只需一步,快速開(kāi)始
查看: 2289|回復(fù): 1
51單片機(jī)超聲波脈寬測(cè)量程序
ID:295881 發(fā)表于 2018-3-23 12:10 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
超聲波程序單片機(jī)源程序如下:
  1. #include <AT89x51.H>                //器件配置文件
  2. #include <intrins.h>
  3. #define  RX  P1_0
  4. #define  TX  P1_1
  5. #define  z1  P1_6//左傳感器
  6. #define  y1  P1_7 //右傳感器
  7. #define  z1_1  P1_2//左電機(jī)
  8. #define  z1_2  P1_3//左電機(jī)
  9. #define  y1_1  P1_4//左電機(jī)
  10. #define  y1_2  P1_5//左電機(jī)
  11. #define LCM_RW  P2_1 //定義LCD引腳
  12. #define LCM_RS  P2_0
  13. #define LCM_E   P2_2
  14. #define LCM_Data  P0
  15. #define Busy    0x80 //用于檢測(cè)LCM狀態(tài)字中的Busy標(biāo)識(shí)
  16. void LCMInit(void);
  17. void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
  18. void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
  19. void Delay5Ms(void);
  20. void Delay400Ms(void);
  21. void Decode(unsigned char ScanCode);
  22. void WriteDataLCM(unsigned char WDLCM);
  23. void WriteCommandLCM(unsigned char WCLCM,BuysC);
  24. unsigned char ReadDataLCM(void);
  25. unsigned char ReadStatusLCM(void);
  26. unsigned char code Cls[] =      {"                "};
  27. unsigned char code ASCII[20] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M','f','l','a','g',':',' '};
  28. static unsigned char DisNum = 0; //顯示用指針
  29.        unsigned int  time=0,buff=0,buff1=0;
  30.            unsigned long S=0;
  31.            bit      flag =0;
  32.            unsigned char disbuff[4]           ={ 0,0,0,0,};
  33. //寫(xiě)數(shù)據(jù)
  34. void WriteDataLCM(unsigned char WDLCM)
  35. {
  36.         ReadStatusLCM(); //檢測(cè)忙
  37.         LCM_Data = WDLCM;
  38.         LCM_RS = 1;
  39.         LCM_RW = 0;
  40.         LCM_E = 0; //若晶振速度太高可以在這后加小的延時(shí)
  41.         LCM_E = 0; //延時(shí)
  42.         LCM_E = 1;
  43. }
  44. //寫(xiě)指令
  45. void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時(shí)忽略忙檢測(cè)
  46. {
  47.         if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測(cè)忙
  48.         LCM_Data = WCLCM;
  49.         LCM_RS = 0;
  50.         LCM_RW = 0;
  51.         LCM_E = 0;
  52.         LCM_E = 0;
  53.         LCM_E = 1;
  54. }
  55. //讀數(shù)據(jù)
  56. unsigned char ReadDataLCM(void)
  57. {
  58.         LCM_RS = 1;
  59.         LCM_RW = 1;
  60.         LCM_E = 0;
  61.         LCM_E = 0;
  62.         LCM_E = 1;
  63.         return(LCM_Data);
  64. }
  65. //讀狀態(tài)
  66. unsigned char ReadStatusLCM(void)
  67. {
  68.         LCM_Data = 0xFF;
  69.         LCM_RS = 0;
  70.         LCM_RW = 1;
  71.         LCM_E = 0;
  72.         LCM_E = 0;
  73.         LCM_E = 1;
  74.         while (LCM_Data & Busy); //檢測(cè)忙信號(hào)
  75.         return(LCM_Data);
  76. }
  77. void LCMInit(void) //LCM初始化
  78. {
  79.         LCM_Data = 0;
  80.         WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
  81.         Delay5Ms();
  82.         WriteCommandLCM(0x38,0);
  83.         Delay5Ms();
  84.         WriteCommandLCM(0x38,0);
  85.         Delay5Ms();
  86.         WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開(kāi)始要求每次檢測(cè)忙信號(hào)
  87.         WriteCommandLCM(0x08,1); //關(guān)閉顯示
  88.         WriteCommandLCM(0x01,1); //顯示清屏
  89.         WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動(dòng)設(shè)置
  90.         WriteCommandLCM(0x0F,1); // 顯示開(kāi)及光標(biāo)設(shè)置
  91. }
  92. //按指定位置顯示一個(gè)字符
  93. void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
  94. {
  95.         Y &= 0x1;
  96.         X &= 0xF; //限制X不能大于15,Y不能大于1
  97.         if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
  98.         X |= 0x80; //算出指令碼
  99.         WriteCommandLCM(X, 1); //發(fā)命令字
  100.         WriteDataLCM(DData); //發(fā)數(shù)據(jù)
  101. }
  102. //按指定位置顯示一串字符
  103. void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
  104. {
  105.         unsigned char ListLength;
  106.   ListLength = 0;
  107.         Y &= 0x1;
  108.         X &= 0xF; //限制X不能大于15,Y不能大于1
  109.         while (DData[ListLength]>0x19) //若到達(dá)字串尾則退出
  110.                 {
  111.                         if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
  112.                                 {
  113.                                         DisplayOneChar(X, Y, DData[ListLength]); //顯示單個(gè)字符
  114.                                         ListLength++;
  115.                                         X++;
  116.                                 }
  117.                 }
  118. }
  119. //5ms延時(shí)
  120. void Delay5Ms(void)
  121. {
  122.         unsigned int TempCyc = 5552;
  123.         while(TempCyc--);
  124. }
  125. //400ms延時(shí)
  126. void Delay400Ms(void)
  127. {
  128.         unsigned char TempCycA = 5;
  129.         unsigned int TempCycB;
  130.         while(TempCycA--)
  131.                 {
  132.                         TempCycB=7269;
  133.                         while(TempCycB--);
  134.                 };
  135. }
  136. /********************************************************/
  137.     void Conut(void)
  138.         {
  139.          time=TH0*256+TL0;
  140.          TH0=0;
  141.          TL0=0;
  142.          S=(time*1.7)/100;     //算出來(lái)是CM
  143.          if(S<10)
  144.          {
  145.                          buff=1;
  146.          }
  147.          else
  148.          {
  149.          buff=0;
  150.          }
  151.          if((S>=100)||flag==1) //超出測(cè)量范圍顯示“-”
  152.          {
  153.           flag=0;
  154.           DisplayOneChar(0, 0, ASCII[11]);
  155.           DisplayOneChar(1, 0, ASCII[10]);        //顯示點(diǎn)
  156.           DisplayOneChar(2, 0, ASCII[11]);
  157.           DisplayOneChar(3, 0, ASCII[11]);
  158.           DisplayOneChar(4, 0, ASCII[12]);        //顯示M
  159.           DisplayOneChar(5, 0, ASCII[18]);        //顯示M
  160.           DisplayOneChar(6, 0, ASCII[13]);        //顯示M
  161.           DisplayOneChar(7, 0, ASCII[14]);        //顯示M
  162.           DisplayOneChar(8, 0, ASCII[15]);        //顯示M
  163.           DisplayOneChar(9, 0, ASCII[16]);        //顯示M
  164.           DisplayOneChar(10, 0, ASCII[17]);        //顯示M
  165.           DisplayOneChar(11, 0, ASCII[8]);        //顯示M
  166.          }
  167.          else
  168.          {
  169.           disbuff[0]=S%1000/100;
  170.           disbuff[1]=S%1000%100/10;
  171.           disbuff[2]=S%1000%10 %10;
  172.           DisplayOneChar(0, 0, ASCII[disbuff[0]]);
  173.           DisplayOneChar(1, 0, ASCII[10]);        //顯示點(diǎn)
  174.           DisplayOneChar(2, 0, ASCII[disbuff[1]]);
  175.           DisplayOneChar(3, 0, ASCII[disbuff[2]]);
  176.           DisplayOneChar(4, 0, ASCII[12]);        //顯示M
  177.           DisplayOneChar(5, 0, ASCII[18]);        //顯示M
  178.           DisplayOneChar(6, 0, ASCII[13]);        //顯示M
  179.           DisplayOneChar(7, 0, ASCII[14]);        //顯示M
  180.           DisplayOneChar(8, 0, ASCII[15]);        //顯示M
  181.           DisplayOneChar(9, 0, ASCII[16]);        //顯示M
  182.           DisplayOneChar(10, 0, ASCII[17]);        //顯示M
  183.           DisplayOneChar(11, 0, ASCII[8]);        //顯示M
  184.          }
  185.         }
  186. /********************************************************/
  187.      void zd0() interrupt 1                  //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
  188.   {
  189.     flag=1;                                                         //中斷溢出標(biāo)志
  190.   }
  191. /********************************************************/
  192.      void  StartModule()                          //啟動(dòng)模塊
  193.   {
  194.           TX=1;                                             //啟動(dòng)一次模塊
  195.           _nop_();
  196.           _nop_();
  197.           _nop_();
  198.           _nop_();
  199.           _nop_();
  200.           _nop_();
  201.           _nop_();
  202.           _nop_();
  203.           _nop_();
  204.           _nop_();
  205.           _nop_();
  206.           _nop_();
  207.           _nop_();
  208.           _nop_();
  209.           _nop_();
  210.           _nop_();
  211.           _nop_();
  212.           _nop_();
  213.           _nop_();
  214.           _nop_();
  215.           _nop_();
  216.           TX=0;
  217.   }
  218. /********************************************************/
  219. void delayms(unsigned int ms)
  220. {
  221.         unsigned char i=100,j;
  222.         for(;ms;ms--)
  223.         {
  224.                 while(--i)
  225.                 {
  226.                         j=10;
  227.                         while(--j);
  228.                 }
  229.         }
  230. }
  231. void qianjin()
  232. {         z1_1 =1;
  233.          z1_2 =0;
  234.          y1_1 =1;
  235.          y1_2 =0;
  236.          }
  237. void tingzhi()
  238. {
  239.    z1_1 =1;
  240.          z1_2 =1;
  241.          y1_1 =1;
  242.          y1_2 =1;
  243. }
  244. void zuozhuan()
  245. {
  246.          z1_1 =1;
  247.          z1_2 =1;
  248.          y1_1 =1;
  249.          y1_2 =0;
  250. }
  251. void youzhuan()
  252. {
  253.    z1_1 =1;
  254.          z1_2 =0;
  255.          y1_1 =1;
  256.          y1_2 =1;
  257. }
  258. /*********************************************************/
  259. void main(void)
  260. {
  261.         unsigned char TempCyc;
  262.         Delay400Ms(); //啟動(dòng)等待,等LCM講入工作狀態(tài)
  263.         LCMInit(); //LCM初始化
  264.         for (TempCyc=0; TempCyc<10; TempCyc++)
  265.         Delay400Ms(); //延時(shí)
  266.         DisplayListChar(0, 1, Cls);
  267.         while(1)
  268.         {
  269.          TMOD=0x01;                   //設(shè)T0為方式1,GATE=1;
  270.          TH0=0;
  271.          TL0=0;
  272.          ET0=1;             //允許T0中斷
  273.          EA=1;                           //開(kāi)啟總中斷
  274.         while(1)
  275.           {
  276.              StartModule();
  277.                 // DisplayOneChar(0, 1, ASCII[0]);
  278.              while(!RX)
  279.                  {
  280.                  if(z1==0&&y1==0&&buff==0)
  281.                  {qianjin();
  282.                  buff1=1;}
  283. ……………………
  284. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
超聲波LC1602顯示.zip (48.72 KB, 下載次數(shù): 11)
ID:337646 發(fā)表于 2018-5-24 21:55 來(lái)自觸屏版 | 只看該作者
樓主好厲害
