查看: 2394|回復: 0
STM32定時器中斷實驗
ID:297022 發表于 2018-3-26 00:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
mian函數
#include "stm32f10x.h"
#include "usart.h"
#include "led.h"
#include "delay.h"
#include "sys.h"
#include "timer.h"
#include "key.h"
#include "timer.h"
#define up 1
#define down 0
int main(void)
    u8  key = 0;
    u8  key1 = 0;
    u8  num0 = 0;
    u8  num1 = 0;
    u8  num2 = 0;
    u8  speed = 1;
    u16 arrLowest = 189;
    u16  arrMax= 409;
    u16 arr =299;
    u16 psc = 359;
    LED_Init();
    delay_init();
    KEY_Init();
    DJ_Init();
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    uart_init(115200);   //串口初始化為115200
    TIM3_Int_Init(arr,psc);//10Khz的計數頻率,計數到100為10ms (arr+1)*(psc+1)/72
        key = KEY_Scan(0);
        if(key == KEY0_PRES)
            if(num0 == 0)
                num0 = 1;
                LED1=0;
                GPIO_ResetBits(GPIOB,GPIO_Pin_6);
                num0 = 0;
                LED1=1;
                GPIO_SetBits(GPIOB,GPIO_Pin_6);
        if(key == KEY1_PRES)
            if(num2 == 0)
                GPIO_SetBits(GPIOG,GPIO_Pin_9);
                num2 = 1;
                GPIO_ResetBits(GPIOG,GPIO_Pin_9);
                num2 = 0;
        while(key == WKUP_PRES)
            if(speed == down)
                arr+=2;
                delay_ms(50);
                key1 = KEY_Scan(0);
                if(arr > arrMax)
                    speed = up;
                if(key1 == WKUP_PRES)//關閉變速
                    LED1 = 0;
                    key = 0;
            if(speed == up)
                arr-=2;
                delay_ms(50);
                if(arr < arrLowest)
                    speed = down;
                key1 = KEY_Scan(0);
                    LED1 = 0;
                    key = 0;
#include "timer.h"
#include "led.h"
void TIM3_Int_Init(u16 arr,u16 psc)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //時鐘使能
    //定時器TIM3初始化
    TIM_TimeBaseStructure.TIM_Period = arr;//自動重裝載寄存器周期的值
    TIM_TimeBaseStructure.TIM_Prescaler = psc;//預分頻值
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;//設置時鐘分割
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上計數模式
    TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
    TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); //使能指定的TIM3中斷,允許更新中斷
    //中斷優先級NVIC設置
    NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;//TIM3中斷
    NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //搶占優先級
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;//響應優先級
    NVIC_Init(&NVIC_InitStructure);
    TIM_Cmd(TIM3,ENABLE);//使能TIMx
void TIM3_IRQHandler(void)//TIM3中斷函數
    if(TIM_GetITStatus(TIM3,TIM_IT_Update) != RESET)//檢查TIM3更新中斷發生與否
        TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//清除TIMx更新中斷標志
        LED0=!LED0;
void DJ_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//使能GPIOB
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG,ENABLE);//使能GPIOG
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;//推挽輸出
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_4;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOB,&GPIO_InitStruct);
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_9;
    GPIO_Init(GPIOG,&GPIO_InitStruct);
