查看: 3461|回復(fù): 1
1602 2004 IIC模塊Arduino測(cè)試程序資料
1602 IICC模塊
單片機(jī)源程序如下:
  1. //YWROBOT
  2. //last updated on 21/12/2011
  3. //Tim Starling Fix the reset bug (Thanks Tim)
  4. //Compatible with the Arduino IDE 1.0
  5. //Library version:1.1
  6. #include "LiquidCrystal_I2C.h"
  7. #include <inttypes.h>
  8. #if defined(ARDUINO) && ARDUINO >= 100
  9. #include "Arduino.h"
  10. #define printIIC(args)        Wire.write(args)
  11. inline size_t LiquidCrystal_I2C::write(uint8_t value) {
  12.         send(value, Rs);
  13.         return 0;
  14. }
  15. #else
  16. #include "WProgram.h"
  17. #define printIIC(args)        Wire.send(args)
  18. inline void LiquidCrystal_I2C::write(uint8_t value) {
  19.         send(value, Rs);
  20. }
  21. #endif
  22. #include "Wire.h"
  23. // When the display powers up, it is configured as follows:
  24. //
  25. // 1. Display clear
  26. // 2. Function set:
  27. //    DL = 1; 8-bit interface data
  28. //    N = 0; 1-line display
  29. //    F = 0; 5x8 dot character font
  30. // 3. Display on/off control:
  31. //    D = 0; Display off
  32. //    C = 0; Cursor off
  33. //    B = 0; Blinking off
  34. // 4. Entry mode set:
  35. //    I/D = 1; Increment by 1
  36. //    S = 0; No shift
  37. //
  38. // Note, however, that resetting the Arduino doesn't reset the LCD, so we
  39. // can't assume that its in that state when a sketch starts (and the
  40. // LiquidCrystal constructor is called).
  41. LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows)
  42. {
  43.   _Addr = lcd_Addr;
  44.   _cols = lcd_cols;
  45.   _rows = lcd_rows;
  46.   _backlightval = LCD_NOBACKLIGHT;
  47. }
  48. void LiquidCrystal_I2C::init(){
  49.         init_priv();
  50. }
  51. void LiquidCrystal_I2C::init_priv()
  52. {
  53.         Wire.begin();
  54.         _displayfunction = LCD_4BITMODE | LCD_1LINE | LCD_5x8DOTS;
  55.         begin(_cols, _rows);
  56. }
  57. void LiquidCrystal_I2C::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
  58.         if (lines > 1) {
  59.                 _displayfunction |= LCD_2LINE;
  60.         }
  61.         _numlines = lines;
  62.         // for some 1 line displays you can select a 10 pixel high font
  63.         if ((dotsize != 0) && (lines == 1)) {
  64.                 _displayfunction |= LCD_5x10DOTS;
  65.         }
  66.         // SEE PAGE 45/46 FOR INITIALIZATION SPECIFICATION!
  67.         // according to datasheet, we need at least 40ms after power rises above 2.7V
  68.         // before sending commands. Arduino can turn on way befer 4.5V so we'll wait 50
  69.         delay(50);
  70.
  71.         // Now we pull both RS and R/W low to begin commands
  72.         expanderWrite(_backlightval);        // reset expanderand turn backlight off (Bit 8 =1)
  73.         delay(1000);
  74.           //put the LCD into 4 bit mode
  75.         // this is according to the hitachi HD44780 datasheet
  76.         // figure 24, pg 46
  77.
  78.           // we start in 8bit mode, try to set 4 bit mode
  79.    write4bits(0x03 << 4);
  80.    delayMicroseconds(4500); // wait min 4.1ms
  81.
  82.    // second try
  83.    write4bits(0x03 << 4);
  84.    delayMicroseconds(4500); // wait min 4.1ms
  85.
  86.    // third go!
  87.    write4bits(0x03 << 4);
  88.    delayMicroseconds(150);
  89.
  90.    // finally, set to 4-bit interface
  91.    write4bits(0x02 << 4);
  92.         // set # lines, font size, etc.
  93.         command(LCD_FUNCTIONSET | _displayfunction);
  94.
  95.         // turn the display on with no cursor or blinking default
  96.         _displaycontrol = LCD_DISPLAYON | LCD_CURSOROFF | LCD_BLINKOFF;
  97.         display();
  98.
  99.         // clear it off
  100.         clear();
  101.
  102.         // Initialize to default text direction (for roman languages)
  103.         _displaymode = LCD_ENTRYLEFT | LCD_ENTRYSHIFTDECREMENT;
  104.
  105.         // set the entry mode
  106.         command(LCD_ENTRYMODESET | _displaymode);
  107.
  108.         home();
  109.
  110. }
  111. /********** high level commands, for the user! */
  112. void LiquidCrystal_I2C::clear(){
  113.         command(LCD_CLEARDISPLAY);// clear display, set cursor position to zero
  114.         delayMicroseconds(2000);  // this command takes a long time!
  115. }
  116. void LiquidCrystal_I2C::home(){
  117.         command(LCD_RETURNHOME);  // set cursor position to zero
  118.         delayMicroseconds(2000);  // this command takes a long time!
  119. }
  120. void LiquidCrystal_I2C::setCursor(uint8_t col, uint8_t row){
  121.         int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
  122.         if ( row > _numlines ) {
  123.                 row = _numlines-1;    // we count rows starting w/0
  124.         }
  125.         command(LCD_SETDDRAMADDR | (col + row_offsets[row]));
  126. }
  127. // Turn the display on/off (quickly)
  128. void LiquidCrystal_I2C::noDisplay() {
  129.         _displaycontrol &= ~LCD_DISPLAYON;
  130.         command(LCD_DISPLAYCONTROL | _displaycontrol);
  131. }
  132. void LiquidCrystal_I2C::display() {
  133.         _displaycontrol |= LCD_DISPLAYON;
  134.         command(LCD_DISPLAYCONTROL | _displaycontrol);
  135. }
  136. // Turns the underline cursor on/off
  137. void LiquidCrystal_I2C::noCursor() {
  138.         _displaycontrol &= ~LCD_CURSORON;
  139.         command(LCD_DISPLAYCONTROL | _displaycontrol);
  140. }
  141. void LiquidCrystal_I2C::cursor() {
  142.         _displaycontrol |= LCD_CURSORON;
  143.         command(LCD_DISPLAYCONTROL | _displaycontrol);
  144. }
  145. // Turn on and off the blinking cursor
  146. void LiquidCrystal_I2C::noBlink() {
  147.         _displaycontrol &= ~LCD_BLINKON;
  148.         command(LCD_DISPLAYCONTROL | _displaycontrol);
  149. }
  150. void LiquidCrystal_I2C::blink() {
  151.         _displaycontrol |= LCD_BLINKON;
  152.         command(LCD_DISPLAYCONTROL | _displaycontrol);
  153. }
  154. // These commands scroll the display without changing the RAM
  155. void LiquidCrystal_I2C::scrollDisplayLeft(void) {
  156.         command(LCD_CURSORSHIFT | LCD_DISPLAYMOVE | LCD_MOVELEFT);
  157. }
  158. void LiquidCrystal_I2C::scrollDisplayRight(void) {
  159.         command(LCD_CURSORSHIFT | LCD_DISPLAYMOVE | LCD_MOVERIGHT);
  160. }
  161. // This is for text that flows Left to Right
  162. void LiquidCrystal_I2C::leftToRight(void) {
  163.         _displaymode |= LCD_ENTRYLEFT;
  164.         command(LCD_ENTRYMODESET | _displaymode);
  165. }
  166. // This is for text that flows Right to Left
  167. void LiquidCrystal_I2C::rightToLeft(void) {
  168.         _displaymode &= ~LCD_ENTRYLEFT;
  169.         command(LCD_ENTRYMODESET | _displaymode);
  170. }
  171. // This will 'right justify' text from the cursor
  172. void LiquidCrystal_I2C::autoscroll(void) {
  173.         _displaymode |= LCD_ENTRYSHIFTINCREMENT;
  174.         command(LCD_ENTRYMODESET | _displaymode);
  175. }
  176. // This will 'left justify' text from the cursor
  177. void LiquidCrystal_I2C::noAutoscroll(void) {
  178.         _displaymode &= ~LCD_ENTRYSHIFTINCREMENT;
  179.         command(LCD_ENTRYMODESET | _displaymode);
  180. }
  181. // Allows us to fill the first 8 CGRAM locations
  182. // with custom characters
  183. void LiquidCrystal_I2C::createChar(uint8_t location, uint8_t charmap[]) {
  184.         location &= 0x7; // we only have 8 locations 0-7
  185.         command(LCD_SETCGRAMADDR | (location << 3));
  186.         for (int i=0; i<8; i++) {
  187.                 write(charmap[i]);
  188.         }
  189. }
  190. // Turn the (optional) backlight off/on
  191. void LiquidCrystal_I2C::noBacklight(void) {
  192.         _backlightval=LCD_NOBACKLIGHT;
  193.         expanderWrite(0);
  194. }
  195. void LiquidCrystal_I2C::backlight(void) {
  196.         _backlightval=LCD_BACKLIGHT;
  197.         expanderWrite(0);
  198. }
  199. /*********** mid level commands, for sending data/cmds */
  200. inline void LiquidCrystal_I2C::command(uint8_t value) {
  201.         send(value, 0);
  202. }
  203. /************ low level data pushing commands **********/
  204. // write either command or data
  205. void LiquidCrystal_I2C::send(uint8_t value, uint8_t mode) {
  206.         uint8_t highnib=value&0xf0;
  207.         uint8_t lownib=(value<<4)&0xf0;
  208.        write4bits((highnib)|mode);
  209.         write4bits((lownib)|mode);
  210. }
  211. void LiquidCrystal_I2C::write4bits(uint8_t value) {
  212.         expanderWrite(value);
  213.         pulseEnable(value);
  214. }
  215. void LiquidCrystal_I2C::expanderWrite(uint8_t _data){
  216.         Wire.beginTransmission(_Addr);
  217.         printIIC((int)(_data) | _backlightval);
  218.         Wire.endTransmission();
  219. }
  220. void LiquidCrystal_I2C::pulseEnable(uint8_t _data){
  221.         expanderWrite(_data | En);        // En high
  222.         delayMicroseconds(1);                // enable pulse must be >450ns
  223.
  224.         expanderWrite(_data & ~En);        // En low
  225.         delayMicroseconds(50);                // commands need > 37us to settle
  226. }
  227. // Alias functions
  228. void LiquidCrystal_I2C::cursor_on(){
  229.         cursor();
  230. }
  231. void LiquidCrystal_I2C::cursor_off(){
  232.         noCursor();
  233. }
  234. void LiquidCrystal_I2C::blink_on(){
  235.         blink();
  236. }
  237. void LiquidCrystal_I2C::blink_off(){
  238.         noBlink();
  239. }
  240. void LiquidCrystal_I2C::load_custom_character(uint8_t char_num, uint8_t *rows){
  241.                 createChar(char_num, rows);
  242. }
  243. void LiquidCrystal_I2C::setBacklight(uint8_t new_val){
  244.         if(new_val){
  245.                 backlight();                // turn backlight on
  246.         }else{
  247.                 noBacklight();                // turn backlight off
  248.         }
  249. }
  250. void LiquidCrystal_I2C::printstr(const char c[]){
  251.         //This function is not identical to the function used for "real" I2C displays
  252.         //it's here so the user sketch doesn't have to be changed
  253.         print(c);
  254. }
  255. // unsupported API functions
  256. void LiquidCrystal_I2C::off(){}
  257. void LiquidCrystal_I2C::on(){}
  258. void LiquidCrystal_I2C::setDelay (int cmdDelay,int charDelay) {}
  259. uint8_t LiquidCrystal_I2C::status(){return 0;}
  260. uint8_t LiquidCrystal_I2C::keypad (){return 0;}
  261. uint8_t LiquidCrystal_I2C::init_bargraph(uint8_t graphtype){return 0;}
  262. void LiquidCrystal_I2C::draw_horizontal_graph(uint8_t row, uint8_t column, uint8_t len,  uint8_t pixel_col_end){}
  263. void LiquidCrystal_I2C::draw_vertical_graph(uint8_t row, uint8_t column, uint8_t len,  uint8_t pixel_row_end){}
  264. void LiquidCrystal_I2C::setContrast(uint8_t new_val){}
  265.
1602 IIC模塊資料.rar (1.15 MB, 下載次數(shù): 13)
ID:314887 發(fā)表于 2018-4-23 21:55 | 只看該作者
都是高人,
