需要的童鞋自行下載吧 usart通訊。。。
- #include "stm32f10x.h"
- #include "GLCD.h"
- #include "USART.h"
- #include <stdio.h>
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- const char menu[] =
- "\n\r"
- "+******************** 火牛開發(fā)板 **********************+\n\r"
- "| 火牛STM32開發(fā)板試驗程序 |\n\r"
- "| USART異步通信試驗 |\n\r"
- "| 技術(shù)支持群:121939788 |\n\r"
- "+-------------------------------------------------------+\n\r";
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- void GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure IO connected to LD1, LD2, LD3 and LD4 leds *********************/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- /* Configure USART1 Tx (PA.09) as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* Configure USART1 Rx (PA.10) as input floating */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- /* Configure USART2 Tx (PA.02) as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- /* Configure USART2 Rx (PA.03) as input floating */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
- //系統(tǒng)中斷管理
- void NVIC_Configuration(void)
- /* Configure the NVIC Preemption Priority Bits */
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
- #ifdef VECT_TAB_RAM
- /* Set the Vector Table base location at 0x20000000 */
- NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
- #else /* VECT_TAB_FLASH */
- /* Set the Vector Table base location at 0x08000000 */
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- #endif
- //配置系統(tǒng)時鐘,使能各外設(shè)時鐘
- void RCC_Configuration(void)
- SystemInit();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
- |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
- |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
- |RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO
- |RCC_APB2Periph_SPI1, ENABLE );
- // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL ,ENABLE );
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4 | RCC_APB1Periph_USART2
- |RCC_APB1Periph_USART3|RCC_APB1Periph_TIM2
- , ENABLE );
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- void InitDis(void)
- /* LCD Module init */
- GLCD_init();
- GLCD_clear(White);
- GLCD_setTextColor(Blue);
- GLCD_displayStringLn(Line1, " FireBull");
- GLCD_displayStringLn(Line2, " USART example");
- GLCD_setTextColor(Red);
- //配置所有外設(shè)
- void Init_All_Periph(void)
- RCC_Configuration();
- InitDis();
- GPIO_Configuration();
- NVIC_Configuration();
- USART1_Configuration();
- USART2_Configuration();
- USART1Write((u8*)" FireBull USART_example ",sizeof(" FireBull USART_example "));
- USART2Write((u8*)" FireBull USART_example ",sizeof(" FireBull USART_example "));
- void Delay(vu32 nCount)
- for(; nCount != 0; nCount--);
- //發(fā)送開機信息
- void SendMessage(void)
- printf(menu);
- USART1Write((u8*)"Hello World! USART1_Test\n\r",sizeof("Hello World! USART1_Test\n\r")) ;
- USART2Write((u8*)"Hello World! USART2_Test\n\r",sizeof("Hello World! USART2_Test\n\r")) ;
- int main(void)
- Init_All_Periph();
- SendMessage();
- while(1)
- /* Turn on LD1 */
- GPIO_SetBits(GPIOD, GPIO_Pin_8);
- /* Insert delay */
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- /* Turn on LD2 */
- GPIO_SetBits(GPIOD, GPIO_Pin_9);
- /* Turn off LD1 */
- GPIO_ResetBits(GPIOD, GPIO_Pin_8);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- /* turn on LD3*/
- GPIO_SetBits(GPIOD, GPIO_Pin_10);
- /* Turn off LD2 */
- GPIO_ResetBits(GPIOD, GPIO_Pin_9);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- /* Turn on LD4 */
- GPIO_SetBits(GPIOD, GPIO_Pin_11);
- /* Turn off LD2 and LD3 */
- GPIO_ResetBits(GPIOD, GPIO_Pin_10);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- Delay(0xAFFFF);
- /* Turn off LD4 */
- GPIO_ResetBits(GPIOD, GPIO_Pin_11);
- * Function Name : PUTCHAR_PROTOTYPE
- * Description : Retargets the C library printf function to the USART.
- * Input : None
- * Output : None
- * Return : None
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART */
- USART_SendData(USART1, (u8) ch);
- /* Loop until the end of transmission */
- while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
- return ch;
Usart1-3.rar
(285.27 KB, 下載次數(shù): 62)
2018-4-17 04:02 上傳
下載積分: 黑幣 -5
