查看: 12193|回復: 10
PIC16F1947單片機做的NTC熱敏電阻溫控器原理圖及源程序
PIC16F1947做的溫控器及程序
電路原理圖如下:
  1. #include "mydefine.h"
  2. #include "pic.h"
  3. #include "mTouch.h"
  4. #include "GLOBAL.H"
  5. #include "DEFINE.H"
  6. #include "XWKQ_KeyScan.H"
  7.                      // Required Include
  8. // CONFIGURATION SETTINGS
  9. #include "generic_processorConfigBits.h"        // Provided for ease-of-development.
  10. // PROTOTYPES
  11. void Example_System_Init (void);
  12. extern void interrupt  ISR      (void);
  13. extern unsigned char auto_exit;
  14. extern void  working_mode ();
  15. extern void inplement();
  16. extern void FAN_CONTROL();
  17. extern volatile int SET_TEMPER10;
  18. void key_press(void);
  19. void key_exit(void);
  20. extern  void LCD_disp(unsigned int data_in );
  21. extern void UpdateLCD(void);
  22. #define uchar unsigned char
  23. #define uint unsigned int
  24. //volatile uchar  tflag;
  25. bit ON_OFF;   //MENU  ON/OFF button
  26. bit   POWER_ON_FIRST;   //1 ,POWER ON   FIRST TIME;
  27. //EEPROM DATA
  28.   int SET_TEMPER; //SETTING TEMPERATURE
  29. volatile bit  SET_DATA;   //change the temperature or other data
  30. unsigned char FAN_SPEED;  // 0:AUTO, 1:LOW, 2:MED, 3:HIGH
  31. unsigned char BACKLIGHT_LEVE;
  32. //unsigned char PIPLE4_AUTO;
  33. volatile unsigned   char MODE; //mode :  1:COOLING,  2:HEATING
  34.
  35. extern volatile unsigned char  piple_num;
  36. bit  OK;  // KEY OK
  37. unsigned char SYSTEM_SETUP;   //1: TEMPERATURE FINE  2: FAN  BE CONTROLED
  38. volatile signed char TEMP_FINE;     // CORRECT THE TEMPERATURE
  39. volatile   unsigned char   FAN_BECONTROL;
  40. bit  FAN_DELAY;
  41. unsigned long FAN_DELAYTIME;
  42. extern  bit FAN_DELAY_OFF;
  43. unsigned char SET_TIME=0;
  44. unsigned long TIME_ONOFF=0;  // TIMING FOR ON OR OFF;
  45. unsigned long TIME_ONOFF_BACKUP=0;
  46. volatile   bit  TIMING;   //CHINESE TIMING SIGN 0:OFF   1: ON
  47. volatile  bit TIME_COUNT;   //0:DISABLE 1:ENABLE
  48. volatile bit  TIME_EDIT;
  49. volatile  bit TIME_ON;      // FROM OFF TO WOROK
  50. extern bit mode_inverter;
  51. extern bit  downup;
  52. extern unsigned char FAN_STATUS;
  53. extern void ClearLCD(void);
  54. extern void KeyControl(void);
  55. extern void KeyScan(void);
  56. // START PROGRAM
  57. void main(void)
  58. {
  59.      OK=1;
  60.      POWER_ON_FIRST=1;
  61.     TIMING=0;  //*****/
  62.     TIME_COUNT=0;
  63.     TIME_EDIT=0;
  64.     TIME_ON=0;
  65.     SYSTEM_SETUP=0;
  66.      FAN_DELAYTIME=0;
  67.
  68.      FAN_DELAY_OFF=1;    // avoid low fan switch be turn on  when power on  at firest time (heating=0  && cooling=0)
  69.      FAN_DELAY=1;      // avoid low fan switch be turn on  when power on  at firest time (heating=0  && cooling=0)
  70.
  71.
  72.
  73.    SET_DATA=0;
  74.    SET_TIME=0;
  75.     Example_System_Init();          // Your System Initialization Function
  76.
  77.
  78.
  79.     mTouch_Init();                  // mTouch Initialization (Required)
  80.
  81.         PEIE = 1;
  82.     GIE = 1;                                     // Initialization complete. Begin servicing interrupts.
  83.
  84.         WDTPS3 = 1;
  85.         SWDTEN = 1;                                                // enable WDT
  86.      INTCON=0b11100000;
  87.      PIR1=0b00000000;
  88.     TMR1H=0x3c;
  89.     TMR1L=0xaf;
  90.     T1CON=0b00110001;  //  16M internal clock
  91.     T1GVAL=0;
  92.
  93.     PORTA       = 0x00;
  94.     PORTB       = 0X00;
  95.     PORTC       = 0x00;
  96.     PORTD       = 0X00;
  97.     PORTE       = 0X00;
  98.     PORTF       = 0X00;
  99.     PORTG       = 0X00;
  100.     LATF=0;
  101.
  102.     ANSELA      =0b00001111;
  103.     ANSELE      =0b00000000;
  104.     ANSELF      =0b00011111;
  105.     ANSELG      =0b00000000;
  106.
  107.     TRISA       =0b00001001;
  108.     TRISB       =0b00000001;
  109.     TRISC       =0b10000000;
  110.     TRISD       =0b00000000;
  111.     TRISE       =0b00000000;
  112.     TRISF       =0b10000000;
  113.     TRISG       =0b00000010;
  114.
  115.
  116.     RG2=0;
  117.
  118.
  119.
  120.
  121.          LCDSE0 = 0xFF;        // enable first group of LCD segment outputs
  122.         LCDSE1 = 0x3F;        // enable second group of LCD segments
  123.         LCDSE2 = 0x00;        // enable third group of LCD segments
  124.         LCDSE3 = 0x00;
  125.         LCDSE4 = 0x00;
  126.         LCDSE5 = 0x00;
  127.     LCDCON = 0b10001011;
  128.         LCDREF = 0b10000000;
  129.     LCDPS   = 0b00110011;
  130.         LCDCST = 0b00000000;
  131.         LCDRL = 0b11110000;
  132.
  133.
  134.
  135.     LCDDATA0=0X00;
  136.     LCDDATA1=0X00;
  137.     LCDDATA3=0X00;
  138.      LCDDATA4=0X00;
  139.      LCDDATA6=0X00;
  140.      LCDDATA7=0X00;
  141.      LCDDATA9=0X00;
  142.      LCDDATA10=0X00;
  143.
  144.     ClearLCD();
  145.
  146.
  147.
  148.
  149.     __delay_us(100);
  150.      CLRWDT();
  151.      MODE=EEPROM_READ(0x00);
  152.      if (MODE==0XFF) {MODE=1;}
  153.      SET_TEMPER=EEPROM_READ(0x01);
  154.      if (SET_TEMPER==0XFF) {SET_TEMPER=25;}
  155.      FAN_SPEED=EEPROM_READ(0X02);
  156.      if (FAN_SPEED==0XFF)  {FAN_SPEED=1;}
  157.      BACKLIGHT_LEVE=EEPROM_READ(0X03);
  158.      if (BACKLIGHT_LEVE==0XFF) {BACKLIGHT_LEVE=0;}
  159.
  160.       //CCPR3L=LIGHT_OFF;
  161.
  162.
  163.      //LIGHT_ON=0;
  164.
  165.
  166. // PIPLE4_AUTO=EEPROM_READ(0X04);
  167. // if (PIPLE4_AUTO==0XFF)  {PIPLE4_AUTO=0;}
  168.      _nop();
  169.      _nop();
  170.
  171.      TEMP_FINE=EEPROM_READ(0X05);
  172.      FAN_BECONTROL=EEPROM_READ(0X06);
  173.     if (FAN_BECONTROL==0XFF)  {FAN_BECONTROL=0;}
  174.
  175.    _nop();
  176.    _nop();
  177.    _nop();
  178.    _nop();
  179.    _nop();
  180.    _nop();
  181.     if (PIPLE_QTY==0)    {piple_num=4;}else {  piple_num=2; }
  182.
  183.    __delay_ms(100);
  184.
  185.
  186.
  187.     while(1)
  188.     {
  189.
  190.           CLRWDT();
  191.
  192.
  193.          if (SET_TIME !=0  &&  TIMING==1  &&TIME_COUNT==1&& OK==1 )
  194.          {
  195.               COOLING=0;
  196.               HEATING=0;
  197.               if (LOW==1)     {CLRWDT(); __delay_ms(10);LOW=0;}
  198.               if (MED==1)     {CLRWDT(); __delay_ms(10);MED=0;}
  199.               if (HIGH==1)    {CLRWDT(); __delay_ms(10);HIGH=0;}
  200.             //  CCPR3L=LIGHT_OFF;
  201.               LIGHT_ON=0;
  202.               TIME_ON=1;
  203.
  204.          }else
  205.             {
  206.                  TIME_ON=0;
  207.
  208.
  209.                    if ( SET_TIME==0  && TIMING==0 &&TIME_COUNT==1 && OK==1)
  210.                    {
  211.                         ON_OFF=0;
  212.
  213.                      //   CCPR3L=LIGHT_OFF;
  214.
  215.
  216.                LIGHT_ON=0;
  217.
  218.                     }else
  219.                        {
  220.
  221.                               _nop();
  222.                                if ( ON_OFF==1)
  223.                                {
  224.
  225.                                      inplement();
  226.                                      FAN_CONTROL();
  227.
  228.
  229.
  230.                                 }
  231.
  232.                       }
  233.
  234.
  235.                                           if  (ON_OFF==0)
  236.
  237.                                         {
  238.                                               COOLING=0;
  239.                                               HEATING=0;
  240.
  241.                                              FAN_CONTROL();
  242.
  243.                                             }
  244.
  245.                  }
  246.
  247.
  248.
  249.                                KeyValueBuf=0;
  250.                               KeyControl();
  251.
  252.
  253.
  254.
  255.
  256.            if (  auto_exit>=100 && OK==1 &&   LIGHT_ON==1)
  257.            {
  258.                LIGHT_ON=0;
  259.            }
  260.
  261.
  262.               if (  auto_exit>=100 && OK==0) //OVERTIME
  263.               {
  264.
  265.               //    MENU_BAR=0;  //RESET THE MENU BAR TO DEFAULT BAR 0;
  266.
  267.                   OK=1;        //RESET TO DEFAULT
  268.                   TIME_ONOFF_BACKUP=0; // EXIT MENU BEGINING TO COUNT
  269.
  270.                   TIME_EDIT=0;
  271.                     if (TIME_COUNT==1 && SET_TIME==0)   { TIME_COUNT=0;TIMING=0;}
  272.                   working_mode ();
  273.
  274.                   SYSTEM_SETUP=0;
  275.
  276.                  }
  277.
  278.
  279.         CLRWDT();
  280.      } // end - while(1) main loop
  281.
  282. } // end - main() function
  283. /*        Initial the system */
  284. void Example_System_Init()
  285. {
  286.     // The mTouch framework controls these modules:
  287.     // *  TMR0  - YOU MUST INIT THE OPTION REGISTER / TMR0 PRESCALER
  288.     //            Do not choose 1:1 prescaling.
  289.     //
  290.     // *  ADC   - automatic initialization
  291.     // *  UART  - automatic initialization (if enabled and available)
  292.     //
  293.     // mTouch performs better as Fosc increases.
  294.
  295.     // NOTE: Update the configuration file if Fosc is changed!
  296.
  297.
  298.
  299. ……………………
  300. …………限于本文篇幅 余下代碼請從51黑下載附件…………
K9-WKQ.7z (432.35 KB, 下載次數: 172)
MCU-SI1102 調整亮度后.pdf (1.08 MB, 下載次數: 122)
收藏收藏4 分享淘帖 頂 踩
ID:273583 發表于 2018-8-12 09:13 | 只看該作者
很好 ,很有用,很不錯!
ID:555335 發表于 2019-7-14 11:19 | 只看該作者
感謝分享
ID:572137 發表于 2019-7-21 08:03 來自觸屏版 | 只看該作者
謝謝樓主無私奉獻
ID:202586 發表于 2019-7-25 19:46 來自觸屏版 | 只看該作者
剛好想研究溫控,謝謝樓主分享
ID:249808 發表于 2019-8-10 09:26 | 只看該作者
感謝分享!大概看了一下!后面有時間再慢慢研究……
ID:410928 發表于 2019-9-20 10:31 | 只看該作者
我想用紅外溫度傳感器,根單片幾做一個,溫度控制起,溫度可調,帶LED屏,好做嗎?
ID:216265 發表于 2021-6-28 06:27 | 只看該作者
我試試,PIC單片機不常用呢
ID:959830 發表于 2021-8-29 23:18 | 只看該作者
謝謝樓主分享,希望可以試試看
ID:582276 發表于 2021-9-1 22:08 | 只看該作者
謝謝分享,參考看能不能得到幫助。
ID:959830 發表于 2021-12-17 21:33 | 只看該作者
謝謝分享,參考看能不能得到幫助。
