三路ADC采集stm32源程序:
- @author Mei Jilin
- @brief ADC1的配置完成3通道的數(shù)據(jù)采集
- @attention
- 1 ----------- adc_config(); //配置adc
- 2 ----------- adc_start(); //啟動adc,開始轉(zhuǎn)換
- 3 ----------- get_ChannelValue(ADC_Channel_x); //讀取相應(yīng)通道的adc值
- #include "stm32f10x.h"
- #include "adc.h"
- #define CH_NUM 3 //要使用的ADC通道數(shù)
- static uint16_t ad_value[CH_NUM]={0};
- /** @para none
- * @ret none
- * @brief adc對應(yīng)的gpio初始化
- void adc_gpio_init(void)
- GPIO_InitTypeDef gpio;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- gpio.GPIO_Mode = GPIO_Mode_AIN; //配置為模擬輸入
- gpio.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2; //ADC1 --channel0,1,2
- gpio.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&gpio);
- /** @para none
- * @ret none
- * @brief adc配置
- void adc_init(void)
- ADC_InitTypeDef adc;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
- RCC_ADCCLKConfig(RCC_PCLK2_Div6); //設(shè)置ad時鐘為72/6=12M,ad最大時鐘頻率為14M
- ADC_DeInit(ADC1);
- adc.ADC_Mode = ADC_Mode_Independent; //工作在獨立模式
- adc.ADC_ContinuousConvMode = ENABLE; //連續(xù)轉(zhuǎn)換模式
- adc.ADC_DataAlign = ADC_DataAlign_Right; //數(shù)據(jù)右對齊
- adc.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//不使用外部觸發(fā)
- adc.ADC_NbrOfChannel = CH_NUM ; //轉(zhuǎn)換3個通道
- adc.ADC_ScanConvMode = ENABLE; //連續(xù)轉(zhuǎn)換模式
- ADC_Init(ADC1,&adc);
- //設(shè)定指定的ADC通道組,設(shè)置轉(zhuǎn)化順序和采樣時間
- ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5);
- ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_55Cycles5);
- //開啟adc的DMA
- ADC_DMACmd(ADC1,ENABLE);
- //使能ADC1
- ADC_Cmd(ADC1, ENABLE);
- /* Enable ADC1 reset calibaration register */
- ADC_ResetCalibration(ADC1); //重新校準(zhǔn)
- /* Check the end of ADC1 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC1)); //等待重新校準(zhǔn)完成
- /* Start ADC1 calibaration */
- ADC_StartCalibration(ADC1); //開始校準(zhǔn)
- /* Check the end of ADC1 calibration */
- while(ADC_GetCalibrationStatus(ADC1)); //等待校準(zhǔn)完成
- /** @para none
- * @ret none
- * @brief 配置dma
- void adc_dma_init()
- DMA_InitTypeDef dma;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- DMA_DeInit(DMA1_Channel1);
- dma.DMA_PeripheralBaseAddr = (u32)&(ADC1->DR); //DMA對應(yīng)的外設(shè)基地址
- dma.DMA_MemoryBaseAddr = (u32)&ad_value; //內(nèi)存存儲基地址
- dma.DMA_DIR = DMA_DIR_PeripheralSRC;//DMA的轉(zhuǎn)換模式為SRC模式,由外設(shè)搬移到內(nèi)存
- dma.DMA_M2M = DMA_M2M_Disable; //M2M模式禁用
- dma.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//定義外設(shè)數(shù)據(jù)寬度為16位
- dma.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //DMA搬移數(shù)據(jù)尺寸,HalfWord就是為16位
- dma.DMA_BufferSize = CH_NUM; //DMA緩存大小CH_NUM個
- dma.DMA_MemoryInc = DMA_MemoryInc_Enable; //接收一次數(shù)據(jù)后,目標(biāo)內(nèi)存地址后移
- dma.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //接收一次數(shù)據(jù)后,設(shè)備地址禁止后移
- dma.DMA_Mode = DMA_Mode_Circular; //轉(zhuǎn)換模式,循環(huán)緩存模式。
- dma.DMA_Priority = DMA_Priority_High; //DMA優(yōu)先級高
- DMA_Init(DMA1_Channel1,&dma);
- /** @para none
- * @ret none
- * @brief 完成adc配置
- void adc_config(void)
- adc_gpio_init();
- adc_dma_init();
- adc_init();
- /** @para none
- * @ret none
- * @brief 啟動adc,開始轉(zhuǎn)換
- void adc_start(void)
- /* Start ADC1 Software Conversion */
- ADC_SoftwareStartConvCmd(ADC1, ENABLE); //連續(xù)轉(zhuǎn)換開始,ADC通過DMA方式不斷的更新RAM區(qū)。
- DMA_Cmd(DMA1_Channel1,ENABLE);
- /** @para ADC_Channel --- (ADC_Channel0 ~ ADC_Channel17)
- * @ret ADC_Channel_x 的ADC值
- uint16_t get_ChannelVale(uint8_t ADC_Channel)
- uint16_t ret = 0;
- switch(ADC_Channel)
- case ADC_Channel_0:
- ret = ad_value[0];
- break;
- case ADC_Channel_1:
- ret = ad_value[1];
- break;
- case ADC_Channel_2:
- ret = ad_value[2];
- break;
- return ret;
ADC_test.rar
(274.67 KB, 下載次數(shù): 411)
2018-4-5 04:19 上傳
下載積分: 黑幣 -5
