查看: 2916|回復: 2
TEA5767 +138譯碼器4位共陰LED收音機
ID:301197 發表于 2018-4-2 22:32 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
/*tea5767完整程序*/
#include <reg52.h>
#include <intrins.h>
#define max_freq 108000 //108Mhz
#define min_freq 87500 //87.5Mhz
#define max_pll 0x339b //108MHz時的pll.
#define min_pll 0x299d //87.5MHz時的pll.
#define Add_Freq 1
#define Dec_Freq 0
#define REFERENCE_FREQ 32.768
#define ATIIcxxDriverAddressW 0xC0
#define ATIIcxxDriverAddressR 0xC1
#define _Nop() _nop_(),_nop_(),_nop_(),_nop_(),_nop_() /*定義空指令*/
#define LED P0
void Initialization(void);
void Get_Pll(void);
void Get_Frequency(void);
void Search(unsigned char mode);
void Auto_Search(unsigned char mode);
unsigned char GetKey();
void Delay(unsigned char Time);
void Led_Display(unsigned long i);
void DelayD(unsigned char Time);
void ATIICxx_PWrite(unsigned char *McuAddress,unsigned char count);
void ATIICxx_PRead(unsigned char *McuAddress,unsigned char count);
void I2C_Send_Byte(unsigned char sendbyte);
unsigned char I2C_Receive_Byte(void);
void I2C_Start(void);
void I2C_Stop(void);
void I2C_Ack(void);
void I2C_Noack(void);
/* IIC讀寫程序芯片型號*/
sbit I2C_SCK=P3^4; /*實時時鐘時鐘線引腳 */
sbit I2C_SDA=P3^5; /*實時時鐘數據線引腳 */
sbit k1=P3^0;
sbit k2=P3^1;
sbit k3=P3^2;
sbit k4=P3^3;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
//unsigned char tab[]={ 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//共陽0, 1, 2 3 4 5 6 7 8 9/
unsigned char tab[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x80};//共陰0, 1, 2 3 4 5 6 7 8 9/
unsigned char radio_write_data[5]={0x2d,0x56,0x20,0x11,0x00}; //初始化寫入TEA5767的數據(FM89.8Mhz)
unsigned char radio_read_data[5];
unsigned int Pll_Data;
unsigned long Frequency_Data;
        TMOD = 0x11;
        TH0 = 0x5d;
        TL0 = 0x3d;
        TR0 = 0; //25ms
        TH1 = 0x5d;
        TL1 = 0x3d;
        TR1 = 0; //25ms
        T2CON = 0x30;
        RCAP2H = 0xFE;
        TH2 = RCAP2H;
        RCAP2L = 0xFB;
        TL2 = RCAP2L;
        TR2 = 0; //2400bps
        PCON = 0x00;
        SCON = 0xD0;
        IP = 0x14;
        EX0 = 1;
        IT0 = 1;
        ET0 = 1;
        EX1 = 1;
        IT1 = 1;
        ES = 0;
        EA = 0;
//讀TEA5767狀態,并轉換成頻率
void Radio_Read(void)
unsigned char temp_l,temp_h;
Pll_Data = 0;
ATIICxx_PRead(&radio_read_data[0],5);
temp_l = radio_read_data[1];
temp_h = radio_read_data[0];
temp_h &= 0x3f;
Pll_Data = temp_h*256+temp_l;
Get_Frequency();
//由PLL計算頻率
unsigned char hlsi;
unsigned int npll = 0;
npll = Pll_Data;
hlsi = radio_read_data[2]&0x10;
if (hlsi)
Frequency_Data = (unsigned long)((float)(npll)*(float)REFERENCE_FREQ*(float)0.25-225); //頻率單位:KHz
Frequency_Data = (unsigned long)((float)(npll)*(float)REFERENCE_FREQ*(float)0.25+225); //頻率單位:KHz
//由頻率計算PLL
void Get_Pll(void)
unsigned char hlsi;
if (hlsi)
Pll_Data = (unsigned int)((float)((Frequency_Data+225)*4)/(float)REFERENCE_FREQ); //頻率單位:k
Pll_Data = (unsigned int)((float)((Frequency_Data-225)*4)/(float)REFERENCE_FREQ); //頻率單位:k
//手動設置頻率,mode=1,+0.1MHz; mode="0:-0".1MHz ,不用考慮TEA5767用于搜臺的相關位:SM,SUD
Radio_Read();
if(mode)
Frequency_Data += 100;
if(Frequency_Data > max_freq)
Frequency_Data = min_freq;
Frequency_Data -= 100;
if(Frequency_Data < min_freq)
Frequency_Data = max_freq;
Get_Pll();
radio_write_data[0] = Pll_Data/256;
radio_write_data[1] = Pll_Data%256;
radio_write_data[2] = 0x41;
radio_write_data[3] = 0x11;
radio_write_data[4] = 0x40;
ATIICxx_PWrite(&radio_write_data[0],5);
//自動搜臺,mode=1,頻率增加搜臺; mode="0:頻率減小搜臺".
Radio_Read();
Get_Pll();
if(mode)
        radio_write_data[2] = 0xb1;
        if(Pll_Data > max_pll)
                Pll_Data = min_pll;
        if(Pll_Data < min_pll)
                Pll_Data = max_pll;
radio_write_data[0] = Pll_Data/256+0x40;
Radio_Read();
while(!(radio_read_data[0]&0x80)) //RF電臺就緒標志
        Radio_Read();
void main(void)
//0x2d,0x56,0x20,0x11,0x00
unsigned long temp;
Initialization();
radio_write_data[0] =0x2A;
radio_write_data[1] =0xB6;
radio_write_data[2] =0x41;
radio_write_data[3] =0x11;
radio_write_data[4] =0x40;
ATIICxx_PWrite(&radio_write_data[0],5);//初始化TEA5767(89.8Mhz)
Frequency_Data = 101900;
        { temp= Frequency_Data;
        Led_Display(Frequency_Data);
        if( k1 == 0)
                DelayD(2);
                while(k1 == 0);//等待鍵松開
                Search(Add_Freq);
        if( k2 == 0)
                DelayD(2);
                while(k2 == 0);//等待鍵松開
                Search(Dec_Freq);
        if( k3 == 0)
                DelayD(2);
                while(k3 == 0);//等待鍵松開
                Auto_Search(Add_Freq);
        if( k4 == 0)
                DelayD(2);
                while(k4 == 0);//等待鍵松開
                Auto_Search(Dec_Freq);
struct bytedata_2
unsigned char ByteH;
unsigned char ByteL;
union int2byte
unsigned int IntData;
struct bytedata_2 ByteData;
//啟動I2C總線,退出時SCL為低
        I2C_SDA=1; /*發送起始條件的數據信號*/
        _Nop();
        I2C_SCK=1;
        _Nop();_Nop();_Nop();_Nop();_Nop();/*起始條件建立時間大于4.7us,延時*/
        I2C_SDA=0; /*發送起始信號*/
        _Nop();_Nop();_Nop();_Nop();_Nop(); /* 起始條件鎖定時間大于4μs*/
        I2C_SCK=0; /*鉗住I2C總線,準備發送或接收數據 */
//*停止I2C總線
void I2C_Stop(void)
        I2C_SCK=0;
        I2C_SDA=0; /*發送結束條件的數據信號*/
        _Nop(); /*發送結束條件的時鐘信號*/
        I2C_SCK=1; /*結束條件建立時間大于4μs*/
        I2C_SDA=1; /*發送I2C總線結束信號*/
//MCU等待應答位(返回0表示應答)
bit I2C_WaitAck(void)
        unsigned char ucErrTime = 200; //因故障接收方無ACK,超時值。
        I2C_SCK=0;
        I2C_SDA=1;
        _Nop();
        I2C_SCK=1;
        while(I2C_SDA)
                ucErrTime--;
                if (ucErrTime == 0)
                        I2C_Stop();
                        return 0;
        I2C_SCK=0;
        return 1;
        //MCU應答信號
void I2C_Ack(void)
        I2C_SCK=0;
        I2C_SDA=0;
        _Nop();
        _Nop();
        _Nop();
        _Nop();
        _Nop();
        I2C_SCK=1;
        _Nop();
        _Nop();
        _Nop();
        _Nop();
        _Nop();
        I2C_SCK=0;
        //MCU發送非應答信號
        I2C_SCK=0;
        I2C_SDA=1;
        _Nop();
        _Nop();
        I2C_SCK=1;
        _Nop();
        _Nop();
        I2C_SCK=0;
unsigned char i = 8;
while( i-- )
        I2C_SCK = 0;
        _Nop(); //_Nop();
        if ( sendbyte &0x80 ) I2C_SDA =1;
        else I2C_SDA =0;
        _Nop(); //_Nop();
        I2C_SCK = 1;
        _Nop(); //_Nop();
        sendbyte <<= 1;
I2C_WaitAck();
static unsigned char I2C_Receive_Byte(void)
        unsigned char i = 8, data_buffer;
        I2C_SDA = 1;
        while ( i--)
                I2C_SCK =0;
                _Nop();_Nop();
                I2C_SCK =1;
                _Nop();_Nop();
                data_buffer <<= 1;
                if ( I2C_SDA ) data_buffer++;
        return (data_buffer);
        I2C_Start();
        I2C_Send_Byte( ATIIcxxDriverAddressW );
        while(count--)
                I2C_Send_Byte( *(unsigned char*)McuAddress );
                ((unsigned char*)McuAddress)++;
        I2C_Stop();
        I2C_Start();
        I2C_Send_Byte( ATIIcxxDriverAddressR );
        while(count--)
                *McuAddress = I2C_Receive_Byte();
                I2C_Ack();
                McuAddress++;
                I2C_Noack();
                I2C_Stop();
                unsigned char i;
                while( --Time != 0)
            for(i = 0; i < 125; i++); //i 從0加到125,CPU大概就耗時1 毫秒 。
void Led_Display(unsigned long i) //顯示函數
        LED = tab[i/100000];                        //千位
        LSA = 1;
        LSB = 1;
        LSC = 0;
        DelayD(3);
        LED = tab[(i%100000)/10000];           //百位
        LSA = 0;
        LSB = 1;
        LSC = 0;
        DelayD(3);
        LED = tab[((i%100000)%10000)/1000]|0x80;   //十位
        LSA = 1;
        LSB = 0;
        LSC = 0;
        DelayD(3);
        LED = tab[(((i%100000)%10000)%1000)/100];         //個位
        LSA = 0;
        LSB = 0;
        LSC = 0;
        DelayD(3);
//sbit LSA=P2^2;
//sbit LSB=P2^3;
//sbit LSC=P2^4;
// 000          打開第0位
// 100          打開第1位
// 010          打開第2位
// 110          打開第3位
// 001          打開第4位
// 101          打開第5位
// 011          打開第6位
// 111          打開第7位
ID:996773 發表于 2022-12-28 15:02 | 只看該作者
這配置練練手可以,用138譯碼器逐掃四個數碼管,稍微弱一點的臺嗚嗚嗚干擾吵得人找不到北。
ID:301197 發表于 2018-4-2 22:34 | 只看該作者
LED用P0口,精度0.1MHz,帶小數點
譯碼器分別位
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
