這是一個(gè)基于單片機(jī)的智能計(jì)算器的系統(tǒng)設(shè)計(jì),希望大家交流指教。
實(shí)物圖:
單片機(jī)源程序
- /* S16 S12 S8 S4分別是123+
- S15 S11 S7 S3分別是456-
- S14 S10 S6 S2分別是789*
- S13 S9 S5 S1分別是0 CLR = /
- /* 實(shí)現(xiàn)兩個(gè)數(shù)的運(yùn)算,每個(gè)數(shù)的位數(shù)至少可以八位 */
- #include<reg52.h>
- typedef unsigned char uint8;
- typedef unsigned int uint16;
- sbit rw=P2^5;
- sbit rs=P2^6;
- sbit e=P2^7;
- sbit led=P3^7;
- sbit beep=P2^0;
- uint8 key,num;
- uint8 fuhao;//定義具體的那個(gè)符號(hào),是加減還是乘除。
- uint8 flag; //定義有沒(méi)有按下符號(hào)鍵,這個(gè)是統(tǒng)稱(chēng)
- long a,b,c,d; //定義運(yùn)算數(shù)據(jù)的第一個(gè)和第二個(gè)及等于的數(shù)變量
- uint8 k; //定義小數(shù)點(diǎn)后面顯示的位數(shù)
- uint8 biao;
- uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存顯示的數(shù)據(jù)
- void delay(uint16 i)
- while(i--);
- void lcdwrc(uint8 c)
- delay(1000);
- rs=0;
- rw=0;
- e=0;
- P0=c;
- e=1;
- delay(1000);
- e=0;
- void lcdwrd(uint8 dat)
- delay(1000);
- rs=1;
- rw=0;
- e=0;
- P0=dat;
- e=1;
- delay(1000);
- e=0;
- rs=0;
- void lcdinit()
- delay(1500);
- lcdwrc(0x38);
- delay(500);
- lcdwrc(0x38);
- delay(500);
- lcdwrc(0x38);
- delay(500);
- lcdwrc(0x38);
- lcdwrc(0x08);
- lcdwrc(0x01);
- lcdwrc(0x06);
- lcdwrc(0x0c);
- key=0;
- num=0;
- flag=0;
- fuhao=0;
- a=0;
- b=0;
- c=0;
- d=0;
- biao=0;
- led=0;
- void keyscan()
- P1=0xfe; //令第一行為0,然后判斷是哪一列按下
- if(P1!=0xfe)
- delay(1000);
- if(P1!=0xfe)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=0;break; //1
- case 0xd0: num=1;break; //2
- case 0xb0: num=2;break; //3
- case 0x70: num=3;break; //加
- while(P1!=0xfe);
- if(num==0||num==1||num==2) //確認(rèn)第一行的數(shù)1,2,3
- if(flag==0) //沒(méi)有按下符號(hào)鍵
- //led=1;
- a=a*10+dat1[num];
- else
- //led=1;
- b=b*10+dat1[num];
- if(num==3)
- //led=0;
- flag=1;
- fuhao=1;//加號(hào)+
- lcdwrd(0x30+dat1[num]);
- P1=0xfd; //令第二行為0,判斷是哪一列按下
- if(P1!=0xfd)
- delay(1000);
- if(P1!=0xfd)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=4;break; //4
- case 0xd0: num=5;break; //5
- case 0xb0: num=6;break; //6
- case 0x70: num=7;break; //減—
- while(P1!=0xfd);
- if(num==4||num==5||num==6)
- //led=1;
- a=a*10+dat1[num];
- else
- //led=1;
- b=b*10+dat1[num];
- else
- flag=1;
- fuhao=2;//帶表減號(hào)
- P1=0xfb; //令第三行為0,判斷哪一列按下
- if(P1!=0xfb)
- delay(1000);
- if(P1!=0xfb)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=8;break; //7
- case 0xd0: num=9;break; //8
- case 0xb0: num=10;break; //9
- case 0x70: num=11;break; //乘*
- while(P1!=0xfb);
- if(num==8||num==9||num==10)
- //led=1;
- a=a*10+dat1[num];
- else
- //led=1;
- b=b*10+dat1[num];
- else
- flag=1;
- fuhao=3;//帶表乘號(hào)*
- P1=0xf7; //令第四行為0,判斷哪一列按下
- if(P1!=0xf7)
- delay(1000);
- if(P1!=0xf7)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=12;break; //0
- case 0xd0: num=13;break; //清除rst
- case 0xb0: num=14;break; //等號(hào)=
- case 0x70: num=15;break; //除/
- while(P1!=0xf7);
- switch(num)
- case 12:
- //led=1;
- a=a*10+dat1[num];
- lcdwrd(0x30);
- else
- //led=1;
- b=b*10+dat1[num];
- lcdwrd(0x30);
- break;
- case 13:
- lcdwrc(0x01); //清屏指令
- a=0;
- b=0;
- flag=0;
- fuhao=0;
- break;
- case 15:
- flag=1;
- fuhao=4;
- lcdwrd(0x2f);//除號(hào)/
- break;
- case 14:
- if(fuhao==1)//加
- lcdwrc(0x4f+0x80);
- lcdwrc(0x04);//設(shè)置光標(biāo)左移,屏幕不移動(dòng)
- c=a+b;
- while(c!=0) //一位一位顯示
- lcdwrd(0x30+c%10);//顯示結(jié)果的最后一位在0x4f的位置
- c=c/10;//取前面的結(jié)果數(shù)據(jù)
- lcdwrd(0x3d); //顯示等于號(hào)=
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- if(fuhao==2) //減
- if(a>b)
- c=a-b;
- else
- c=b-a;
- if(a<b) lcdwrd(0x2d); //顯示-號(hào)
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- if(fuhao==3)//乘法
- c=a*b;
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- if(fuhao==3)//乘法
- c=a*b;
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- if(fuhao==4)
- k=0;
- c=(long)(((float)a/b)*1000);//強(qiáng)制轉(zhuǎn)換為long。
- k++;
- if(k==3)
- lcdwrd(0x2e);
- k=0;
- if(a/b<0) //如果a比b小的話那么除的結(jié)果最高位是0
- lcdwrd(0x30);
- lcdwrd(0x3d); //顯示等號(hào)
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- break;
- void main()
- lcdinit();
- while(1)
- keyscan();
全部資料51hei下載地址:
基于單片機(jī)的智能計(jì)算器.rar
(392.12 KB, 下載次數(shù): 87)
2018-4-25 14:51 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
