hc-sr501人體紅外模塊介紹與電路原理圖,附件里面包含arduino平臺和51單片機源程序
- The name of the program: <Pyroelectric sensor module>
- Date: 2012 04 09
- hardware:mcu(stc12c5a60s2),Operational Amplifier(lm324),Pyroelectric sensor module,etc
- #include<stc12c5a60s2.h>
- #define uchar unsigned char
- #define uint unsigned int
- void Delay_us(unsigned int x)
- while(x--);
- void delay(int x)
- uchar i,j;
- for(i=0;i<x;i++)
- for(j=0;j<110;j++);
- void ADC_one() //Only channel P1.0
- P1ASF=0x1f;
- ADC_CONTR=0x00;
- AUXR1=0x00;
- ADC_CONTR=0x80;
- Delay_us(2);
- ADC_CONTR=0x88;
- Delay_us(2);
- while(ADC_CONTR==0x88);
- ADC_CONTR=0;
- void main()
- while(1)
- float num=0;
- uint resl=0;
- ADC_one();
- resl=ADC_RES;
- resl=(resl<<2)+ADC_RESL;
- num=resl/1024.0*5;
- num=num*1000;
- if(num>2700)
- P2=0XEF;//Light-emitting diode is lit
- else
- P2=0XFF; //Light-emitting diode is extinguished
HC-SR501 人體紅外感應模塊 熱釋電 紅外傳感器 探頭 .rar
(2.62 MB, 下載次數(shù): 47)
2018-3-19 12:06 上傳
人體紅外
