查看: 2202|回復: 2
(分享設計)動態(tài)數(shù)碼管顯示
ID:317135 發(fā)表于 2018-4-27 14:05 | 顯示全部樓層 |閱讀模式
#include "reg52.h"
typedef unsigned char u8;
typedef unsigned int  u16;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
u8 code smgduan[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
              0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; //共陰
void delay(u16 i)
   while(i--);
void DiaDisplay()   //循環(huán)掃描八個數(shù)碼管,并顯示code smguan[16]中的數(shù)字
    u8 i;
for(i=0;i<8;i++)
    switch(i)
    case(0):
    LSA=0;LSB=0;LSC=0;break;
    case(1):
    LSA=1;LSB=0;LSC=0;break;
    case(2):
    LSA=0;LSB=1;LSC=0;break;
    case(3):
    LSA=1;LSB=1;LSC=0;break;
    case(4):
    LSA=0;LSB=0;LSC=1;break;
    case(5):
    LSA=1;LSB=0;LSC=1;break;
    case(6):
    LSA=0;LSB=1;LSC=1;break;
    case(7):
    LSA=1;LSB=1;LSC=1;break;
    P0=smgduan[i+1];
    delay(50000);
    P0=0x00;
  DiaDisplay();
ID:332416 發(fā)表于 2018-5-17 22:51 | 顯示全部樓層
數(shù)碼管動態(tài)顯示1和2
#include<reg52.h>
sbit wela=P2^7;
sbit dula=P2^6;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
                dula=1;
                P0=0x06;
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfe;
                wela=0;
                delay(5);
                dula=1;
                P0=0x5b;
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfd;
                wela=0;
                delay(5);
ID:322985 發(fā)表于 2018-7-9 19:47 | 顯示全部樓層
#include"reg52.h"
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;
void delay(uint);
        uint i,j;
        uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
        for(i=1;i<9;i++)
        switch(i)
                  case 1 : a=0;b=0;c=0;break;
                case 2 : a=1;b=0;c=0;break;
                case 3 : a=0;b=1;c=0;break;
                case 4 : a=1;b=1;c=0;break;
                case 5 : a=0;b=0;c=1;break;
                case 6 : a=1;b=0;c=1;break;
                case 7 : a=0;b=1;c=1;break;
                case 8 : a=1;b=1;c=1;break;
                for(j=0;j<16;j++)
                P0=table[j];
                delay(500);
void delay(uint w)
        uint i,j;
        for(i=w;i>0;i--)
        for(j=110;j>0;j--);
