51控制多路舵機
- #include <reg52.h> //包含單片機寄存器的頭文件
- #define uchar unsigned char
- #define uint unsigned int
- P0M1=0X00;
- P0M0=0XFF;//設置P0 為強推挽輸出
- sbit servo0=P0^0;
- sbit servo1=P0^1;
- sbit servo2=P0^2;
- sbit servo3=P0^3;
- sbit servo4=P0^4;
- sbit servo5=P0^5;
- sbit servo6=P0^6;
- sbit servo7=P0^7;
- uchar serVal[2];
- uint pwm[]={1382,1382,1382,1382,1382,1382,1382,1382}; //初始90度,(實際是1382.4,取整得1382)
- uchar pwm_flag=0;
- uint code ms0_5Con=461; //0.5ms計數 (實際是460.8,取整得461)
- uint code ms2_5Con=2304; //2.5ms計數
- * 功能 : 串口初始化,晶振11.0592,波特率9600,使能了串口中斷
- void Com_Init()
- TMOD |= 0x20; //用定時器設置串口波特率
- TH1=0xFD; //256-11059200/(32*12*9600)=253 (FD)
- TL1=0xFD;//同上
- TR1=1;//定時器1開關打開
- REN=1; //開啟允許串行接收位
- SM0=0;//串口方式,8位數據
- SM1=1;//同上
- EA=1; //開啟總中斷
- ES=1; //串行口中斷允許位
- * 功能 : 舵機PWM中斷初始化
- void Timer0Init()
- //0度=0.5ms, 45度=1ms, 90度=1.5ms, 135度=2ms, 180度=2.5ms
- //2.5 ms初始值 F700, (12n/11059200=2.5/1000, n=2304, X=65536-2304=63232 > F700)
- TMOD |= 0x01; //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
- TH0=-ms2_5Con>>8; //給定初值,17ms中斷
- TL0=-ms2_5Con;
- EA=1; //總中斷打開
- ET0=1; //定時器0中斷打開
- TR0=1; //定時器0開關打開
- * 功能 : 舵機PWM中斷, //舵機控制函數 周期為20ms 一個循環20MS = 8*2.5ms
- void SteeringGear() interrupt 1
- switch(pwm_flag)
- case 1: servo0=1; TH0=-pwm[0]>>8; TL0=-pwm[0]; break;
- case 2: servo0=0; TH0=-(ms2_5Con-pwm[0])>>8; TL0=-(ms2_5Con-pwm[0]); break;
- case 3: servo1=1; TH0=-pwm[1]>>8; TL0=-pwm[1]; break;
- case 4: servo1=0; TH0=-(ms2_5Con-pwm[1])>>8; TL0=-(ms2_5Con-pwm[1]); break;
- case 5: servo2=1; TH0=-pwm[2]>>8; TL0=-pwm[2]; break;
- case 6: servo2=0; TH0=-(ms2_5Con-pwm[2])>>8; TL0=-(ms2_5Con-pwm[2]); break;
- case 7: servo3=1; TH0=-pwm[3]>>8; TL0=-pwm[3]; break;
- case 8: servo3=0; TH0=-(ms2_5Con-pwm[3])>>8; TL0=-(ms2_5Con-pwm[3]); break;
- case 9: servo4=1; TH0=-pwm[4]>>8; TL0=-pwm[4]; break;
- case 10: servo4=0; TH0=-(ms2_5Con-pwm[4])>>8; TL0=-(ms2_5Con-pwm[4]); break;
- case 11: servo5=1; TH0=-pwm[5]>>8; TL0=-pwm[5]; break;
- case 12: servo5=0; TH0=-(ms2_5Con-pwm[5])>>8; TL0=-(ms2_5Con-pwm[5]); break;
- case 13: servo6=1;TH0=-pwm[6]>>8; TL0=-pwm[6]; break;
- case 14: servo6=0;TH0=-(ms2_5Con-pwm[6])>>8; TL0=-(ms2_5Con-pwm[6]); break;
- case 15: servo7=1;TH0=-pwm[7]>>8; TL0=-pwm[7]; break;
- case 16: servo7=0;TH0=-(ms2_5Con-pwm[7])>>8; TL0=-(ms2_5Con-pwm[7]); break;
- default: TH0=0xff; TL0=0x80; pwm_flag=0;
- pwm_flag++;
- void SetSteeringGear(uchar i, uchar val)
- uint a = (val+46)*10;
- if(a<ms0_5Con)
- a=ms0_5Con;
- if(a>ms2_5Con)
- a=ms2_5Con;
- pwm[i]=a;
- serVal[0]=255; //清除緩存
- void SteeringGearUp(uchar i)
- if(pwm[i]>ms0_5Con)
- pwm[i]=pwm[i]-10;
- void SteeringGearDown(uchar i)
- if(pwm[i]<ms2_5Con)
- pwm[i]=pwm[i]+10;
- * 功能 : 串口中斷接收數據
- void ser() interrupt 4
- serVal[0]=serVal[1];
- serVal[1]=SBUF;
- RI=0;//串口中斷清0
- ** 函數功能 : 主函數
- void main()
- bit started=0; //路由是否已經啟動完畢
- Com_Init();//串口初始化
- Timer0Init();//舵機初始化
- while(1)
- if(serVal[0]=='w' && serVal[1]=='d'){
- started=1; //路由啟動最后會出現:ar71xx-wdt,由此判斷路由已經啟動
- if(started)
- if(serVal[0]==0){
- switch(serVal[1])
- case 'A': SteeringGearUp(0); break;
- case 'B': SteeringGearDown(0); break;
- case 'C': SteeringGearUp(1); break;
- case 'D': SteeringGearDown(1); break;
- case 'E': SteeringGearUp(2); break;
- case 'F': SteeringGearDown(2); break;
- case 'G': SteeringGearUp(3); break;
- case 'H': SteeringGearDown(3); break;
- case 'I': SteeringGearUp(4); break;
- case 'J': SteeringGearDown(4); break;
- case 'K': SteeringGearUp(5); break;
- case 'L': SteeringGearDown(5); break;
- default:break;
- }else if(serVal[0]==1){
- SetSteeringGear(0,serVal[1]);
- }else if(serVal[0]==2){
- SetSteeringGear(1,serVal[1]);
- }else if(serVal[0]==3){
- SetSteeringGear(2,serVal[1]);
- }else if(serVal[0]==4){
- SetSteeringGear(3,serVal[1]);
- }else if(serVal[0]==5){
- SetSteeringGear(4,serVal[1]);
- }else if(serVal[0]==6){
- SetSteeringGear(5,serVal[1]);
51單片機超高精度6路舵機控制程序-087b81f04afe04a1b071de51.doc
(41 KB, 下載次數: 53)
2018-4-6 22:29 上傳
下載積分: 黑幣 -5
