stm32f4驅(qū)動ov2640圖像處理
stm32單片機(jī)源程序如下:
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "key.h"
- #include "lcd.h"
- #include "ltdc.h"
- #include "sdram.h"
- #include "pcf8574.h"
- #include "timer.h"
- #include "ov5640.h"
- #include "usart2.h"
- #include "dcmi.h"
- #include "usmart.h"
- //分辨率 x,y
- #define X 160
- #define Y 120
- #define buf_size X*Y
- //提取R、G、B的參數(shù)
- #define RGB_R 0XF800
- #define RGB_G 0X07E0
- #define RGB_B 0X001F
- //fps、FPS數(shù)組存入采集回來的信息
- u32 fps[buf_size];
- u16 FPS[buf_size];
- //變量R,G,B
- u16 R,G,B;
- u16 threshold=32767;//閾值
- 函數(shù):灰度化且二值化函數(shù)
- 返回值類型:u16
- 返回值:二值化后的值
- 形參:采集的像素點數(shù)據(jù)
- u16 Binary(u16 pixel)
- static u16 Gray;
- /*******提取R,G,B值*******/
- R = (pixel&RGB_R)>>11;
- G = (pixel&RGB_G)>>5;
- B = (pixel&RGB_B);
- /*******灰度值計算*******/
- /*******網(wǎng)絡(luò)上大部分的公式是針對8位的*******/
- /*******這條公式是針對12位的******/
- Gray = (u16)((R*634+G*613+B*232));
- /*******二值化*******/
- if(Gray<threshold)
- Gray = BLACK;
- else if(Gray>=threshold)
- Gray = WHITE;
- return Gray;
- //處理數(shù)據(jù)
- //當(dāng)采集完一幀數(shù)據(jù)后,調(diào)用此函數(shù).開始下一幀采集.
- //該函數(shù)會被HAL_DCMI_FrameEventCallback調(diào)用
- void jpeg_data_process(void)
- u16 i,j,l;
- l = 0;
- /*******顯示二值化后的數(shù)據(jù)*******/
- for(j=0;j<Y;j++)
- for(i=0;i<X;i++)
- LCD_SetCursor(i,j);
- LCD_WriteRAM_Prepare(); //開始寫入GRAM
- FPS[l] = fps[l];
- LCD->LCD_RAM=Binary(FPS[l]);
- // LCD->LCD_RAM=FPS[l];
- l++;
- l = 0;
- /*******顯示原來的數(shù)據(jù)*******/
- for(j=0;j<Y;j++)
- for(i=0;i<X;i++)
- LCD_SetCursor(i+X+10,j);
- FPS[l] = fps[l];
- // LCD->LCD_RAM=Binary(FPS[l]);
- LCD->LCD_RAM=FPS[l];
- l++;
- //RGB565測試
- //RGB數(shù)據(jù)直接顯示在LCD上面
- void rgb565_test(void)
- u8 key;
- u8 k;
- u16 outputheight=0;
- LCD_Clear(WHITE);
- POINT_COLOR=RED;
- //自動對焦初始化
- OV5640_RGB565_Mode(); //RGB565模式
- OV5640_Focus_Init();
- OV5640_Light_Mode(0); //自動模式
- OV5640_Color_Saturation(3);//色彩飽和度0
- OV5640_Brightness(4); //亮度0
- OV5640_Contrast(3); //對比度0
- OV5640_Sharpness(33); //自動銳度
- //OV5640_Focus_Constant();//啟動持續(xù)對焦
- /*************這里初始化PCLK、VSYNC、HSYNC和數(shù)據(jù)口******************/
- DCMI_Init(); //DCMI配置
- DCMI_DMA_Init((u32)fps,0,buf_size,DMA_MDATAALIGN_HALFWORD,DMA_MINC_ENABLE);
- TIM3->CR1&=~(0x01); //關(guān)閉定時器3,關(guān)閉幀率統(tǒng)計,打開的話,RGB屏,在串口打印的時候,會抖
- outputheight=lcddev.height;
- OV5640_OutSize_Set(0,0,X*2,Y*2); //滿屏縮放顯示
- LCD_Clear(BLACK);
- delay_ms(100);
- LCD_SetCursor(0,0);
- DCMI_Start(); //啟動傳輸
- while(1)
- key=KEY_Scan(0);
- if(key==KEY0_PRES)
- OV5640_Focus_Single();
- else if(key==KEY1_PRES)
- k++;
- if(k%2==1)
- OV5640_Flash_Ctrl(1);//打開閃光燈
- else
- OV5640_Flash_Ctrl(0);//關(guān)閉閃光燈
- int main(void)
- HAL_Init(); //初始化HAL庫
- Stm32_Clock_Init(360,25,2,8); //設(shè)置時鐘,180Mhz
- delay_init(180); //初始化延時函數(shù)
- uart_init(115200); //初始化USART
- usart2_init(921600); //初始化USART2
- usmart_dev.init(90); //初始化USMART
- LED_Init(); //初始化LED
- KEY_Init(); //初始化按鍵
- SDRAM_Init(); //初始化SDRAM
- LCD_Init(); //初始化LCD
- TIM3_Init(10000-1,9000-1); //10Khz計數(shù),1秒鐘中斷一次
- POINT_COLOR=BLUE;//設(shè)置字體為紅色
- LCD_ShowString(30,50,200,16,16,"Apollo STM32F4/F7");
- LCD_ShowString(30,70,200,16,16,"OV5640 TEST");
- LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(30,110,200,16,16,"2016/1/16");
- /*************這里初始化一些重要的引腳,SCL,SDA,RESET******************/
- while(OV5640_Init())//初始化OV5640
- LCD_ShowString(30,130,240,16,16,"OV5640 ERR");
- delay_ms(200);
- LCD_Fill(30,130,239,170,WHITE);
- delay_ms(200);
- LED0=!LED0;
- LCD_ShowString(30,130,200,16,16,"OV5640 OK");
- rgb565_test();
下載:
二值化5-成功.rar
(1.03 MB, 下載次數(shù): 172)
2018-3-31 02:40 上傳
下載積分: 黑幣 -5
