查看: 3681|回復: 1
基于51單片機密碼電子鎖+protues仿真
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. uchar code table[]="Input Password:";
  5. uchar code table1[]="  Input Error!  ";
  6. uchar code table2[]="You are welcome!";
  7. uchar code table3[]="****** ";
  8. uint  yuanmima[6]={0x38,0x38,0x38,0x38,0x38,0x38};
  9. uint  inputmima[7];
  10. sbit lcdrs=P2^0;
  11. sbit lcdrw=P2^1;
  12. sbit lcden=P2^2;
  13. sbit ledred=P2^4;
  14. sbit ledgreen=P2^3;
  15. sbit dianji=P2^5;
  16. uint x,num,temp,keyscan();
  17. void delay(uint z)
  18. {
  19.   uint x,y;
  20.   for(x=0;x<z;x++)
  21.   for(y=0;y<110;y++);
  22. }
  23. void write_com(uchar com)
  24. {
  25. lcdrs=0;
  26. lcdrw=0;
  27. lcden=0;
  28. P0=com;
  29. delay(5);
  30. lcden=1;
  31. delay(5);
  32. lcden=0;
  33. }
  34. void write_data(uchar date)
  35. {
  36. lcden=0;
  37. lcdrs=1;
  38. lcdrw=0;
  39. P0=date;
  40. delay(5);
  41. lcden=1;
  42. delay(5);
  43. lcden=0;
  44. }
  45. void init()
  46. {
  47. write_com(0x38);
  48. delay(5);
  49.     write_com(0x01);
  50. delay(5);
  51. write_com(0x06);
  52. delay(5);
  53. write_com(0x0d);//0x0d 顯示光標
  54. delay(5);
  55. }
密碼電子鎖.zip (403.67 KB, 下載次數: 100)
收藏收藏3 分享淘帖 頂 踩
ID:762095 發表于 2020-8-5 22:13 | 只看該作者
按鍵好像沒有寫吧
