查看: 3186|回復(fù): 0
基于stc15f2k60s2單片機(jī)超聲波測(cè)距
ID:316968 發(fā)表于 2018-4-26 14:06 來自觸屏版 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "STC15F2K60S2.h"
#include   "INTRINS.H"
unsigned char code table[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
sbit WEI1=P1^0;
sbit WEI2=P1^1;
sbit WEI3=P1^2;
sbit WEI4=P1^3;
sbit trig=P3^2;
sbit echo=P3^3;
int haomi=0,i,j,k;
void Delay12us()                //@11.0592MHz
        unsigned char i;
        i = 28;
        while (--i);
void Timer0Init(void)                //6微秒@18.432MHz
        AUXR |= 0x80;                //定時(shí)器時(shí)鐘1T模式
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TL0 = 0xBE;                //設(shè)置定時(shí)初值
//        TH0 = 0xFF;                //設(shè)置定時(shí)初值
//        TF0 = 0;                //清除TF0標(biāo)志
        //TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
void Delay3us()                //@18.432MHz
        unsigned char i;
        _nop_();
        i = 11;
        while (--i);
/*void INT1_init()
        EX1=1;
        IT1=1;
        EA=1;
void xiajiangyan() interrupt 2;
        TR0=0;
        i=haomi/1000;
        j=haomi%1000/10;
        k=haomi%10;
        WEI1=1;
        WEI2=0;
        WEI3=1;
        WEI4=1;
        P0=table[i];
    Delay3us();
        WEI1=1;
        WEI2=1;
        WEI3=0;
        WEI4=1;
        P0=table[j];
    Delay3us();
        WEI1=1;
        WEI2=1;
        WEI3=1;
        WEI4=0;
        P0=table[k];
    Delay3us();
void Delay3ms()                //@11.0592MHz
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 33;
        j = 66;
        do
                while (--j);
        } while (--i);
void Delay50us()                //@18.432MHz
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 1;
        j = 226;
        do
                while (--j);
        } while (--i);
        Timer0Init();
        //INT1_init();
        TMOD=0X01;
        //TR0=1;
        ET0=1;
        EA=1;
        P0M1=0x00;
        P0M0=0xFF;
        trig=0;
        //echo=0;
        trig=1;
        Delay12us();
        trig=0;
        while(!(echo==1));
        TR0 = 1;
        while(!(echo==0));
        TR0 = 0;
        haomi=haomi/10;
        i=haomi/100;
        j=haomi%100/10;
        k=haomi%10;
        WEI1=1;
        WEI2=1;
        WEI3=0;
        WEI4=1;
        P0=table[i];
    Delay3ms();
        Delay3ms();
        WEI1=1;
        WEI2=0;
        WEI3=1;
        WEI4=1;
        P0=table[j];
    Delay3ms();
        Delay3ms();
        WEI1=1;
        WEI2=1;
        WEI3=1;
        WEI4=0;
        P0=table[k];
    //Delay50us();
        haomi=0;
void Timer0()interrupt 1
                TL0 = 0x91;                //設(shè)置定時(shí)初值
        haomi++;
