查看: 1864|回復: 0
步進電機正反轉
ID:309169 發表于 2018-4-16 13:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
源代碼如下:
#include<reg51.h>
uchar steptabt[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};
uchar steptabf[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01};
uint freq,ftim;
uchar num,fx;
sbit key1=P2^0;
sbit key2=P2^1;
sbit key3=P2^2;
void t0isr() interrupt 1
        TH0=(65536-ftim)/256;
        TL0=(65536-ftim)%256;
        P1=steptabt[num];
        if(fx==0)
        num++;
        num%=8;
        if(num==0)num=7;
        else num--;
main()
        TMOD=0x01;
        freq=1/10;
        ftim=1000000/2/freq;
        ET0=1;
        EA=1;
        if(key1==0){fx=0;TR0=1;}
        if(key2==0){fx=1;TR0=1;}
        if(key3==0){TR0=0;}
電機.zip
55.67 KB, 下載次數: 8, 下載積分: 黑幣 -5
