我的電路原理圖能實現(xiàn)功能,但到了實物圖就會出現(xiàn)蜂鳴器一直響,密碼總是不正確。這究竟是什么原因?求求打什么指導(dǎo)
main函數(shù):
#include <reg52.h>
#include "delay_ms.h"
#include "矩陣鍵盤.h"
#include "i2c.h"
#include "1602.h"
#include "mima.h"
#define A 0x0a //輸入密碼
#define B 0x0b //修改密碼
#define D 0x0d //關(guān)鎖
#define enter 0x0c //確認(rèn)
#define backspace 0x0f //退格鍵
sbit baojing = P3^7; //蜂鳴器接口
sbit lock = P3^3;//鎖信號
sbit set = P3^2;
uchar idata mima_5[6] = {1,2,3,4,5,6}; //初始密碼
uchar flag_change;
uchar aa;//存放密碼錯誤的次數(shù),夠三次報警
uchar bb;
uchar flag_t0;
void baoj1()//報警函數(shù)
int i;
for(i = 0;i < 5; i++)
baojing = 1;
delay_ms(5);
baojing = 0;
delay_ms(5);
void baoj()
uchar i;
for(i = 0; i < 10; i++)
baoj1();
/*密碼處理函數(shù)*/
void mimachuli()
uchar key,i;
uchar idata mima_1[6]={' ',' ',' ',' ',' ',' '};//存放密碼緩沖區(qū)
uchar idata mima_2[6]={' ',' ',' ',' ',' ',' '};
uchar idata mima_3[6]={' ',' ',' ',' ',' ',' '};
key = step_choose();
if(key == A)//A被按下,接收輸入密碼,處理
read_n_add(mima_1,0x00,6);
write_com(0x06);//寫一個字符后地址指針加 1
write_com(0x01);//顯示清零,數(shù)據(jù)指針清零
write_com(0x0f);//顯示光標(biāo)
lcd_pos(0,0);
write_n_char(" press password ");
if(input_mima(mima_2)) //處理輸入密碼
if(mimaduibi(mima_2,mima_1)) //密碼正確
lcd_pos(0,0);
write_com(0x0c);
write_n_char(" password right ");
aa = 0; //清除密碼錯誤次數(shù)
lock = 0; //開鎖
baojing = 1; //響一下
delay_ms(1000);
baojing = 0;
TR0 = 1;
flag_t0 = 1;
while(key != D && flag_t0) //D沒按下一直開
key = keyscan();
TR0 = 0;
lock = 1;//D按下了關(guān)鎖
else //密碼 不正確
lcd_pos(0,0);
write_com(0x0c); //關(guān)光標(biāo)
write_n_char(" password wrong");
delay_ms(1000);
aa++;
if(aa == 4)
aa = 0;
i = 20; //密碼不正確報警
while(i--)
baoj();
else //密碼沒有輸入正確或完成
lcd_pos(0,0);
delay_ms(1000);
aa++;
if(aa == 4)
aa = 0;
i = 20; //密碼不正確報警
while(i--)
baoj();
if(key == B)//B被按下,修改密碼
lcd_pos(0,0);
write_n_char(" input password");
lcd_pos(0,0);
write_com(0x0c);
write_n_char("password right ");
delay_ms(1500);
flag_change = 1;
while(flag_change) //下面開始修改密碼
lcd_pos(0,0);
write_n_char("In new password");
delay_ms(1500);
lcd_pos(0,0);
write_com(0x0c);
write_n_char("Input new pass"); //確定新密碼
lcd_pos(1,0);
write_n_char("word again");
delay_ms(2000);
lcd_pos(0,0);
if(input_mima(mima_3)) //處理輸入密碼
if(mimaduibi(mima_2,mima_3)) //密碼正確
lcd_pos(0,0);
write_com(0x0c);
write_n_char("password has");
lcd_pos(1,0);
write_n_char("change already");
write_n_add(mima_3,0x00,6); //把修改的密碼存進(jìn)24C02
delay_ms(2000);
flag_change = 0;
else //密碼 不正確
lcd_pos(0,0);
write_n_char("password wrong");
delay_ms(1000);
aa++;
if(aa == 4)
aa = 0;
i = 20; //3次輸入密碼不正確報警
while(i--)
baoj();
flag_change = 0;
else //密碼沒有輸入正確或完成
lcd_pos(0,0);
delay_ms(1000);
aa++;
if(aa == 4)
aa = 0;
while(i--)
baoj();
else //密碼沒有輸入正確或完成
lcd_pos(0,0);
delay_ms(1000);
flag_change = 0;
aa++;
if(aa == 4)
aa = 0;
while(i--)
baoj();
else //密碼 不正確
lcd_pos(0,0);
delay_ms(1000);
aa++;
if(aa == 4)
aa = 0;
while(i--)
baoj();
else //密碼沒有輸入正確或完成
lcd_pos(0,0);
delay_ms(1000);
aa++;
if(aa == 4)
aa = 0;
while(i--)
baoj();
/*外部中斷函數(shù),恢復(fù)出廠設(shè)置,長按set鍵恢復(fù)*/
void int0() interrupt 0
delay_ms(2000);
if(!set)
lcd_pos(0,0);
i2cinit();//24C02總線初始化
write_n_add(mima_5,0x00,6);
write_n_char("password renew");
lcd_pos(1,0);
write_n_char("already");
delay_ms(1000);
lcd_pos(0,0);
write_n_char("Input password");
lcd_pos(1,0);
write_n_char("Press key A");
}// 引起了三個警告
void timer0() interrupt 1 //定時器0中斷,50ms定時
TH0 = 0x4c;//50ms定時
TL0 = 0x00;
bb++;
if(bb == 200)//10秒時間到
bb = 0;
flag_t0 = 0;
yjinit();//液晶初始化
baojing = 0;
lock = 1; //關(guān)鎖
TMOD = 0x01;//選擇定時器0方式1
EA = 1;//打開總中斷
ET0 = 1;//打開定時器0中斷
EX0 = 1; //打開外部中斷0
IT0 = 1;//下降沿觸發(fā)
TR0 = 0;//關(guān)閉定時器
TH0 = 0x4c;//50ms裝初值
TL0 = 0x00;
mimachuli();
