查看: 4651|回復: 3
FPGA采集模擬信號數據波形,51單片機顯示波形
fpga采集數據波形,51單片機顯示波形,示波器
單片機源程序如下(frqent_count.v):
  1. /*==============================================
  2. *        描    述:頻率計控制模塊計數測試程序
  3. //==============================================*/
  4. module frqent_count(clk_b,clk_d,vavle,rst,cnt_h_out,cnt_b_out,cnt_d_out);
  5.         input rst;
  6.         input clk_b;
  7.         input clk_d;
  8.
  9.         input vavle;
  10.
  11.         output reg[31:0]     cnt_h_out;                                         //用于測量高脈寬
  12.         output reg[31:0]     cnt_b_out;                                                //標準頻率計數
  13.         output reg[31:0]         cnt_d_out;                                                //待測頻率計數
  14.
  15.         reg        [31:0]        cnt_h;        //用于測量高脈寬
  16.         reg        [31:0]        cnt_b;        //標準頻率計數
  17.         reg        [31:0]        cnt_d;        //待測頻率計數
  18.
  19.         reg        start_reg;        //開始信號緩存
  20.         reg        clk_d_reg;        //待測時鐘緩存
  21.
  22.         wire start;
  23.
  24.         /*------------------------------------------------
  25.         *        模塊說明:計數允許模塊
  26.         *        備          注:Start_l對于頻率沒有作用,只對于低電平
  27.                                  脈寬計數有作用,頻率主要作用在Start
  28.         *-------------------------------------------------*/
  29.
  30.         assign start = vavle;
  31.
  32.
  33.         //開始信號緩存
  34.         always@(posedge clk_b,negedge rst)
  35.         begin
  36.                 if(!rst)
  37.                 begin
  38.                         start_reg <= 1'b0;
  39.                 end
  40.
  41.                 else
  42.                 begin
  43.                         start_reg <= start;
  44.                 end
  45.         end
  46.
  47.         //待測信號緩存
  48.         always@(posedge clk_b, negedge rst)
  49.         begin
  50.                 if(!rst)
  51.                 begin
  52.                         clk_d_reg <= 1'b0;
  53.                 end
  54.
  55.                 else
  56.                 begin
  57.                         clk_d_reg <= clk_d;
  58.                 end
  59.         end
  60.
  61.         //待測時鐘進行計數
  62.         always@(posedge clk_d,negedge rst)
  63.         begin
  64.                 if(!rst)
  65.                 begin
  66.                         cnt_d <= 32'b0;
  67.                 end
  68.
  69.                 else
  70.                 begin
  71.                         if(start == 0)
  72.                                 begin
  73.                                         cnt_d <= 0;
  74.                                 end
  75.                         // 高電平觸發
  76.                         else
  77.                                 begin
  78.                                         cnt_d <= cnt_d + 1'b1;
  79.                                 end
  80.                 end
  81.         end
  82.
  83.         //標準時鐘進行計數
  84.         always@(posedge clk_b,negedge rst)
  85.         begin
  86.                 if(!rst)
  87.                 begin
  88.                         cnt_b <= 0;
  89.                 end
  90.
  91.                 else
  92.                 begin
  93.                         if(start == 0)
  94.                                 begin
  95.                                         cnt_b <= 0;
  96.                                 end
  97.
  98.                         else
  99.                                 begin
  100.                                         cnt_b <= cnt_b + 1'b1;
  101.                                 end
  102.                 end
  103.         end
  104.
  105.         //高電平計數
  106.         always@(posedge clk_b, negedge rst)
  107.         begin
  108.                 if(!rst)
  109.                 begin
  110.                         cnt_h <= 0;
  111.                 end
  112.
  113.                 else
  114.                         begin
  115.                                 if(clk_d == 0)
  116.                                 begin
  117.                                         cnt_h <= 0;
  118.                                 end
  119.
  120.                                 else
  121.                                 begin
  122.                                         cnt_h <= cnt_h + 1'b1;
  123.                                 end
  124.                         end
  125.         end
  126.
  127.         //標準計數和待測計數輸出
  128.         always@(posedge clk_b, negedge rst)
  129.         begin
  130.                 if(!rst)
  131.                 begin
  132.                         cnt_b_out <= 0;
  133.                         cnt_b_out <= 0;
  134.                 end
  135.
  136.                 else
  137.                 begin
  138.                         if(start_reg && !start)
  139.                         begin
  140.                                 cnt_b_out <= cnt_b;
  141.                                 cnt_d_out <= cnt_d;
  142.                         end
  143.
  144.                         else
  145.                         begin
  146.                                 cnt_b_out <= cnt_b_out;
  147.                                 cnt_d_out <= cnt_d_out;
  148.                         end
  149.                 end
  150.         end
  151.
  152.         //高電平計數輸出
  153.         always@(posedge clk_b,negedge rst)
  154.         begin
  155.                 if(!rst)
  156.                 begin
  157.                         cnt_h_out<=0;
  158.                 end
  159.
  160.                 else
  161.                 begin
  162.                         if(clk_d_reg&&!clk_d)
  163.                         begin
  164.                                 cnt_h_out<=cnt_h;
  165.                         end
  166.
  167.                         else
  168.                         begin
  169.                                 cnt_h_out<=cnt_h_out;
  170.                         end
  171.                 end
  172.         end
  173.
  174. endmodule
  175.
采集模擬信號.rar (2.39 MB, 下載次數: 51)
ID:326615 發表于 2018-5-10 10:44 | 只看該作者
有用,就是黑幣太高了
ID:326615 發表于 2018-5-10 10:45 | 只看該作者
學習學習
ID:229939 發表于 2018-8-6 00:45 | 只看該作者
謝謝。。。。。。。。。。。。
