查看: 2843|回復: 0
YL-47 DHT11 樹莓派測試源程序
  1. #!/usr/bin/python
  2. import RPi.GPIO as GPIO
  3. import time
  4. channel = 17
  5. data = []
  6. j = 0
  7. GPIO.setmode(GPIO.BCM)
  8. time.sleep(1)
  9. GPIO.setup(channel, GPIO.OUT)
  10. GPIO.output(channel, GPIO.LOW)
  11. time.sleep(0.02)
  12. GPIO.output(channel, GPIO.HIGH)
  13. GPIO.setup(channel, GPIO.IN)
  14. while GPIO.input(channel) == GPIO.LOW:
  15.     continue
  16. while GPIO.input(channel) == GPIO.HIGH:
  17.     continue
  18. while j < 40:
  19.     k = 0
  20.     while GPIO.input(channel) == GPIO.LOW:
  21.         continue
  22.
  23.     while GPIO.input(channel) == GPIO.HIGH:
  24.         k += 1
  25.         if k > 100:
  26.             break
  27.
  28.     if k < 8:
  29.         data.append(0)
  30.     else:
  31.         data.append(1)
  32.     j += 1
  33. print "sensor is working."
  34. print data
  35. humidity_bit = data[0:8]
  36. humidity_point_bit = data[8:16]
  37. temperature_bit = data[16:24]
  38. temperature_point_bit = data[24:32]
  39. check_bit = data[32:40]
  40. humidity = 0
  41. humidity_point = 0
  42. temperature = 0
  43. temperature_point = 0
  44. check = 0
  45. for i in range(8):
  46.     humidity += humidity_bit[i] * 2 ** (7 - i)
  47.     humidity_point += humidity_point_bit[i] * 2 ** (7 - i)
  48.     temperature += temperature_bit[i] * 2 ** (7 - i)
  49.     temperature_point += temperature_point_bit[i] * 2 ** (7 - i)
  50.     check += check_bit[i] * 2 ** (7 - i)
  51. tmp = humidity + humidity_point + temperature + temperature_point
  52. if check == tmp:
  53.     print "temperature : ", temperature, ", humidity : " , humidity
  54. else:
  55.     print "wrong"
  56.     print "temperature : ", temperature, ", humidity : " , humidity, " check : ", check, " tmp : ", tmp
  57. GPIO.cleanup()
DHT11測試程序.zip (235.57 KB, 下載次數: 5)
