單片機(jī)源程序如下:
- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define Data P0 //數(shù)據(jù)端口
- sbit RS=P2^4;
- sbit RW=P2^5;
- sbit E=P2^6;
- sbit DHT=P1^0;
- uchar FirstLine[] ="wen:00.00"; //第一行數(shù)據(jù)
- uchar SecondLine[]="shi:00.00"; //第二行數(shù)據(jù)
- unsigned char shiZ,shiX,wenZ,wenX,check;
- unsigned char tr_shiZ,tr_shiX,tr_wenZ,tr_wenX;
- unsigned char flag;
- unsigned int n=20,m;
- void delay_1ms(unsigned int i)
- unsigned int j=88;
- for(;i>0;i--)
- while(j>0)j--;
- void delay_10us()
- unsigned char i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- /*************溫濕度讀取函數(shù)***************/
- char read_data()
- unsigned char i,num,temp;
- num=0;
- for(i=0;i<8;i++)
- flag=2;
- while((!DHT)&&flag++);
- delay_10us();
- delay_10us();
- delay_10us();
- if(DHT==1)
- temp=1;
- flag=2;
- while(DHT&&flag++);
- else
- temp=0;
- num<<=1;
- num|=temp;
- return(num);
- void delay(uchar ms) // 延時(shí)函數(shù)ms毫秒
- uchar i,j;
- for(i=ms;i>0;i--)
- for(j=100;j>0;j--);
- void DelayUs(unsigned char us) //--延時(shí)函數(shù)
- unsigned char uscnt;
- uscnt=us>>1; /*12MHz頻率*/
- while(--uscnt);
- void DelayMs(unsigned char ms)
- while(--ms)
- DelayUs(250);
- DelayUs(250);
- DelayUs(250);
- DelayUs(250);
- void lcd_write_com(uchar c) //寫命令
- DelayMs(5);//操作前短暫延時(shí),保證信號(hào)穩(wěn)定
- E=0;
- RS=0;
- RW=0;
- _nop_();
- E=1;
- Data=c;
- E=0;
- void lcd_write_dat(uchar c) //寫數(shù)據(jù)
- DelayMs(5); //操作前短暫延時(shí),保證信號(hào)穩(wěn)定
- E=0;
- RS=1;
- RW=0;
- _nop_();
- E=1;
- Data=c;
- E=0;
- RS=0;
- void lcd_init() //LCD初始化
- DelayMs(15);
- lcd_write_com(0x38); //display mode
- lcd_write_com(0x06); //顯示光標(biāo)移動(dòng)位置
- lcd_write_com(0x0c); //顯示開及光標(biāo)設(shè)置
- lcd_write_com(0x01); //顯示清屏
- void ShowChar(uchar pos,uchar c) //顯示單個(gè)字符
- unsigned char p;
- if (pos>=0x10)
- p=pos+0xb0; //是第二行則命令代碼高4位為0xc
- else
- p=pos+0x80; //是第二行則命令代碼高4位為0x8
- lcd_write_com(p);//寫命令
- lcd_write_dat(c); //寫數(shù)據(jù)
- void ShowString (uchar line,char *ptr) //顯示字符串
- unsigned char l,*p;
- p=ptr;
- l=line<<4;
- while((*p)!='\0')
- ShowChar(l++,*(p));
- p++;
- void disp(void) //主函數(shù)調(diào)用的顯示函數(shù)
- ShowString(0,FirstLine);
- ShowString(1,SecondLine);
- /************初始化及采集程序**************/
- void read_init()
- DHT=0; //主機(jī)使DHT11低電平并延時(shí)至少18ms
- delay_1ms(21);
- DHT=1; //主機(jī)置DHT11高電平20~40us,并等待從機(jī)相應(yīng)
- delay_10us();
- delay_10us();
- delay_10us();
- delay_10us();
- DHT=1;
- if(!DHT) //從機(jī)發(fā)出相應(yīng)信號(hào)
- flag=2;
- flag=2;
- while(DHT&&flag++); //開始采集數(shù)據(jù)
- tr_shiZ=read_data();//采集濕度整數(shù)部分
- tr_shiX=read_data();//采集濕度小數(shù)部分
- tr_wenZ=read_data();//采集溫度整數(shù)部分
- tr_wenX=read_data();//采集溫度小數(shù)部分
- check=read_data(); //采集校驗(yàn)位
- DHT=1;
- void main()
- unsigned char temp;
- lcd_init();
- delay(50);
- while(1)
- disp();
- read_init();
- temp=tr_shiZ+tr_shiX+tr_wenZ+tr_wenX;
- if(check==temp)
- shiZ=tr_shiZ;
- shiX=tr_shiX;
- wenZ=tr_wenZ;
- wenX=tr_wenX;
- FirstLine[4]='0'+wenZ/10;
- FirstLine[5]='0'+wenZ%10;
- FirstLine[8]='0'+wenX/10;
- FirstLine[9]='0'+wenX%10;
- SecondLine[4]='0'+shiZ/10;
- SecondLine[5]='0'+shiZ%10;
- SecondLine[8]='0'+shiX/10;
- SecondLine[9]='0'+shiX%10;
以上代碼51hei提供下載:
DHT11測(cè)溫濕度程序lcd1602顯示代碼.doc
(34.5 KB, 下載次數(shù): 93)
2018-4-20 10:44 上傳
點(diǎn)擊文件名下載附件
DHT11采集信息顯示到1602上 下載積分: 黑幣 -5
