可移植的鏈表算法。
單片機(jī)源程序如下:
- #ifndef _LINUX_LIST_H
- #define _LINUX_LIST_H
- #include <stdio.h>
- #ifndef offsetof
- * Get offset of a member
- #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER)
- #endif
- #ifndef container_of
- * Casts a member of a structure out to the containing structure
- * @param ptr the pointer to the member.
- * @param type the type of the container struct this is embedded in.
- * @param member the name of the member within the struct.
- #define container_of(ptr, type, member) ({ \
- const typeof( ((type *)0)->member ) *__mptr = (ptr); \
- (type *)( (char *)__mptr - offsetof(type,member) );})
- #endif
- * These are non-NULL pointers that will result in page faults
- * under normal circumstances, used to verify that nobody uses
- * non-initialized list entries.
- #define LIST_POISON1 ((void *) 0x00100100)
- #define LIST_POISON2 ((void *) 0x00200200)
- struct list_head {
- struct list_head *next, *prev;
- #define LIST_HEAD_INIT(name) { &(name), &(name) }
- #define LIST_HEAD(name) \
- struct list_head name = LIST_HEAD_INIT(name)
- static inline void INIT_LIST_HEAD(struct list_head *list)
- list->next = list;
- list->prev = list;
- * Insert a new entry between two known consecutive entries.
- * This is only for internal list manipulation where we know
- * the prev/next entries already!
- static inline void __list_add(struct list_head *new,
- struct list_head *prev,
- struct list_head *next)
- next->prev = new;
- new->next = next;
- new->prev = prev;
- prev->next = new;
- * list_add - add a new entry
- * @new: new entry to be added
- * @head: list head to add it after
- * Insert a new entry after the specified head.
- * This is good for implementing stacks.
- static inline void list_add(struct list_head *new, struct list_head *head)
- __list_add(new, head, head->next);
- * list_add_tail - add a new entry
- * @head: list head to add it before
- * Insert a new entry before the specified head.
- * This is useful for implementing queues.
- static inline void list_add_tail(struct list_head *new, struct list_head *head)
- __list_add(new, head->prev, head);
- * Delete a list entry by making the prev/next entries
- * point to each other.
- static inline void __list_del(struct list_head * prev, struct list_head * next)
- next->prev = prev;
- prev->next = next;
- * list_del - deletes entry from list.
- * @entry: the element to delete from the list.
- * Note: list_empty on entry does not return true after this, the entry is
- * in an undefined state.
- static inline void list_del(struct list_head *entry)
- __list_del(entry->prev, entry->next);
- entry->next = LIST_POISON1;
- entry->prev = LIST_POISON2;
- * __list_for_each - iterate over a list
- * @pos: the &struct list_head to use as a loop counter.
- * @head: the head for your list.
- * This variant differs from list_for_each() in that it's the
- * simplest possible list iteration code, no prefetching is done.
- * Use this for code that knows the list to be very short (empty
- * or 1 entry) most of the time.
- #define __list_for_each(pos, head) \
- for (pos = (head)->next; pos != (head); pos = pos->next)
- * list_for_each_safe - iterate over a list safe against removal of list entry
- * @n: another &struct list_head to use as temporary storage
- #define list_for_each_safe(pos, n, head) \
- for (pos = (head)->next, n = pos->next; pos != (head); \
- pos = n, n = pos->next)
- * list_entry - get the struct for this entry
- * @ptr: the &struct list_head pointer.
- * @type: the type of the struct this is embedded in.
- * @member: the name of the list_struct within the struct.
- #define list_entry(ptr, type, member) \
- container_of(ptr, type, member)
- static inline int list_len(struct list_head *head_p)
- struct list_head *p;
- int n = 0;
- __list_for_each(p, head_p) {
- n++;
- return n;
- * list_empty - tests whether a list is empty
- * @head: the list to test.
- static inline int list_empty(const struct list_head *head)
- return head->next == head;
- * list_first - Returns first entry on list, or NULL if empty
- * @head: the list
- static inline struct list_head *list_first(const struct list_head *head)
- return list_empty(head) ? NULL : head->next;
- * list_move_tail - delete from one list and add as another's tail
- * @list: the entry to move
- * @head: the head that will follow our entry
- static inline void list_move_tail(struct list_head *list,
- struct list_head *head)
- __list_del(list->prev, list->next);
- list_add_tail(list, head);
- static inline void __list_splice(struct list_head *list,
- struct list_head *first = list->next;
- struct list_head *last = list->prev;
- struct list_head *at = head->next;
- first->prev = head;
- head->next = first;
- last->next = at;
- at->prev = last;
- * * list_splice - join two lists
- * * @list: the new list to add.
- * * @head: the place to add it in the first list.
- static inline void list_splice(struct list_head *list, struct list_head *head)
- if (!list_empty(list))
- __list_splice(list, head);
- * list_replace - replace old entry by new one
- * @old : the element to be replaced
- * @new : the new element to insert
- * If @old was empty, it will be overwritten.
- static inline void list_replace(struct list_head *old,
- struct list_head *new)
- new->next = old->next;
- new->next->prev = new;
- new->prev = old->prev;
- new->prev->next = new;
- static inline void list_replace_init(struct list_head *old,
- list_replace(old, new);
- INIT_LIST_HEAD(old);
- #endif
list.7z
(1.94 KB, 下載次數(shù): 10)
2018-4-24 11:33 上傳
點(diǎn)擊文件名下載附件
鏈表算法 下載積分: 黑幣 -5
