這個是一個基于單片機的波形與函數信號發生器的設計
Altium Designer畫的DAC0832信號發生器原理圖和PCB圖如下:(51hei附件中可下載工程文件)
2018-4-4 17:04 上傳
- #include<reg52.h> //包含頭文件
- #include<intrins.h>
- #define uchar unsigned char //宏定義
- #define uint unsigned int
- sbit s1=P3^5; //定義按鍵的接口
- sbit s2=P3^6;
- sbit s3=P3^7;
- sbit s4=P3^4;
- sbit led0=P3^0;
- sbit led1=P3^1;
- sbit led2=P3^2;
- sbit led3=P3^3;
- sbit lcdrs=P2^7; //液晶控制位
- sbit lcden=P2^6;
- char num,boxing,u; //定義全局變量
- int pinlv=100,bujin=1,bujin1=1;
- uchar code table[]="0123456789"; //定義顯示的數組
- uchar code table1[]="Fout= Wave form:";
- unsigned long int m;
- int a,b,h,num1;
- //自定義字符
- uchar code zifu[]={
- 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00, //正弦波 0 1
- 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
- 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00, //矩形波 2 3
- 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
- 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00, //三角波 4 5
- 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00, //鋸齒波 6
- uchar code sin[64]={
- 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
- 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
- }; //正弦波取碼
- uchar code juxing[64]={
- 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
- 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
- }; //矩形波取碼
- uchar code sanjiao[64]={
- 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
- 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
- }; //三角波取碼
- uchar code juchi[64]={
- 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
- 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
- }; //鋸齒波取碼
- void delay(uint xms) //延時函數
- int a,b;
- for(a=xms;a>0;a--)
- for(b=110;b>0;b--);
- void write_com(uchar com) //寫命令函數
- lcdrs=0;
- P0=com;
- delay(1);
- lcden=1;
- delay(1);
- lcden=0;
- void write_date(uchar date) //寫數據函數
- lcdrs=1;
- P0=date;
- delay(1);
- lcden=1;
- delay(1);
- lcden=0;
- //自定義字符集
- void Lcd_ram()
- uint i,j,k=0,temp=0x40;
- for(i=0;i<7;i++)
- for(j=0;j<8;j++)
- write_com(temp+j);
- write_date(zifu[k]);
- k++;
- temp=temp+8;
- void init_lcd() //初始化函數
- uchar i;
- lcden=0; //默認開始狀態為關使能端,見時序圖
- Lcd_ram();
- write_com(0x0f);
- write_com(0x38); //顯示模式設置,默認為0x38,不用變。
- write_com(0x01); //顯示清屏,將上次的內容清除,默認為0x01.
- write_com(0x0c); //顯示功能設置0x0f為開顯示,顯示光標,光標閃爍;0x0c為開顯示,不顯光標,光標不閃
- write_com(0x06); //設置光標狀態默認0x06,為讀一個字符光標加1.
- write_com(0x80); //設置初始化數據指針,是在讀指令的操作里進行的
- for(i=10;i<20;i++) //顯示初始化
- write_date(table1[i]);
- write_com(0x80+0x40);
- for(i=0;i<9;i++)
- write_com(0x80+10);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_com(0x80+0x40+0x09);
- write_date(' ');
- write_date('1');
- write_date('0');
- write_date('.');
- write_date('0');
- write_date('H');
- write_date('z');
- void initclock() //時鐘初始化
- TMOD=0x01;
- TH0=a;
- TL0=b;
- EA=1;
- ET0=1;
- TR0=1;
- void display() //顯示函數
- uchar qian,bai,shi,ge;
- qian=pinlv/1000;
- bai=pinlv%1000/100;
- shi=pinlv%1000%100/10;
- ge=pinlv%1000%100%10;
- if(qian==0)
- write_date(' ');
- else
- write_date(table[qian]);
- if(qian==0&&bai==0)
- write_date(' ');
- else
- write_date(table[bai]);
- write_date(table[shi]);
- write_date('.');
- write_date(table[ge]);
- write_date('H');
- write_date('z');
- if(boxing==0)
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- led3=1;
- led0=0;
- if(boxing==1)
- write_date(2);
- write_date(3);
- write_date(2);
- write_date(3);
- write_date(2);
- write_date(3);
- led0=1;
- led1=0;
- if(boxing==2)
- write_date(4);
- write_date(5);
- write_date(4);
- write_date(5);
- write_date(4);
- write_date(5);
- led1=1;
- led2=0;
- if(boxing==3)
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- led2=1;
- led3=0;
- void keyscan() //鍵盤檢測函數
- if(s1==0)
- EA=0;
- delay(2);
- if(s1==0)
- while(!s1);
- pinlv+=bujin;
- if(pinlv>1000)
- pinlv=100;
- display();
- m=65536-(150000/pinlv);
- a=m/256;
- b=m%256;
- EA=1;
- if(s2==0)
- delay(5);
- if(s2==0)
- EA=0;
- while(!s2);
- pinlv-=bujin;
- if(pinlv<100)
- pinlv=1000;
- display();
- a=m/256;
- b=m%256;
- EA=1;
- if(s3==0)
- delay(5);
- if(s3==0)
- EA=0;
- while(!s3);
- boxing++;
- if(boxing>=4)
- boxing=0;
- display();
- EA=1;
- void bujindisplay()
- uint bai,shi,ge;
- bai=bujin1/100;
- shi=bujin1%100/10;
- ge=bujin1%100%10;
- write_com(0x80+11);
- if(bai==0)
- write_date(' ');
- else
- write_date('.');
- void bujinjiance()
- if(s4==0)
- delay(5);
- if(s4==0)
- while(!s4);
- h++;
- if(h==1)
- write_com(0x01);
- write_com(0x80);
- write_date('S');delay(1); //step value
- write_date('t');delay(1);
- write_date('e');delay(1);
- write_date('p');delay(1);
- write_date(' ');delay(1);
- write_date('v');delay(1);
- write_date('a');delay(1);
- write_date('l');delay(1);
- write_date('u');delay(1);
- write_date(':');delay(1);
- bujin1=bujin;
- bujindisplay();
- if(h==2)
- h=0;
- bujin=bujin1;
- init_lcd();
- initclock();
- display();
- if(h==1)
- if(s1==0)
- delay(5);
- if(s1==0)
- while(!s1);
- bujin1++;
- if(bujin1>=101)
- bujin1=1;
- bujindisplay();
- if(s2==0)
- delay(5);
- if(s2==0)
- while(!s2);
- bujin1--;
- if(bujin1<=0)
2018-4-4 17:05 上傳
仿真及程序.zip
(106.25 KB, 下載次數: 282)
2018-4-4 16:23 上傳
電路的仿真和程序 下載積分: 黑幣 -5
