查看: 2686|回復: 0
八路搶答器的設計
ID:312526 發表于 2018-4-20 16:57 | 顯示全部樓層 |閱讀模式
原程序
#include<reg51.h>
unsigned char dip[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
sbit KEY9=P3^1;
sbit KEY10=P3^2;
sbit BUZZ=P3^0;
bit start_key();
bit end_key();
unsigned int number_key();
void delay_20ms();
void buzz_on();
unsigned char key_number,n;
  P0=0x00;
  BUZZ=1;
  if(start_key()==1)
   key_number=number_key();
   if(key_number==0)continue;
     else P0=dip[key_number];
   while(end_key()==1)
    buzz_on();
  else{P0=0x49;
   while(end_key()==1)
    if(key_number!=0)
     P0=dip[key_number];
     for(n=0;n<150;n++)
         buzz_on();
     while(end_key()==1);
         break;
bit start_key()
{ if(KEY9==1)
return 1;
return 0;
bit end_key()
{ if(KEY10==1)
   return 1;
  delay_20ms();
if(KEY10==1)
  return 1;
  return 0;
{unsigned char key_state=0;
key_state=P1;
if(key_state==0xFF)
return 0;
if(key_state==0xfe)return 1;
else if(key_state==0xFD)return 2;
else if(key_state==0xFB)return 3;
else if(key_state==0xF7)return 4;
else if(key_state==0xEF)return 5;
else if(key_state==0xDF)return 6;
else if(key_state==0xBF)return 7;
else return 8;
void buzz_on()
{unsigned char i;
BUZZ=0;
for(i=0;i<26;i++)
   delay_20ms();
BUZZ=1;
void delay_20ms()
   unsigned int j;
   for(j=0;j<10;j++);
