查看: 1856|回復: 0
條形碼測試cpp
ID:300498 發表于 2018-4-1 19:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "core/core.hpp"
#include "highgui/highgui.hpp"
#include "imgproc/imgproc.hpp"
#include "video/tracking.hpp"
#include<iostream>
#include <iostream>
#include <zbar.h>
#define STR(s) #s
using namespace zbar;
using namespace cv;
using namespace std;
int main(int argc, char*argv[])
    ImageScanner scanner;
    scanner.set_config(ZBAR_NONE, ZBAR_CFG_ENABLE, 1);
    Mat image = imread("../data/2code.jpg");
    if (!image.data)
        cout << "請確認圖片" << endl;
        system("pause");
        return 0;
    Mat imageGray;
    cvtColor(image, imageGray, CV_RGB2GRAY);
    int width = imageGray.cols;
    int height = imageGray.rows;
    uchar *raw = (uchar *)imageGray.data;
    Image imageZbar(width, height, "Y800", raw, width * height);
    scanner.scan(imageZbar); //掃描條碼
    Image::SymbolIterator symbol = imageZbar.symbol_begin();
    if (imageZbar.symbol_begin() == imageZbar.symbol_end())
        cout << "查詢條碼失敗,請檢查圖片!" << endl;
    for (; symbol != imageZbar.symbol_end(); ++symbol)
        cout << "類型:" << endl << symbol->get_type_name() << endl << endl;
        cout << "條碼:" << endl << symbol->get_data() << endl << endl;
    imshow("Source Image", image);
    waitKey();
    imageZbar.set_data(NULL, 0);
    return 0;
