查看: 3135|回復: 0
藍橋杯單片機組第七屆省賽代碼僅供參考
ID:310661 發表于 2018-4-18 10:27 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<STC15F2K60S2.h>
#include "ds18b20.h"
        uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff,0xc6};
        uchar yi,er,san,si,wu,liu,qi,ba;
        uchar mode=1;
        uchar time=0;
        uchar tt=0;
        uint miao=0;
        bit wendu=0;
                void allinit(void);
                void display1(uchar yi,uchar er);
                void display2(uchar san,uchar si);
                void display3(uchar wu,uchar liu);
                void display4(uchar qi,uchar ba);
                void delay(uint ms);
                void keyscan(void);
          void Timer0Init(void);
        void main(void)
                allinit();
                Timer0Init();
                yi=10;er=1;san=10;si=11;wu=0;liu=0;qi=5;ba=0;
                        if(wendu==0)
                                yi=10;er=mode;san=10;si=11;wu=time/1000;liu=time%1000/100;qi=time%100/10;ba=time%10;
                        else if(wendu==1)
                                yi=10;er=4;san=10;si=11;wu=11;liu=Tempget()/10;qi=Tempget()%10;ba=12;
                        if(time>0)
                                if(mode==1)
                                        P2=0x80;P0=0xfe;
                                if(mode==2)
                                        P2=0x80;P0=0xfd;
                                if(mode==3)
                                        P2=0x80;P0=0xfb;
                        if(time==0)
                                P2=0x80;P0=0xff;
                        keyscan();
                        display1(yi,er);
                        display2(san,si);
                        display3(wu,liu);
                        display4(qi,ba);
        void allinit(void)
                P2=0xa0;
                P0=0x00;
                P2=0x80;
                P0=0xff;
                P2=0xc0;
                P0=0x01;
                P2=0xff;
                P0=tab[yi];
                delay(1);
                P2=0xc0;
                P0=0x02;
                P2=0xff;
                P0=tab[er];
                delay(1);
                P2=0xc0;
                P0=0x04;
                P2=0xff;
                P0=tab[san];
                delay(1);
                P2=0xc0;
                P0=0x08;
                P2=0xff;
                P0=tab[si];
                delay(1);
                P2=0xc0;
                P0=0x10;
                P2=0xff;
                P0=tab[wu];
                delay(1);
                P2=0xc0;
                P0=0x20;
                P2=0xff;
                P0=tab[liu];
                delay(1);
                P2=0xc0;
                P0=0x40;
                P2=0xff;
                P0=tab[qi];
                delay(1);
                P2=0xc0;
                P0=0x80;
                P2=0xff;
                P0=tab[ba];
                delay(1);
                P2=0xc0;
                P0=0xff;
                P2=0xff;
                P0=0xff;
        void delay(uint ms)
                uint i,j;
                for(i=ms;i>0;i--)
                for(j=845;j>0;j--);
        void keyscan(void)
                if(P30==0)
                        delay(5);
                        if(P30==0)
                                wendu=~wendu;
                        while(!P30);
                if(P31==0)
                        delay(5);
                        if(P31==0)
                                time=0;
                        while(!P31);
                if(P32==0)
                        delay(5);
                        if(P32==0)
                                if(time==0)time=60;
                                else if((time<=60)&&(time>0))time=120;
                                else if((time<=120)&&(time>60))time=0;
                        while(!P32);
                if(P33==0)
                        delay(5);
                        if(P33==0)
                                if(mode==1)mode=2;
                                else if(mode==2)mode=3;
                                else if(mode==3)mode=1;
                        while(!P33);
        AUXR |= 0x80;
        TMOD &= 0xF0;
        TL0 = 0xAE;
        TH0 = 0xFB;
        TF0 = 0;
        TR0 = 1;
        ET0=1;
        EA=1;
void Timer0() interrupt 1
        tt++;miao++;
        if(tt==11)tt=1;
        if(time>0)
                if(mode==1)
                        if(tt<3)P34=1;
                 else P34=0;
          else if(mode==2)
                        if(tt<4)P34=1;
           else P34=0;
          else if(mode==3)
                        if(tt<8)P34=1;
           else P34=0;
        if(miao==10000)
                if(time>0)time--;
                miao=0;
