三個(gè)DS18B20的溫度采集單片機(jī)源程序如下:
- #include <reg52.h>
- #include <stdio.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit ds = P2^0;
- sbit ds2 = P2^1;
- sbit ds3 = P2^2;
- sbit Led1 = P0^4;
- sbit Led2 = P0^5;
- sbit Led3 = P0^7;
- uint temp,temp2,temp3; //整形溫度數(shù)據(jù)
- float f_temp1,f_temp2,f_temp3; //浮點(diǎn)型溫度數(shù)據(jù)
- uchar rev=0,flag_rev=0;
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- /*****DS18B20復(fù)位,初始化函數(shù)*****/
- void dsreset(void)
- uint i;
- ds = 0;
- i = 103;
- while(i>0)
- i--;
- ds = 1;
- i = 4;
- while(i>0)
- i--;
- void dsreset2(void)
- uint i;
- ds2 = 0;
- i = 103;
- while(i>0)
- i--;
- ds2 = 1;
- i = 4;
- while(i>0)
- i--;
- void dsreset3(void)
- uint i;
- ds3 = 0;
- i = 103;
- while(i>0)
- i--;
- ds3 = 1;
- i = 4;
- while(i>0)
- i--;
- /*****讀1位數(shù)據(jù)函數(shù)*****/
- bit tempreadbit(void)
- uint i;
- bit dat;
- ds = 0;
- i++;
- ds = 1;
- i++;
- i++;
- dat = ds;
- i = 8;
- while(i>0)
- i--;
- return (dat);
- bit tempreadbit2(void)
- uint i;
- bit dat;
- ds2 = 0;
- i++;
- ds2 = 1;
- i++;
- i++;
- dat = ds2;
- i = 8;
- while(i>0)
- i--;
- return (dat);
- bit tempreadbit3(void)
- uint i;
- bit dat;
- ds3 = 0;
- i++;
- ds3 = 1;
- i++;
- i++;
- dat = ds3;
- i = 8;
- while(i>0)
- i--;
- return (dat);
- /*****讀一個(gè)字節(jié)數(shù)據(jù)函數(shù)*****/
- uchar tempread(void)
- uchar i,j,dat;
- dat = 0;
- for(i=1;i<=8;i++)
- j = tempreadbit();
- dat = (j<<7)|(dat>>1);
- return (dat);
- uchar tempread2(void)
- uchar i,j,dat;
- dat = 0;
- for(i=1;i<=8;i++)
- j = tempreadbit2();
- return (dat);
- uchar tempread3(void)
- uchar i,j,dat;
- dat = 0;
- for(i=1;i<=8;i++)
- j = tempreadbit3();
- return (dat);
- /*****向DS18B20寫一個(gè)字節(jié)數(shù)據(jù)函數(shù)*****/
- void tempwritebyte(uchar dat)
- uint i;
- uchar j;
- bit testb;
- for(j=1;j<=8;j++)
- testb = dat&0x01;
- dat = dat>>1;
- if(testb)
- ds = 0;
- i++; i++;
- ds = 1;
- i = 8;
- while(i>0)
- i--;
- else
- ds = 0;
- i = 8;
- while(i>0)
- i--;
- ds = 1;
- i++; i++;
- void tempwritebyte2(uchar dat)
- uint i;
- uchar j;
- bit testb;
- for(j=1;j<=8;j++)
- testb = dat&0x01;
- dat = dat>>1;
- if(testb)
- ds2 = 0;
- i++; i++;
- ds2 = 1;
- i = 8;
- while(i>0)
- i--;
- else
- ds2 = 0;
- i = 8;
- while(i>0)
- i--;
- ds2 = 1;
- i++; i++;
- void tempwritebyte3(uchar dat)
- uint i;
- uchar j;
- bit testb;
- for(j=1;j<=8;j++)
- testb = dat&0x01;
- dat = dat>>1;
- if(testb)
- ds3 = 0;
- i++; i++;
- ds3 = 1;
- i = 8;
- while(i>0)
- i--;
- else
- ds3 = 0;
- i = 8;
- while(i>0)
- i--;
- ds3 = 1;
- i++; i++;
- void tempchange(void)
- dsreset();
- delay(1);
- tempwritebyte(0xcc); //寫跳過讀ROM指令
- tempwritebyte(0x44); //寫溫度轉(zhuǎn)換指令
- void tempchange2(void)
- dsreset2();
- delay(1);
- tempwritebyte2(0xcc); //寫跳過讀ROM指令
- tempwritebyte2(0x44); //寫溫度轉(zhuǎn)換指令
- void tempchange3(void)
- dsreset3();
- delay(1);
- tempwritebyte3(0xcc); //寫跳過讀ROM指令
- tempwritebyte3(0x44); //寫溫度轉(zhuǎn)換指令
- /*****讀取寄存器中存儲(chǔ)的溫度數(shù)據(jù)*****/
- uint get_temp()
- uchar a,b;
- dsreset();
- delay(1);
- tempwritebyte(0xbe);
- a = tempread(); //低八位
- b = tempread(); //高八位
- temp = b;
- temp<<=8;
- temp = temp|a;
- f_temp1 = temp*0.0625;
- temp = f_temp1*10+0.5;
- f_temp1 = f_temp1+0.05;
- return temp;
- uint get_temp2()
- uchar a,b;
- dsreset2();
- delay(1);
- tempwritebyte2(0xbe);
- a = tempread2(); //低八位
- b = tempread2(); //高八位
- temp2 = b;
- temp2<<=8;
- temp2 = temp2|a;
- f_temp2 = temp2*0.0625;
- temp2 = f_temp2*10+0.5;
- f_temp2 = f_temp2+0.05;
- return temp2;
- uint get_temp3()
- uchar a,b;
- dsreset3();
- delay(1);
- tempwritebyte3(0xbe);
- a = tempread3(); //低八位
- b = tempread3(); //高八位
- temp3 = b;
- temp3<<=8;
- temp3 = temp3|a;
- f_temp3 = temp3*0.0625;
- temp3 = f_temp3*10+0.5;
- f_temp3 = f_temp3+0.05;
- return temp3;
- /*****串口配置部分*****/
- void int_com(void)
- TMOD = 0X20;
- PCON = 0X00;
- SCON = 0X50;
- TH1 = 0XFd; //波特率9600
- TL1 = 0XFd;
- TR1 = 1;
- SM0 = 0;
- SM1 = 1;
- REN = 1;
- EA = 1;
- ES = 1;
- void comm(char *parr)
- do
- SBUF = *parr++; //發(fā)送數(shù)據(jù)
- while(!TI); //等待發(fā)送完成標(biāo)志為1
- TI = 0; //標(biāo)志位清0
- while(*parr); //保持循環(huán)直到字符為'\0'
- void main()
- uchar buff1[4],buff2[4],buff3[4],buffer[12];
- uint m;
- int_com();
- while(1)
- tempchange();
- tempchange2();
- tempchange3();
- get_temp(); //獲取溫度
- get_temp2();
- get_temp3();
- sprintf(buff1,"%f",f_temp1); //浮點(diǎn)型溫度格式轉(zhuǎn)換為字符型
- sprintf(buff2,"%f",f_temp2);
- sprintf(buff3,"%f",f_temp3);
- /*****數(shù)據(jù)打包處理*****/
- for(m=0;m<4;m++)
- buffer[m] = buff1[m];
- buffer[m+4] = buff2[m];
- buffer[m+8] = buff3[m];
- comm(buffer); //串口發(fā)送數(shù)據(jù)
- if(flag_rev == 1)
- ES = 0;
- switch(rev)
- case '0': Led1=1;Led2=1;Led3=1;
- break;
- case '1': Led1=0;Led2=1;Led3=1;
- break;
- case '2': Led1=1;Led2=0;Led3=1;
- break;
- case '3': Led1=1;Led2=1;Led3=0;
- break;
- case '4': Led1=0;Led2=0;Led3=1;
- break;
- case '5': Led1=1;Led2=0;Led3=0;
- break;
- case '6': Led1=1;Led2=0;Led3=1;
- break;
- case '7': Led1=0;Led2=0;Led3=0;
- break;
- ES = 1;
- flag_rev = 0;
- void ser() interrupt 4
- RI = 0;
- rev = SBUF;
- flag_rev = 1;
三點(diǎn)溫度采集及串口發(fā)送51.zip
(88.42 KB, 下載次數(shù): 37)
2018-4-18 21:02 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
