查看: 3641|回復: 2
STM32超聲波定位算法(融合測試)源碼
ID:157311 發表于 2018-4-1 10:50 | 顯示全部樓層 |閱讀模式
超詳細的資料,是我自己編寫的,包含定位算法的程序及其分析,有需要的速速學習吧
stm32主程序源碼:
  1. #include <stm32f10x.h>
  2. #include "Nvic_Exit.h"
  3. #include "ov7670.h"
  4. #include "I2C.h"
  5. #include "ILI9325_32.h"
  6. #include "GUI_32.h"
  7. #include "delay.h"
  8. #include "led.h"
  9. #include "data_conf.h"
  10. #include "PictureAnalyse.h"
  11. #include "Tim1.h"
  12. /*
  13. 用到的模塊
  14. 1:IIC 對應端口初始化
  15. 2:OV7670寄存器初始化+端口初始化
  16. 3:添加FIFO.C輔助端口初始化,并且添加RRST()和WRST()兩個初始化函數
  17. 4:外部中斷初始化
  18. 5:LED指示燈初始化
  19. 6:延時初始化
  20. 7: 串口初始化 測試用
  21. 程序邏輯
  22. */
  23. extern Picture_Control PictureContorl;
  24. int main()
  25. {
  26.           LED_GPIO_Config();//指示燈初始化
  27.           delay_init(72);//延時初始化
  28.           ILI9325_initial();//TFT端口初始化
  29.           Anal_I2C_Init();//IIC初始化
  30.     ov7670_PortConfig();//攝像頭模塊引腳初始化//對RCK,WR,OE,WRST,RRST進行了端口設置
  31.           Cmos7670_init();//配置寄存
  32.           GUI_clearscreen(0xffff);//清屏
  33.     GUI_sprintf_string(50, 100,"TFT Init Successful !", 0x0000,0xffff);        //顯示初始化
  34.           GUI_clearscreen(0xffff);//清屏
  35.                 Exit_Init(GPIOC, GPIO_Pin_12, GPIO_Mode_IPU, EXTI_Trigger_Falling, 0, 0);        //VSYNC //外部中斷初始化
  36.   //        TakeVerfPhoto();
  37.           TIM1_Init();
  38.                 GUI_sprintf_string(10,50,"ERROR:",0x0000,0xffff);
  39.           GUI_sprintf_string(10,100,"ERROR_Verf:",0x0000,0xffff);
  40.                 GUI_sprintf_string(10,150,"+offset:",0x0000,0xffff);
  41.                 GUI_sprintf_string(10,200,"-offset:",0x0000,0xffff);
  42.           GUI_sprintf_string(10,250,"RunTime:",0x0000,0xffff);
  43.     while(1)
  44.                 {
  45.               GUI_wrul(200,50,PictureContorl.Control_Value,0x0000,0xffff); //刷新控制?
  46.                         GUI_wrul(200,100,PictureContorl.Control_Value_Verf,0x0000,0xffff); //刷新控制量
  47.                   if(PictureContorl.Control_Value-PictureContorl.Control_Value_Verf>0)
  48.
  49.                                 GUI_wrul(200,150,(PictureContorl.Control_Value-PictureContorl.Control_Value_Verf),0x0000,0xffff); //刷新控制量
  50.                         else
  51.         GUI_wrul(200,200,(PictureContorl.Control_Value_Verf-PictureContorl.Control_Value),0x0000,0xffff); //刷新控制量
  52.                                 GUI_wrul(200,250,PictureContorl.Control_Value,0x0000,0xffff); //刷新控制?
  53.
  54.                 }
  55. }
下載:
28 攝像頭定位算法(融合測試) 定位算法2.rar (4.68 MB, 下載次數: 45)
ID:137231 發表于 2018-4-1 21:47 | 顯示全部樓層
謝謝分享,定位范圍有多寬
ID:314855 發表于 2018-7-7 23:06 | 顯示全部樓層
請問是用什么軟件寫的
