電路原理圖加程序
protel99格式電路原理圖如下:
單片機(jī)源程序如下:
- #include <reg52.h> //調(diào)用單片機(jī)頭文件
- #define uchar unsigned char //宏定義"uchar"代替"unsigned char"。
- #define uint unsigned int //宏定義"uint"用來定義無符號(hào)整型數(shù)。
- #include "eeprom52.h"
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
- // A B C D E F 不顯示
- 0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff}; //斷碼
- uchar dis_smg[8] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
- uchar smg_i = 4; //顯示數(shù)碼管的個(gè)位數(shù)
- //數(shù)碼管位選定義
- sbit smg_we1 = P2^0; //數(shù)碼管位選定義
- sbit smg_we2 = P2^1;
- sbit smg_we3 = P3^6;
- sbit smg_we4 = P3^7;
- char dx_s = 0; //東西 南北 倒計(jì)時(shí)變量
- sbit dx_red = P2^4; //東西紅燈
- sbit dx_green = P2^3; //東西綠燈
- sbit dx_yellow = P2^2; //東西黃燈
- sbit nb_red = P2^7; //南北紅燈
- sbit nb_green = P2^6; //南北綠燈
- sbit nb_yellow = P2^5; //南北黃燈
- uchar flag_jtd_mode; //交通燈的模式 根據(jù)時(shí)間
- bit flag_1s = 0;
- bit flag_500ms;
- bit flag_dx_nb; //東西南北模式
- uchar flag_5m_value;
- uchar i;
- uchar flag_alarm; //模式
- uchar dx_time = 30,nb_time = 20; //東西、南北的時(shí)間
- uchar flag_jdgz ; //交通管制
- /***********************數(shù)碼位選函數(shù)*****************************/
- void smg_we_switch(uchar i)
- switch(i)
- case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
- case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
- case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
- case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
- /******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
- void write_eeprom()
- SectorErase(0x2000);
- byte_write(0x2000, dx_time);
- byte_write(0x2001, nb_time);
- byte_write(0x2058, a_a);
- /******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來*****************/
- void read_eeprom()
- dx_time = byte_read(0x2000);
- nb_time = byte_read(0x2001);
- a_a = byte_read(0x2058);
- /**************開機(jī)自檢eeprom初始化*****************/
- void init_eeprom() ///開機(jī)自檢eeprom初始化
- read_eeprom(); //先讀
- if(a_a != 1) //新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
- a_a = 1;
- dx_time = 30;
- nb_time = 20; //東西、南北的時(shí)間
- write_eeprom(); //保存數(shù)據(jù)
- * 名稱 : delay_1ms()
- * 功能 : 延時(shí)1ms函數(shù)
- * 輸入 : q
- * 輸出 : 無
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<110;j++);
- * 名稱 : display()
- * 功能 : 數(shù)碼管顯示
- * 輸入 : 無
- * 輸出 : 無
- void display()
- uchar i;
- for(i=0;i<smg_i;i++)
- P0 = 0xff; //消隱
- smg_we_switch(i); //位選
- P0 = dis_smg[i]; //段選
- delay_1ms(3);
- /*********************定時(shí)器0、定時(shí)器1初始化******************/
- void time0_init()
- EA = 1; //開總中斷
- TMOD = 0X11; //定時(shí)器0、定時(shí)器1工作方式1
- ET0 = 1; //開定時(shí)器0中斷
- TR0 = 1; //允許定時(shí)器0定時(shí)
- // ET1 = 1; //開定時(shí)器1中斷
- // TR1 = 1; //允許定時(shí)器1定時(shí)
- /*********************交通燈處理函數(shù)*********************************/
- void jiaotongdeng_dis()
- if(flag_1s == 1)
- flag_1s = 0;
- if(dx_s == 0)
- if(flag_dx_nb == 1)
- dx_s = nb_time; //南北時(shí)間
- else
- dx_s = dx_time; //東西時(shí)間
- flag_dx_nb = ~flag_dx_nb;
- dx_s --;
- dis_smg[0] = smg_du[dx_s % 10] ;
- dis_smg[1] = smg_du[dx_s / 10] ;
- dis_smg[2] = smg_du[dx_s % 10] ;
- dis_smg[3] = smg_du[dx_s / 10] ;
- /***********************南北時(shí)間*********************************/
- if(flag_dx_nb == 0)
- if(dx_s > 5)
- dx_red = 1; //滅
- dx_green = 0; //亮
- dx_yellow = 1; //滅
- nb_red = 0; //亮
- nb_green = 1; //滅
- nb_yellow = 1; //滅
- flag_5m_value = 0;
- }else if(dx_s <= 5) //當(dāng)小于5秒時(shí) 黃燈要閃了
- dx_red = 1; //滅
- dx_green = 1; //滅
- nb_red = 0; //亮
- nb_green = 1; //滅
- if(flag_500ms == 0)
- dx_yellow = 0;//亮
- else
- dx_yellow = 1;//滅
- /***********************東西時(shí)間*********************************/
- if(dx_s > 5)
- dx_red = 0; //亮
- dx_green = 1; //滅
- nb_red = 1; //滅
- nb_green = 0; //亮
- dx_red = 0; //滅
- dx_green = 1; //滅
- nb_red = 1; //滅
- nb_green = 1; //滅
- if(flag_500ms == 0) //黃燈閃爍
- nb_yellow = 0; //亮
- else
- /********************獨(dú)立按鍵程序*****************/
- uchar key_can; //按鍵值
- void key() //獨(dú)立按鍵程序
- static uchar key_new;
- key_can = 20; //按鍵值還原
- P1 |= 0x1f;
- if((P1 & 0x1f) != 0x1f) //按鍵按下
- delay_1ms(1); //按鍵消抖動(dòng)
- if(((P1 & 0x1f) != 0x1f) && (key_new == 1))
- { //確認(rèn)是按鍵按下
- key_new = 0;
- switch(P1 & 0x1f)
- case 0x1e: key_can = 1; break; //得到按鍵值
- case 0x1d: key_can = 2; break; //得到按鍵值
- case 0x1b: key_can = 3; break; //得到按鍵值
- case 0x17: key_can = 4; break; //得到按鍵值
- else
- key_new = 1;
- uchar menu_1,flag_s;
- /********************設(shè)置函數(shù)*****************/
- void key_with()
- if(key_can == 4) //交通管制按鍵
- flag_jdgz ++;
- if(flag_jdgz > 5)
- flag_jdgz = 0;
- if(flag_jdgz == 1) // 全部亮紅燈
- dx_red = 0; //亮
- dx_green = 1; //滅
- nb_red = 0; //亮
- nb_green = 1; //滅
- if(flag_jdgz == 2) // 東西紅燈 南北綠燈
- dx_red = 0; //亮
- dx_green = 1; //滅
- nb_red = 1; //滅
- nb_green = 0; //亮
- if(flag_jdgz == 3) // 南北紅燈 東西綠燈
- dx_red = 1; //滅
- dx_green = 0; //亮
- nb_red = 0; //亮
- nb_green = 1; //滅
- if(flag_jdgz == 4) // 南北綠燈 東西綠燈
- dx_red = 1; //滅
- dx_green = 0; //亮
- nb_red = 1; //滅
- nb_green = 0; //亮
- if(flag_jdgz == 5) // 南北黃燈 東西黃燈
- dx_red = 1; //滅
- dx_green = 1; //滅
- dx_yellow = 0; //亮
- nb_red = 1; //滅
- nb_green = 1; //滅
- if(key_can == 1) //設(shè)置鍵
- menu_1 ++;
- if(menu_1 >= 3)
- menu_1 = 0;
- if(menu_1 == 1) //設(shè)置東西的時(shí)間
- if(key_can == 2)
- dx_time ++ ; //加1
- if(dx_time > 99)
- dx_time = 99;
- if(key_can == 3)
- dx_time -- ; //減1
- if(dx_time <= 10)
- dx_time = 10;
- dis_smg[0] = smg_du[10] ; //顯示為A
- dis_smg[1] = smg_du[10] ; //顯示為A
- dis_smg[2] = smg_du[dx_time % 10] ; //顯示東西設(shè)置的時(shí)候
- dis_smg[3] = smg_du[dx_time / 10] ;
- if(menu_1 == 2) //設(shè)置南北的時(shí)間
- if(key_can == 2)
- nb_time ++ ; //加1
- if(nb_time > 99)
- nb_time = 99;
- if(key_can == 3)
- nb_time -- ; //減1
- if(nb_time <= 10)
- nb_time = 10;
- dis_smg[0] = smg_du[11] ; //顯示為B
- dis_smg[1] = smg_du[11] ; //顯示為B
- dis_smg[2] = smg_du[nb_time % 10] ; //顯示東西設(shè)置的時(shí)候
- dis_smg[3] = smg_du[nb_time / 10] ;
交通燈 電路原理圖.rar
(524.35 KB, 下載次數(shù): 68)
2018-4-27 20:03 上傳
點(diǎn)擊文件名下載附件
