查看: 7395|回復(fù): 4
請問怎么把LCD1602中的字符串換行呀
ID:278523 發(fā)表于 2018-4-1 22:07 | 顯示全部樓層 |閱讀模式
5黑幣
請問怎么把temper換行到第二行去啊,急急急
#include <reg52.H>
#include <intrins.H>
#include <math.H>
sbit dula = P2^6;
sbit wela = P2^7;
sbit rw = P3^6;
sbit RS = P3^5;
sbit LCDEN = P3^4;
void delayUs()
    _nop_();
void delayMs(uint a)
    uint i, j;
    for(i = a; i > 0; i--)
        for(j = 100; j > 0; j--);
void writeComm(uchar comm)
     RS = 0;
    P0 = comm;
    LCDEN = 1;
     delayUs();
    LCDEN = 0;
    delayMs(1);
//寫數(shù)據(jù):RS=1, RW=0;
void writeData(uchar dat)
     RS = 1;
     P0 = dat;
     LCDEN = 1;
    delayUs();
    LCDEN = 0;
    delayMs(1);
void init()
   rw = 0;
   dula = wela = 0;
   writeComm(0x38);
   writeComm(0x0c);
   writeComm(0x06);
   writeComm(0x01);
void writeString(uchar * str, uchar length)
     uchar i;
    for(i = 0; i < length; i++)
         writeData(str[i]);
/**//*****************************ultrasound*******************************/
/**//*****************************DS18B20*******************************/
sbit ds = P2^2;
void dsInit()
    unsigned int i;
    ds = 0;
    i = 100;
     while(i>0) i--;
    ds = 1;
    i = 4;
     while(i>0) i--;
void dsWait()
      unsigned int i;
      while(ds);
      while(~ds);
      i = 4;
      while(i > 0) i--;
bit readBit()
    unsigned int i;
    bit b;
    ds = 0;
    i++;
    ds = 1;
   i++; i++;
    b = ds;
    i = 8;
    while(i>0) i--;
    return b;
unsigned char readByte()
    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
        j = readBit();
        dat = (j << 7) | (dat >> 1);
    return dat;
void writeByte(unsigned char dat)
    unsigned int i;
    unsigned char j;
    bit b;
    for(j = 0; j < 8; j++)
        b = dat & 0x01;
        dat >>= 1;
        if(b)
           ds = 0;          i++; i++;
            ds = 1;
            i = 8; while(i>0) i--;
            ds = 0;
            ds = 1;
           i++; i++;
void sendChangeCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
    t = value * 0.0625;
    value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0減0.5
    return value;
void display(int v)
    unsigned char count;
    unsigned char datas[] = {0, 0, 0, 0, 0};
    unsigned int tmp = abs(v);
    datas[0] = tmp / 10000;
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
    datas[3] = tmp % 100 / 10;
    datas[4] = tmp % 10;
    writeComm(0xc0+7);
    if(v < 0)
        writeString("- ", 2);
       writeString("+ ", 2);
    if(datas[0] != 0)
        writeData('0'+datas[0]);
    for(count = 1; count != 5; count++)
        writeData('0'+datas[count]);
        if(count == 2)
            writeData('.');
        writeData(0xdf);
        writeData(0x43);
    uchar table[] = "temper:";
    sendChangeCmd();
    init();
    writeComm(0xc0);
    writeString(table, 7);
        delayMs(1000); //溫度轉(zhuǎn)換時間需要750ms以上
        writeComm(0xc0);
        display(getTmpValue());
        sendChangeCmd();
ID:137239 發(fā)表于 2018-4-2 09:52 | 顯示全部樓層
uchar code addr[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,//第一行顯示位置
                   0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f//第二行顯示位置
void zuobiao(uchar x,uchar y,uchar *s)
        uchar dizhi;
        dizhi=addr[16*x+y];
    Cmd(dizhi | 0x80);
        while(*s>0)
              Data(*s);
                  s++;
zuobiao(1,0,table);
ID:137239 發(fā)表于 2018-4-2 10:14 | 顯示全部樓層
writeComm(0x80+0x40);
也可以,你試試
ID:286600 發(fā)表于 2018-4-4 21:30 來自觸屏版 | 顯示全部樓層
指定顯示位置呀
ID:302510 發(fā)表于 2018-4-5 20:10 | 顯示全部樓層
我感覺也是
