DS1302庫文件 Arduino
2018-4-24 20:03 上傳
- DS1302.cpp - Arduino library support for the DS1302 Trickle Charge Timekeeping Chip
- Copyright (C)2010 Henning Karlsen. All right reserved
- You can find the latest version of the library at
- This library has been made to easily interface and use the DS1302 RTC with
- the Arduino.
- If you make any modifications or improvements to the code, I would appreciate
- that you share the code with me so that I might include it in the next release.
- This library is free software; you can redistribute it and/or
- modify it under the terms of the GNU Lesser General Public
- License as published by the Free Software Foundation; either
- version 2.1 of the License, or (at your option) any later version.
- This library is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- Lesser General Public License for more details.
- You should have received a copy of the GNU Lesser General Public
- License along with this library; if not, write to the Free Software
- Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
- #include "DS1302.h"
- #define REG_SEC 0
- #define REG_MIN 1
- #define REG_HOUR 2
- #define REG_DATE 3
- #define REG_MON 4
- #define REG_DOW 5
- #define REG_YEAR 6
- #define REG_WP 7
- #define REG_TCR 8
- /* Public */
- Time::Time()
- this->year = 2010;
- this->mon = 1;
- this->date = 1;
- this->hour = 0;
- this->min = 0;
- this->sec = 0;
- this->dow = 5;
- DS1302_RAM::DS1302_RAM()
- for (int i=0; i<31; i++)
- cell[i]=0;
- DS1302::DS1302(uint8_t ce_pin, uint8_t data_pin, uint8_t sclk_pin)
- _ce_pin = ce_pin;
- _data_pin = data_pin;
- _sclk_pin = sclk_pin;
- pinMode(_ce_pin, OUTPUT);
- pinMode(_sclk_pin, OUTPUT);
- Time DS1302::getTime()
- Time t;
- _burstRead();
- t.sec = _decode(_burstArray[0]);
- t.min = _decode(_burstArray[1]);
- t.hour = _decodeH(_burstArray[2]);
- t.date = _decode(_burstArray[3]);
- t.mon = _decode(_burstArray[4]);
- t.dow = _burstArray[5];
- t.year = _decodeY(_burstArray[6])+2000;
- return t;
- void DS1302::setTime(uint8_t hour, uint8_t min, uint8_t sec)
- if (((hour>=0) && (hour<24)) && ((min>=0) && (min<60)) && ((sec>=0) && (sec<60)))
- _writeRegister(REG_HOUR, _encode(hour));
- _writeRegister(REG_MIN, _encode(min));
- _writeRegister(REG_SEC, _encode(sec));
- void DS1302::setDate(uint8_t date, uint8_t mon, uint16_t year)
- if (((date>0) && (date<=31)) && ((mon>0) && (mon<=12)) && ((year>=2000) && (year<3000)))
- year -= 2000;
- _writeRegister(REG_YEAR, _encode(year));
- _writeRegister(REG_MON, _encode(mon));
- _writeRegister(REG_DATE, _encode(date));
- void DS1302::setDOW(uint8_t dow)
- if ((dow>0) && (dow<8))
- _writeRegister(REG_DOW, dow);
- char *DS1302::getTimeStr(uint8_t format)
- char *output= "xxxxxxxx";
- Time t;
- t=getTime();
- if (t.hour<10)
- output[0]=48;
- else
- output[0]=char((t.hour / 10)+48);
- output[1]=char((t.hour % 10)+48);
- output[2]=58;
- if (t.min<10)
- output[3]=48;
- else
- output[3]=char((t.min / 10)+48);
- output[4]=char((t.min % 10)+48);
- output[5]=58;
- if (format==FORMAT_SHORT)
- output[5]=0;
- else
- if (t.sec<10)
- output[6]=48;
- else
- output[6]=char((t.sec / 10)+48);
- output[7]=char((t.sec % 10)+48);
- output[8]=0;
- return output;
- char *DS1302::getDateStr(uint8_t slformat, uint8_t eformat, char divider)
- char *output= "xxxxxxxxxx";
- int yr, offset;
- Time t;
- t=getTime();
- switch (eformat)
- case FORMAT_LITTLEENDIAN:
- if (t.date<10)
- output[0]=48;
- else
- output[0]=char((t.date / 10)+48);
- output[1]=char((t.date % 10)+48);
- output[2]=divider;
- if (t.mon<10)
- output[3]=48;
- else
- output[3]=char((t.mon / 10)+48);
- output[4]=char((t.mon % 10)+48);
- output[5]=divider;
- if (slformat==FORMAT_SHORT)
- yr=t.year-2000;
- if (yr<10)
- output[6]=48;
- else
- output[6]=char((yr / 10)+48);
- output[7]=char((yr % 10)+48);
- output[8]=0;
- else
- yr=t.year;
- output[6]=char((yr / 1000)+48);
- output[7]=char(((yr % 1000) / 100)+48);
- output[8]=char(((yr % 100) / 10)+48);
- output[9]=char((yr % 10)+48);
- output[10]=0;
- break;
- case FORMAT_BIGENDIAN:
- offset=0;
- else
- offset=2;
- yr=t.year-2000;
- if (yr<10)
- output[0]=48;
- else
- output[0]=char((yr / 10)+48);
- output[1]=char((yr % 10)+48);
- else
- yr=t.year;
- output[0]=char((yr / 1000)+48);
- output[1]=char(((yr % 1000) / 100)+48);
- output[2]=char(((yr % 100) / 10)+48);
- output[3]=char((yr % 10)+48);
- output[4]=divider;
- if (t.mon<10)
- output[3+offset]=48;
- else
- output[3+offset]=char((t.mon / 10)+48);
- output[4+offset]=char((t.mon % 10)+48);
- output[5+offset]=divider;
- if (t.date<10)
- output[6+offset]=48;
- else
- output[6+offset]=char((t.date / 10)+48);
- output[7+offset]=char((t.date % 10)+48);
- output[8+offset]=0;
- break;
- case FORMAT_MIDDLEENDIAN:
- if (t.mon<10)
- output[0]=48;
- else
- output[0]=char((t.mon / 10)+48);
- output[1]=char((t.mon % 10)+48);
- if (t.date<10)
- output[3]=48;
- else
- output[3]=char((t.date / 10)+48);
- output[4]=char((t.date % 10)+48);
- yr=t.year-2000;
- if (yr<10)
- output[6]=48;
- else
- output[8]=0;
- else
- yr=t.year;
- output[10]=0;
- break;
- return output;
- char *DS1302::getDOWStr(uint8_t format)
- char *output= "xxxxxxxxx";
- Time t;
- t=getTime();
- switch (t.dow)
- case MONDAY:
- output="Monday";
- break;
- case TUESDAY:
- output="Tuesday";
- break;
- case WEDNESDAY:
- output="Wednesday";
- break;
- case THURSDAY:
- output="Thursday";
- break;
- case FRIDAY:
- output="Friday";
- break;
- case SATURDAY:
- output="Saturday";
- break;
- case SUNDAY:
- output="Sunday";
- break;
- output[3]=0;
- return output;
- char *DS1302::getMonthStr(uint8_t format)
- Time t;
- t=getTime();
- switch (t.mon)
- case 1:
- output="January";
- break;
- case 2:
- output="February";
- break;
- case 3:
- output="March";
- break;
- case 4:
- output="April";
- break;
- case 5:
- output="May";
- break;
- case 6:
- output="June";
- break;
- case 7:
- output="July";
- break;
- case 8:
- output="August";
- break;
- case 9:
- output="September";
- break;
- case 10:
- output="October";
- break;
- case 11:
- output="November";
- break;
- case 12:
- output="December";
- break;
- output[3]=0;
- return output;
- void DS1302::halt(bool enable)
- uint8_t _reg = _readRegister(REG_SEC);
- _reg &= ~(1 << 7);
- _reg |= (enable << 7);
- _writeRegister(REG_SEC, _reg);
- void DS1302::writeProtect(bool enable)
- uint8_t _reg = (enable << 7);
- _writeRegister(REG_WP, _reg);
- void DS1302::setTCR(uint8_t value)
- _writeRegister(REG_TCR, value);
- /* Private */
- uint8_t DS1302::_readByte()
- pinMode(_data_pin, INPUT);
- uint8_t value = 0;
- uint8_t currentBit = 0;
- for (int i = 0; i < 8; ++i)
- currentBit = digitalRead(_data_pin);
- value |= (currentBit << i);
- digitalWrite(_sclk_pin, HIGH);
- delayMicroseconds(1);
- digitalWrite(_sclk_pin, LOW);
DS1302.zip
(72.21 KB, 下載次數: 259)
2018-4-24 12:52 上傳
下載積分: 黑幣 -5
