查看: 8144|回復: 3
單片機LCD1602顯示年月日時鐘帶星期和鬧鐘
ID:36963 發表于 2018-4-6 15:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
長春工業大學
測控技術與儀器專業
單片機LCD1602顯示年月日時鐘帶星期和鬧鐘,可識別閏年
下載文檔即可完全復制
#include <reg52.h>
sbit lcdrs  =P0^7;     //液晶引腳定義
sbit led_cs = P0^6;
sbit lcden  =P0^5;
sbit boom   =P3^6;
sbit key1 = P3^5;
sbit key2 = P3^4;
sbit key3 = P3^3;
sbit keyE = P3^2;
ucharnum,key1num,key2num,count,hour,min,sec,day,mon,year,shi,fen,miao,week;
char  ye1,ye2;
uchar code cg_1602[]={0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00,
0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,};//"年月日"
/*延時函數*/
void delay(uint xms)
       uint i,j;
       for(i=xms;i>0;i--)
       for(j=114;j>0;j--);
/*1602液晶*/
void write_com(uchar com)//寫命令
       lcdrs=0;
       lcden=0;
       P0=com;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
void write_data(uchar date)//寫數據
       lcdrs=1;
       lcden=0;
       P0=date;
       delay(5);
       lcden=1;
       delay(5);
       lcden=0;
void write_by_xy(uchar x,uchar y)//坐標定位
       ucharaddress;
       if(y==0)
       address=0x80+x;//y=0,寫第一行
       address=0xc0+x;//y=1,寫第二行
       write_com(address);
/*void write_char(uchar x,uchar y,uchar date)//坐標定位顯示
       write_by_xy(x,y);//先定位
       write_data(date);//后寫數
void write_string(uchar x,uchar y,uchar *s)//寫字符串
       write_by_xy(x,y);//設定顯示位置
       while(*s)//writecharacter
       P0=*s;
       write_data(*s);
       s++;
void write_sfm(uchar add,uchar date)//寫時分秒函數
       ucharhour,ge;
       hour=date/10;//分解一個2位數的十位和個位
       ge=date%10;
       write_com(0x80+add);//設置顯示位置
       write_data(0x30+hour);//送去液晶顯示十位
       write_data(0x30+ge);//送去液晶顯示個位
void write_cg()//寫入固定漢字和符號
       write_com(0x40);//設定CGRAM地址
       for(num=0;num<24;num++)//將自定義字型碼寫入CGRAM
              write_data(cg_1602[num]);
       write_com(0xc4);//
              write_data(0);
       write_com(0xc7);//
              write_data(1);
       write_com(0xca);//
              write_data(2);
       write_string(2,0,":");
       write_string(5,0,":");
       write_string(0x0a,0,":");
       write_string(0x0d,0,":");
       write_string(0x0c,1,"W");
       write_string(0x0d,1,"K");
void init_1602()//初始化
       led_cs=0;
hour=23;min=59;sec=55;key1num=0;count=0;day=28;mon=2;ye1=20;ye2=13;year=ye1*100+ye2;boom=0;shi=0;fen=0;miao=0;week=7;
       write_com(0x38);
       write_com(0x0c);
       write_com(0x06);
       write_com(0x01);
       write_string(0,1,"2013");
       write_string(5,1,"02");
       write_string(8,1,"28");
       write_sfm(8,shi);
       write_sfm(0x0b,fen);
       write_sfm(0x0e,miao);
       write_sfm(0,hour);
       write_sfm(3,min);
       write_sfm(6,sec);
       write_sfm(0x48,day);
       write_sfm(0x45,mon);
       write_sfm(0x40,ye1);
       write_sfm(0x42,ye2);
       write_sfm(0x4e,week);
       write_cg();
       TMOD=0x01;//設置定時器0工作模式1
       TH0=(65536-50000)/256;//定時器裝初值
       TL0=(65536-50000)%256;
       EA=1; //開總中斷
       ET0=1; //開定時器0中斷
       TR0=1; //啟動定時器0
/*鍵盤掃描函數*/
void keyscan()//按鍵掃描函數
       //keyE =0;
       if(key1==0)
              delay(5);
              if(key1==0)//確認功能鍵被按下
                     key1num++;//功能鍵按下次數記錄
                     while(!key1);//釋放確認
                     if(key1num==1)//第一次被按下時
                            TR0=0;//關閉定時器
                            write_com(0x80+7);//光標定位到秒位置
                            write_com(0x0f);//光標開始閃爍
                     if(key1num==2)//第二次按下光標閃爍定位到分鐘位置
                            write_com(0x80+4);
                     if(key1num==3)//第三次按下光標閃爍定位到小時位置
                            write_com(0x80+1);
                     if(key1num==4)//第四次按下光標閃爍定位到日位置
                            write_com(0x80+0x49);
                     if(key1num==5)//第五次按下光標閃爍定位到月位置
                            write_com(0x80+0x46);
                     if(key1num==6)//第六次按下光標閃爍定位到年2位置
                            write_com(0x80+0x43);
                     if(key1num==7)//第七次按下光標閃爍定位到年1位置
                            write_com(0x80+0x41);
                     if(key1num==8)//第八次按下光標閃爍定位到星期位置
                            write_com(0x80+0x4f);
                     if(key1num==9)//第九次按下
                            key1num=0;//記錄按鍵數清零
                            write_com(0x0c);//取消光標閃爍
                            TR0=1;//啟動定時器使時鐘開始走
       if(key1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
              if(key2==0)
                     delay(5);
                     if(key2==0)//增加鍵確認被按下
                            while(!key2);//按鍵釋放
                            if(key1num==1)//若功能鍵第一次按下
                                   sec++;//則調整秒加1
                                   if(sec==60)//若滿60后將清零
                                   sec=0;
                                   write_sfm(6,sec);//每調節一次送液晶顯示一下
                                   write_com(0x80+7);//顯示位置重新回到調節處
                            if(key1num==2)//若功能鍵第二次按下
                                   min++;//則調整分鐘加1
                                   if(min==60)//若滿60后將清零
                                   min=0;
                                   write_sfm(3,min);//每調節一次送液晶顯示一下
                                   write_com(0x80+4);//顯示位置重新回到調節處
                            if(key1num==3)//若功能鍵第三次按下
                                   hour++;//則調整小時加1
                                   if(hour==24)//若滿24后將清零
                                   hour=0;
                                   write_sfm(0,hour);;//每調節一次送液晶顯示一下
                                   write_com(0x80+1);//顯示位置重新回到調節處
                            if(key1num==4)//若功能鍵第四次按下
                                   day++;//則調整日加1
                                   if(day>31)//若大于31后將置一
                                   day=1;
                                   write_sfm(0x48,day);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x48);//顯示位置重新回到調節處
                            if(key1num==5)//若功能鍵第五次按下
                                   mon++;//則調整月加1
                                   if(mon>12)//若大于12后將置一
                                   mon=1;
                                   write_sfm(0x45,mon);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x45);//顯示位置重新回到調節處
                            if(key1num==6)//若功能鍵第六次按下
                                   ye2++;//則調整年加1
                                   if(ye2==0x0a)//若滿99后將清零
                                   ye2=0;
                                   year=ye1*100+ye2;
                                   write_sfm(0x42,ye2);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x42);//顯示位置重新回到調節處
                            if(key1num==7)//若功能鍵第七次按下
                                   ye1++;//則調整年加100
                                   if(ye1==0x0a)//若滿99后將清零
                                   ye1=0;
                                   year=ye1*100+ye2;
                                   write_sfm(0x40,ye1);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x40);//顯示位置重新回到調節處
                            if(key1num==8)//若功能鍵第八次按下
                                   week++;//則調整周加一
                                   if(week>7)//若大于7后置一
                                   week=1;
                                   write_sfm(0x4f,week);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x4f);//顯示位置重新回到調節處
              if(key3==0)
                     delay(5);
                     if(key3==0)//確認減小鍵被按下
                            while(!key3);//按鍵釋放
                                   sec--;//則調整秒減1
                                   if(sec==-1)//若減到負數則將其重新設置為59
                                          sec=59;
                                   min--;//則調整分鐘減1
                                   if(min==-1)//若減到負數則將其重新設置為59
                                          min=59;
                                   hour--;//則調整小時減1
                                   if(hour==-1)//若減到負數則將其重新設置為23
                                          hour=23;
                                   write_sfm(0,hour);//每調節一次送液晶顯示一下
                                   day--;//則調整日減1
                                   if(day==0)//若日為零時將置一
                                   day=31;
                                   write_com(0x80+0x49);//顯示位置重新回到調節處
                                   mon--;//則調整月減1
                                   if(mon==0)//若月為零將置一
                                   mon=12;
                                   ye2--;//則調整年減1
                                   if(ye2<0)//若小于零后將設置為99
                                   ye2=99;
                                   year=ye1*100+ye2;
                                   ye1--;//則調整年減100
                                   if(ye1<0)//若小于零后將設置為99
                                   ye1=99;
                                   year=ye1*100+ye2;
                                   week--;//則調整周減一
                                   if(week==0)//若等于0后將置7
                                   week=7;
       if(keyE==0)
              delay(5);
              if(keyE==0)//確認功能鍵被按下
                     key2num++;//功能鍵按下次數記錄
                     while(!keyE);//釋放確認
                     if(key2num==1)//第一次被按下時
                            TR0=0;//關閉定時器
                            write_com(0x80+0x0f);//光標定位到秒位置
                     if(key2num==2)//第二次按下光標閃爍定位到分鐘位置
                            write_com(0x80+0x0c);
                     if(key2num==3)//第三次按下光標閃爍定位到小時位置
                            write_com(0x80+9);
                     if(key2num==4)//第八次按下
                            key2num=0;//記錄按鍵數清零
                            TR0=1;//啟動定時器使時鐘開始走
              if(key2num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
              if(key2==0)
                     delay(5);
                            while(!key2);//按鍵釋放
                            if(key2num==1)//若功能鍵第一次按下
                                   miao++;//則調整秒加1
                                   if(miao==60)//若滿60后將清零
                                   miao=0;
                                   write_sfm(0x0e,miao);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x0e);//顯示位置重新回到調節處
                            if(key2num==2)//若功能鍵第二次按下
                                   fen++;//則調整分鐘加1
                                   if(fen==60)//若滿60后將清零
                                   fen=0;
                                   write_sfm(0x0b,fen);//每調節一次送液晶顯示一下
                                   write_com(0x80+0x0b);//顯示位置重新回到調節處
                            if(key2num==3)//若功能鍵第三次按下
                                   shi++;//則調整小時加1
                                   if(shi==24)//若滿24后將清零
                                   shi=0;
                                   write_sfm(8,shi);;//每調節一次送液晶顯示一下
                                   write_com(0x80+8);//顯示位置重新回到調節處
              if(key3==0)
                     delay(5);
                            while(!key3);//按鍵釋放
                                   miao--;//則調整秒減1
                                   if(miao==-1)//若減到負數則將其重新設置為59
                                          miao=59;
                                   fen--;//則調整分鐘減1
                                   if(fen==-1)//若減到負數則將其重新設置為59
                                          fen=59;
                                   shi--;//則調整小時減1
                                   if(shi==-1)//若減到負數則將其重新設置為23
                                          shi=23;
                                   write_sfm(8,shi);//每調節一次送液晶顯示一下
/*主函數*/
       led_cs=0;
       init_1602();
              keyscan();
/*中斷函數*/
void timer0() interrupt 1//定時器0中斷服務程序
       TH0=(65536-50000)/256;//再次裝定時器初值
       count++;//中斷次數累加
       if(count==20)//2050毫秒為1
              count=0;
              sec++;
              if(sec==60)//秒加到60則進位分鐘
                     sec=0;//同時秒數清零
                     min++;
                     if(min==60)//分鐘加到60則進位小時
                            min=0;//同時分鐘數清零
                            hour++;
                            //boom=1;
                            //delay(5);
                            //boom=0;
                            if(hour==24)//小時加到24則小時清零
                                   hour=0;
                                   day++;
                                   week++;
                                   if(week>7)
                                   week=1;
                                   if(mon==1)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==2)
                                    if((year%4==0 &&year%100!=0)||year%4==0)
                                    if(day>29)
                                    day=1;
                                    mon++;
                                    else if(day>28)
                                    day=1;
                                    mon++;
                                    if(mon==3)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==4)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==5)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==6)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==7)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==8)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    }if(mon==9)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==10)
                                    if(day>31)
                                    day=1;
                                    mon++;
                                    if(mon==11)
                                    if(day>30)
                                    day=1;
                                    mon++;
                                    if(mon==12)
                                    if(day>31)
                                    day=1;
                                    mon=1;
                                    ye2++;
                            write_sfm(0,hour);//小時若變化則重新寫入
                     write_sfm(3,min);//分鐘若變化則重新寫入
              write_sfm(6,sec);//秒若變化則重新寫入
                     if((hour==shi&& min==fen) && sec==miao)
              boom=1;
              delay(5);
              boom=0;
收藏收藏5 分享淘帖 頂 踩
ID:46065 發表于 2018-4-6 21:32 | 只看該作者
樓主,求電路圖,先謝謝啦
ID:615302 發表于 2019-10-22 17:40 | 只看該作者
謝謝分享
ID:678764 發表于 2020-1-1 15:35 | 只看該作者
樓主,在哪可以下載完整程序呀,課程設計想要才能考一下。
