Data);
- // Show Checkboard (Full Screen)
- void Checkerboard()
- for(i=0;i<8;i++)
- for(j=0;j<64;j++)
- Write_Data(0x55);
- Write_Data(0xaa);
- Set_Start_Page(0);
- Write_Data(0x55);
- Write_Data(0xaa);
- Write_Data(0x55);
- Write_Data(0xaa);
- // Show Frame (Full Screen)
- void Frame()
- Set_Start_Page(0x00);
- Set_Start_Column(XLevel);
- for(i=0;i<Max_Column;i++)
- Write_Data(0x01);
- Set_Start_Page(0x07);
- Write_Data(0x80);
- for(i=0;i<8;i++)
- for(j=0;j<Max_Column;j+=(Max_Column-1))
- Set_Start_Column(XLevel+j);
- Write_Data(0xFF);
- void Frame_2()
- Write_Data(0x01);
- Set_Start_Page(0x04);
- Write_Data(0x80);
- Set_Start_Page(0x05);
- Write_Data(0x01);
- Write_Data(0x80);
- for(i=0;i<8;i++)
- Write_Data(0xFF);
- // Show Character (5x7)
- // a: Database
- // b: Ascii
- // c: Start Page
- // d: Start Column
- void Show_Font57(unsigned char a, unsigned char b, unsigned char c, unsigned char d)
- unsigned char *Src_Pointer;
- unsigned char i;
- switch(a)
- case 1:
- Src_Pointer=&Ascii_1[(b-1)][0];
- break;
- case 2:
- Src_Pointer=&Ascii_2[(b-1)][0];
- break;
- Set_Start_Page(c);
- Set_Start_Column(d);
- for(i=0;i<5;i++)
- Write_Data(*Src_Pointer);
- Src_Pointer++;
- Write_Data(0x00);
- // Show String
- // a: Database
- // b: Start Page
- // * Must write "0" in the end...
- void Show_String(unsigned char a, unsigned char *Data_Pointer, unsigned char b, unsigned char c)
- Src_Pointer=Data_Pointer;
- Show_Font57(1,96,b,c); // No-Break Space
- // Must be written first before the string start...
- while(1)
- Show_Font57(a,*Src_Pointer,b,c);
- Src_Pointer++;
- c+=6;
- if(*Src_Pointer == 0) break;
- // Show Pattern (Partial or Full Screen)
- // a: Start Page
- // b: End Page
- void Show_Pattern(unsigned char *Data_Pointer, unsigned char a, unsigned char b, unsigned char c, unsigned char d)
- for(j=0;j<d;j++)
- Src_Pointer++;
- // Vertical / Fade Scrolling (Partial or Full Screen)
- // a: Scrolling Direction
- // "0x00" (Upward)
- // "0x01" (Downward)
- // b: Set Top Fixed Area
- // c: Set Vertical Scroll Area
- // d: Set Numbers of Row Scroll per Step
- // e: Set Time Interval between Each Scroll Step
- void Vertical_Scroll(unsigned char a, unsigned char b, unsigned char c, unsigned char d, unsigned char e)
- unsigned int i,j;
- Write_Command(0xA3); // Set Vertical Scroll Area
- Write_Command(b); // Default => 0x00 (Top Fixed Area)
- Write_Command(c); // Default => 0x40 (Vertical Scroll Area)
- switch(a)
- case 0:
- for(i=0;i<c;i+=d)
- Set_Start_Line(i);
- for(j=0;j<e;j++)
- uDelay(200);
- break;
- case 1:
- for(i=0;i<c;i+=d)
- Set_Start_Line(c-i);
- for(j=0;j<e;j++)
- uDelay(200);
- break;
- Set_Start_Line(0x00);
- // Continuous Horizontal Scrolling (Partial or Full Screen)
- // "0x00" (Rightward)
- // "0x01" (Leftward)
- // b: Define Start Page Address
- // c: Define End Page Address
- // d: Set Time Interval between Each Scroll Step in Terms of Frame Frequency
- // e: Delay Time
- void Horizontal_Scroll(unsigned char a, unsigned char b, unsigned char c, unsigned char d, unsigned char e)
- Write_Command(0x26|a); // Horizontal Scroll Setup
- Write_Command(0x00); // => (Dummy Write for First Parameter)
- Write_Command(b);
- Write_Command(d);
- Write_Command(c);
- Write_Command(0x2F); // Activate Scrolling
- Delay(e);
- // Continuous Vertical / Horizontal / Diagonal Scrolling (Partial or Full Screen)
- // "0x00" (Vertical & Rightward)
- // "0x01" (Vertical & Leftward)
- // b: Define Start Row Address (Horizontal / Diagonal Scrolling)
- // c: Define End Page Address (Horizontal / Diagonal Scrolling)
- // d: Set Top Fixed Area (Vertical Scrolling)
- // e: Set Vertical Scroll Area (Vertical Scrolling)
- // f: Set Numbers of Row Scroll per Step (Vertical / Diagonal Scrolling)
- // g: Set Time Interval between Each Scroll Step in Terms of Frame Frequency
- // h: Delay Time
- // * d+e must be less than or equal to the Multiplex Ratio...
- void Continuous_Scroll(unsigned char a, unsigned char b, unsigned char c, unsigned char d, unsigned char e, unsigned char f, unsigned char g, unsigned char h)
- Write_Command(d); // Default => 0x00 (Top Fixed Area)
- Write_Command(e); // Default => 0x40 (Vertical Scroll Area)
- Write_Command(0x29+a); // Continuous Vertical & Horizontal Scroll Setup
- Write_Command(b);
- Write_Command(g);
- Write_Command(c);
- Write_Command(f);
- Delay(h);
- // Deactivate Scrolling (Full Screen)
- void Deactivate_Scroll()
- Write_Command(0x2E); // Deactivate Scrolling
- // Fade In (Full Screen)
- void Fade_In()
- unsigned int i;
- Set_Display_On_Off(0xAF);
- for(i=0;i<(Brightness+1);i++)
- Set_Contrast_Control(i);
- uDelay(200);
- uDelay(200);
- uDelay(200);
- // Fade Out (Full Screen)
- void Fade_Out()
- unsigned int i;
- for(i=(Brightness+1);i>0;i--)
- Set_Contrast_Control(i-1);
- uDelay(200);
- uDelay(200);
- uDelay(200);
- Set_Display_On_Off(0xAE);
- // Sleep Mode
- // "0x00" Enter Sleep Mode
- // "0x01" Exit Sleep Mode
- void Sleep(unsigned char a)
- switch(a)
- case 0:
- Set_Entire_Display(0xA5);
- break;
- case 1:
- Set_Entire_Display(0xA4);
- break;
- // Connection Test
- void Test()
- unsigned char i;
- RES=0;
- for(i=0;i<200;i++)
- uDelay(200);
- RES=1;
- Set_Entire_Display(0xA5); // Enable Entire Display On (0xA4/0xA5)
- while(1)
- Set_Display_On_Off(0xAF); // Display On (0xAE/0xAF)
- Delay(2);
- Set_Display_On_Off(0xAE); // Display Off (0xAE/0xAF)
- Delay(2);
- // Initialization
- void OLED_Init_E() // VCC Supplied Externally
- unsigned char i;
- RES=0;
- uDelay(200);
- RES=1;
- Set_Display_Clock(0x80); // Set Clock as 100 Frames/Sec
- Set_Multiplex_Ratio(0x3F); // 1/64 Duty (0x0F~0x3F)
- Set_Display_Offset(0x3F); // Shift Mapping RAM Counter (0x00~0x3F)
- Set_Start_Line(0x00); // Set Mapping RAM Display Start Line (0x00~0x3F)
- Set_Charge_Pump(0x14); // Disable Embedded DC/DC Converter (0x10/0x14) 0x10
- Set_Addressing_Mode(0x02); // Set Page Addressing Mode (0x00/0x01/0x02)
- Set_Segment_Remap(0xA1); // Set SEG/Column Mapping (0xA0/0xA1)
- Set_Common_Remap(0xC8); // Set COM/Row Scan Direction (0xC0/0xC8)
- Set_Common_Config(0x12); // Set Sequential Configuration (0x02/0x12)
- Set_Contrast_Control(Brightness); // Set SEG Output Current
- Set_Precharge_Period(0x22); // Set Pre-Charge as 2 Clocks & Discharge as 2 Clocks
- Set_VCOMH(0x20); // Set VCOM Deselect Level 0x40
- Set_Entire_Display(0xA4); // Disable Entire Display On (0xA4/0xA5)
- Set_Inverse_Display(0xA6); // Disable Inverse Display On (0xA6/0xA7)
- Fill_RAM(0x00); // Clear Screen
- // Main Program
- void main()
- unsigned char code Name[]={44,85,13,65,73,13,81,73,79,78,71,0};//{55,73,83,69,35,72,73,80,0};
- // WiseChip
- unsigned char code Tel[]={11,24,24,22,13,19,23,13,21,24,23,17,22,24,0};
- // +886-37-587168
- unsigned char i;
- P1=0xFF;
- P3=0xFF;
- OLED_Init_E();
- while(1)
- // Show Pattern - UniV OLED
- Show_Pattern(&UniV[0][0],0x02,0x05,XLevel+0x28,0x30);
- Delay(1);
- // Fade In/Out (Full Screen)
- Fade_Out();
- Fade_In();
- Fade_Out();
- Fade_In();
- Delay(1);
- // Scrolling (Partial or Full Screen)
- Vertical_Scroll(0x00,0x00,Max_Row,0x01,0x20);
- // Upward
- Delay(1);
- Vertical_Scroll(0x01,0x00,Max_Row,0x01,0x20);
- // Downward
- Delay(1);
- Deactivate_Scroll();
- Continuous_Scroll(0x00,0x00,0x00,0x00,0x20,0x01,0x00,0x01);
- // Upward - Top Area
- Continuous_Scroll(0x00,0x00,0x00,0x00,0x20,0x1F,0x00,0x01);
- // Downward - Top Area
- Continuous_Scroll(0x00,0x00,0x03,0x00,0x20,0x01,0x00,0x02);
- // Up & Rightward - Top Area
- Continuous_Scroll(0x01,0x00,0x03,0x00,0x20,0x1F,0x00,0x02);
- // Down & Leftward - Top Area
- Continuous_Scroll(0x01,0x04,0x07,0x00,0x20,0x01,0x00,0x02);
- // Leftward - Bottom Area
- Continuous_Scroll(0x00,0x04,0x07,0x00,0x20,0x1F,0x00,0x02);
- // Rightward - Bottom Area
- Delay(1);
- Fill_RAM(0x00);
- // Show string
- Show_String(1,&Name,0x03,XLevel+0x28);
- Delay(1);
- // All Pixels On (Test Pattern)
- Fill_RAM(0xFF);
- Delay(1);
- Fill_RAM(0x00);
- Frame_2();
- Delay(1);
- // Checkerboard (Test Pattern)
- Checkerboard();
- Delay(1);
- // Frame (Test Pattern)
- Frame();
- Delay(1);
- // Show String - WiseChip +886-37-587168
- // Show_String(1,&Tel,0x04,XLevel+0x16);
- Delay(1);
12864_01.rar
(10.07 KB, 下載次數: 9)
2018-4-28 11:20 上傳
