查看: 3787|回復: 1
STM32F4XX的HC-SR04超聲波測距源碼
STM32F4系列的超超聲波測距,型號HC-SR04,通過超聲波模塊可正常獲取距離,再進行二次開發
  1. #include "stm32f4xx.h"
  2. #include "string.h"
  3. #include "stdio.h"
  4. #include "stdlib.h"
  5. #include "delay.h"
  6. #include "sys.h"
  7. #include "beep.h"
  8. #include "key.h"
  9. #include "led.h"
  10. #include "hc_sr04.h"
  11. #include "init_usart.h"
  12. #include "bsp_ili9341_lcd.h"
  13. //#include "w25qxx.h"
  14. //#include "sdio_sdcard.h"
  15. //#include "lcd.h"
  16. //#include "malloc.h"
  17. //#include "spi.h"
  18. char buf[400] = {0};//WiFi設置接收字符串
  19. volatile uint32_t flag_buf = 0;//判斷串口傳數據是否傳完
  20. volatile uint32_t send_flag = 0;//WiFi設置命令標志位 (暫存)
  21. char rx_buf[200] = {0};//WiFi設置命令字符串
  22. uint32_t i = 0;//返回字符串計數
  23. char edit_buf[20] = {0};//接受設置是時的字符數據
  24. u32 FLASH_SIZE;
  25. //串口3發送字符串:發給wifi
  26. void wifi_set(char *pstr)
  27. {
  28.         //判斷當 前是否為NULL指針
  29.         //字符串是以'\0'(0值為結尾)
  30.         uint32_t i = 0;
  31.
  32.         while(pstr && *pstr)
  33.         {
  34.                 rx_buf[i] = *pstr;
  35.                 i++;
  36.                 USART_SendData(USART3,*pstr++);
  37.                 while(USART_GetFlagStatus(USART3,USART_FLAG_TXE)==RESET);
  38.         }
  39.         send_flag = 1;
  40. }
  41. uint64_t wifi_all_set(uint64_t flag_buf)
  42. {
  43.         if(flag_buf)
  44.                 {
  45.                         printf("run here1\r\n");
  46.                         if(strstr(rx_buf,"AT+CWMODE=2") != NULL && strstr(buf,"OK") != NULL)
  47.                         {
  48.                                 wifi_set("AT+RST\r\n");//重啟是設置生效
  49.                                 delay_ms(666);
  50.                                 delay_ms(666);
  51.                                 delay_ms(666);
  52.                                 delay_ms(666);
  53.                                 //wifi_set("AT+CWSAP="TEST","123456123456",1,3");//設置wifi為多連接模式
  54.
  55.                                 wifi_set("AT+CIPMUX=1\r\n");//設置wifi為多連接模式
  56.                                 delay_ms(666);
  57.                                 delay_ms(666);
  58.                                 delay_ms(666);
  59.                                 wifi_set("AT+CIPSERVER=1,6666\r\n");//設置為服務器,端口號為6666
  60.                                 delay_ms(666);
  61.                                 delay_ms(666);
  62.                                 delay_ms(666);
  63.                                 wifi_set("AT+CIPSTO=6000\r\n");//設置超時時間
  64.                                 delay_ms(666);
  65.                                 delay_ms(666);
  66.                                 delay_ms(666);
  67.                         }
  68.                 }
  69.                 else
  70.                         return 1;
  71.
  72.                 flag_buf = 0;
  73.                 delay_ms(666);
  74.                 delay_ms(666);
  75.                 delay_ms(666);
  76.         return 0;
  77. }
  78. //int main(void)
  79. //{
  80. //        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); // 中斷優先級分組管理
  81. //
  82. //        Systick_Init();//延時初始化時鐘
  83. //        usart_init(115200);//串口1初始化
  84. //        USART3_Init(115200);//串口3初始化
  85. //        KEY_Init();
  86. //        key_init1();
  87. //        LED_Init();
  88. //        exit_init();
  89. //        Beep_init();
  90. //        printf("run here\r\n");
  91. //
  92. //        wifi_set("AT+CWMODE=2\r\n");//設置wifi為模式3,sta與AP共存
  93. //        delay_ms(666);
  94. //        wifi_all_set(flag_buf);//進入中斷函數后,當串口3接收完數據,flag_buf = 1
  95. //
  96. //
  97. //        //delay_ms(666);
  98. //        //delay_ms(666);
  99. //        //delay_ms(666);
  100. //        //delay_ms(666);
  101. //
  102. //                while(1)
  103. //                {
  104. //                        if(PEin(3) == 0)//KEY1
  105. //                        {
  106. //                                PAout(6) = 0;//LED2
  107. //                                delay_ms(500);
  108. //                                PAout(6) = 1;//LED2
  109. //
  110. //                                PBout(0) = 1;
  111. //                                delay_ms(500);
  112. //
  113. //                                printf("=====\r\n");
  114. //                        }
  115. //                        delay_ms(500);
  116. //                        printf("=====1111\r\n");
  117. //                }
  118. //        //return 0;
  119. //}
  120. void USART1_IRQHandler(void)                                                //串口1中斷服務程序
  121. {
  122.         uint8_t d;
  123.         if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)          //接收中斷
  124.         {
  125.                 //接收數據
  126.                 d = USART_ReceiveData(USART1);        //讀一個發一個
  127.
  128.                 USART_SendData(USART3,d);
  129.         }
  130. }
  131. void USART3_IRQHandler(void)                                                //串口3中斷服務程序
  132. {
  133.         uint8_t d;
  134.
  135.         if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)          //接收中斷
  136.         {
  137.                 //接收數據
  138.                 d = USART_ReceiveData(USART3);
  139.
  140.
  141.                 buf[i++] = d;
  142.                 if(buf[i-2] == 0x0D && buf[i-1] == 0x0A)//判斷字符串是否接收完畢
  143.                 {
  144.                         i = 0;
  145.                         flag_buf = 1;
  146.
  147.                 }
  148.                 if(i >= 300)//判斷字符串是否是自己需要的
  149.                 {
  150.                         i = 0;
  151.                         memset(buf,0,sizeof(buf));
  152.                 }
  153.                 //printf("%d = s\r\n",d);
  154.                 //轉發給PC顯示
  155.                 USART_SendData(USART1,d);
  156.
  157.                 while(USART_GetFlagStatus(USART3,USART_FLAG_TXE)==RESET);
  158.         }
  159. }
  160. int main(void)
  161. {
  162.         int n;
  163.
  164.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置系統中斷優先級分組2
  165.
  166.         Systick_Init();//延時延時函數
  167.         usart_init(115200);//串口1初始化
  168.         USART3_Init(115200);//串口3初始化
  169.         KEY_Init();                //初始化串口波特率為115200
  170.         key_init1();                                        //初始化LED
  171.         //LED_Init();                         //LCD初始化
  172.         exit_init();                         //按鍵初始化
  173.
  174.         init_sr04();
  175.         printf("1234r\n");
  176.
  177.         while(1)
  178.         {
  179.                 printf("F====\r\n");
  180.                 n = get_sr04_distance()/10;
  181.                 //printf("HGFHGHGFHFHGGF====\r\n");
  182.                 printf("distace = %d cm\r\n",n);
  183.                 delay_s(1);
  184.         }
  185. }
sr04.rar (101.94 KB, 下載次數: 69)
ID:315667 發表于 2018-4-25 15:56 | 只看該作者
下載鏈接失效了,可以再發一次嗎 謝謝!
