BL5372-USB功能RTC時(shí)鐘電路板AD格式的電路原理圖和PCB工程:
2018-4-1 01:25 上傳
2018-4-1 01:25 上傳
2018-4-1 01:25 上傳
Demo演示用的固件(程序),出貨前已經(jīng)燒錄好,給PCBA通電即可工作!
如果您需要再次燒錄,請(qǐng)按此HEX文件進(jìn)行燒錄即可。
燒錄工具一般用 ST-LINK/V2, 或者J-LINK都可以!
R8、R9兩者只能焊接一個(gè)
焊接R8則選擇IIC接口
焊接R9則選擇SPI接口
stm32程序源碼:
- 作者:紫電青霜
- /*Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stm32f0xx_hal.h"
- #include "usb_device.h"
- #include "BL5372_IIC.h"
- #include "usbd_cdc_if.h"
- uint8_t RRTCiic_buf[16];
- uint8_t RRTCiic_Buf_Out[26]={0x32,0x30,0x31,0x37,0xC4,0xEA,0x30,0x32,0xD4,0xC2,
- 0x32,0x35,0xC8,0xD5,0x32,0x32,0x3A,0x35,0x36,0x3A,0x00,0x00,0x0D,0x0A,0x0D,0x0A};
- extern unsigned char Set_Year ;
- extern unsigned char Set_Month ;
- extern unsigned char Set_Day ;
- extern unsigned char Set_Hour ;
- extern unsigned char Set_Minute ;
- extern unsigned char Set_Second ;
- uint8_t Rec_buff[18]={0};
- /* Private variables ---------------------------------------------------------*/
- SPI_HandleTypeDef hspi1;
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- void Error_Handler(void);
- static void MX_GPIO_Init(void);
- static void MX_SPI1_Init(void);
- void My_GPIO_Init(void);
- unsigned char DataStr[]=__DATE__;
- unsigned char TimeStr[]=__TIME__;
- extern uint8_t UserRxBufferFS[];
- int main(void)
- unsigned char i=0;
- unsigned char Miao_mark = 0;
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_SPI1_Init();
- MX_USB_DEVICE_Init();
- IIC_Init();
- My_GPIO_Init();
- if(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_7) == 0)//讀取PB7管腳的電平,為低電平,則初始化BL5372時(shí)間
- BL5372_init();
- while (1)
- HAL_Delay(50);
- if(UserRxBufferFS[0] == 'S' && UserRxBufferFS[1] == 'T' && UserRxBufferFS[10] == 'F' && UserRxBufferFS[11] == 'N' )
- CDC_Transmit_FS("設(shè)置年月日\(chéng)r\n",12);
- Set_Year = ((UserRxBufferFS[4]-0x30)<<4)+(UserRxBufferFS[5]-0x30);
- Set_Month = ((UserRxBufferFS[6]-0x30)<<4)+(UserRxBufferFS[7]-0x30);
- Set_Day = ((UserRxBufferFS[8]-0x30)<<4)+(UserRxBufferFS[9]-0x30);
- BL5372_init();
- else if(UserRxBufferFS[0] == 'S' && UserRxBufferFS[1] == 'T' && UserRxBufferFS[8] == 'F' && UserRxBufferFS[9] == 'I' )
- CDC_Transmit_FS("設(shè)置時(shí)分秒\r\n",12);
- Set_Hour = ((UserRxBufferFS[2]-0x30)<<4)+(UserRxBufferFS[3]-0x30);
- Set_Minute = ((UserRxBufferFS[4]-0x30)<<4)+(UserRxBufferFS[5]-0x30);
- Set_Second = ((UserRxBufferFS[6]-0x30)<<4)+(UserRxBufferFS[7]-0x30);
- BL5372_init();
- for(i=0;i<18;i++)
- UserRxBufferFS[i] = 0;
- // HAL_Delay(5);
- BL5372_Read(0x00,RRTCiic_buf,7);
- if(RRTCiic_buf[0] != Miao_mark)
- //秒
- RRTCiic_Buf_Out[20] = ((RRTCiic_buf[0]>>4)&0x0f) +0x30;
- RRTCiic_Buf_Out[21] = (RRTCiic_buf[0]&0x0f) +0x30;
- //分
- RRTCiic_Buf_Out[17] = ((RRTCiic_buf[1]>>4)&0x0f) +0x30;
- RRTCiic_Buf_Out[18] = (RRTCiic_buf[1]&0x0f) +0x30;
- //時(shí)
- RRTCiic_Buf_Out[14] = ((RRTCiic_buf[2]>>4)&0x0f) +0x30;
- RRTCiic_Buf_Out[15] = (RRTCiic_buf[2]&0x0f) +0x30;
- //日
- RRTCiic_Buf_Out[10] = ((RRTCiic_buf[4]>>4)&0x0f) +0x30;
- RRTCiic_Buf_Out[11] = (RRTCiic_buf[4]&0x0f) +0x30;
- //月
- RRTCiic_Buf_Out[6] = ((RRTCiic_buf[5]>>4)&0x0f) +0x30;
- RRTCiic_Buf_Out[7] = (RRTCiic_buf[5]&0x0f) +0x30;
- //年
- RRTCiic_Buf_Out[2] = ((RRTCiic_buf[6]>>4)&0x0f) +0x30;
- RRTCiic_Buf_Out[3] = (RRTCiic_buf[6]&0x0f) +0x30;
- CDC_Transmit_FS((uint8_t *)RRTCiic_Buf_Out,26);
- Miao_mark = RRTCiic_buf[0] ;
- for(i=0;i<16;i++)
- RRTCiic_buf[i] = 0;
- /* USER CODE END 3 */
- /** System Clock Configuration
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_PeriphCLKInitTypeDef PeriphClkInit;
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48;
- RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI48;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
- Error_Handler();
- PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
- PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_HSI48;
- if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
- Error_Handler();
- /**Configure the Systick interrupt time
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* SPI1 init function */
- hspi1.Instance = SPI1;
- hspi1.Init.Mode = SPI_MODE_MASTER;
- hspi1.Init.Direction = SPI_DIRECTION_2LINES;
- hspi1.Init.DataSize = SPI_DATASIZE_4BIT;
- hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
- hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
- hspi1.Init.NSS = SPI_NSS_SOFT;
- hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
- hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
- hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
- hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
- hspi1.Init.CRCPolynomial = 7;
- hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
- hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
- if (HAL_SPI_Init(&hspi1) != HAL_OK)
- Error_Handler();
- /** Pinout Configuration
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOA_CLK_ENABLE();
- GPIO_InitTypeDef GPIO_InitStruct;
- __HAL_RCC_GPIOB_CLK_ENABLE();
- /*Configure GPIO pin : PB7 */
- GPIO_InitStruct.Pin = GPIO_PIN_7 ;
- GPIO_InitStruct.Mode = GPIO_MODE_INPUT;//輸入
- GPIO_InitStruct.Pull = GPIO_PULLUP;//上拉輸入
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param None
- * @retval None
- /* USER CODE BEGIN Error_Handler */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
下載:
BL5372-USB功能RTC時(shí)鐘電路板原理圖和PCB.zip
(17.33 MB, 下載次數(shù): 60)
2018-3-31 20:07 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
BL5372.pdf
(144.14 KB, 下載次數(shù): 38)
2018-3-31 20:06 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
RTC時(shí)鐘電路板程序源碼.zip
(3.63 MB, 下載次數(shù): 90)
2018-3-31 20:06 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
