查看: 18736|回復: 26
51單片機控制DHT11在1602上顯示溫濕度的程序
ID:199245 發表于 2018-3-15 19:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
需要的拿去
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. typedef bit BOOL;
  5. sbit io = P2^0;
  6. sbit rs = P2^6;
  7. sbit rw = P2^5;
  8. sbit ep = P2^7;
  9. uchar data_byte;
  10. uchar RH,RL,TH,TL;
  11. /********延時模塊***********/
  12. void delay(uchar ms)
  13. {  // 延時子程序
  14. uchar i;
  15. while(ms--)
  16. {
  17.   for(i = 0;i<250;i++);
  18. }
  19. }
  20. void delay1()//延時10us
  21. {
  22. uchar i;
  23. i--;
  24. i--;
  25. i--;
  26. i--;
  27. i--;
  28. i--;
  29. }
  30. void longdelay(uchar s) //長延時
  31. {
  32. while(s--)
  33. {
  34.   delay(60);
  35. }
  36. }
  37. BOOL lcd_bz()//測試LCD忙碌狀態
  38. {
  39. BOOL result;
  40. rs = 0;
  41. rw = 1;
  42. ep = 1;
  43. result = (BOOL)(P0 & 0x80);
  44. ep = 0;
  45. return result;
  46. }
  47. void write_cmd(uchar cmd)// 寫指令
  48. {
  49. while(lcd_bz());
  50. rs = 0;
  51. rw = 0;
  52. ep = 0;
  53. P0 = cmd;
  54. ep = 1;
  55. ep = 0;
  56. }
  57. void write_addr(uchar addr)//寫地址
  58. {
  59. write_cmd(addr|0x80);
  60. }
  61. void write_byte(uchar dat)//寫字節
  62. {
  63. while(lcd_bz());
  64. rs = 1;
  65. rw = 0;
  66. ep = 0;
  67. P0 = dat;
  68. ep = 1;
  69. ep = 0;
  70. }
  71. void lcd_init()// 初始化
  72. {
  73. write_cmd(0x38);
  74. delay(1);
  75.   write_cmd(0x08);
  76. delay(1);
  77. write_cmd(0x01);
  78. delay(1);
  79. write_cmd(0x06);
  80. delay(1);
  81. write_cmd(0x0c);
  82. delay(1);
  83. }
  84. void display(uchar addr, uchar q)//在某一地址上顯示一字節
  85. {
  86. delay(10);
  87. write_addr(addr);
  88. write_byte(q);
  89. longdelay(2);
  90. }
  91. void start()//開始信號
  92. {
  93. io=1;
  94. delay1();
  95. io=0;
  96. delay(20);//>18ms
  97. io=1;
  98. delay1();//20-40us
  99. delay1();
  100. delay1();
  101. delay1();
  102. delay1();
  103. }
  104. uchar receive_byte()//接收一個字節
  105. {
  106. uchar i,temp,count;
  107. for(i=0;i<8;i++)
  108. {
  109.    count=2;
  110.   while((!io)&&count++)//等待50us低電平結束
  111.   temp=0;
  112.   delay1();
  113.   delay1();
  114.   delay1();
  115.   delay1();
  116.    if(io==1)
  117.   temp=1;
  118.   count=2;
  119.   while((io)&&count++);
  120.   if(count==1)break;
  121. data_byte<<=1;
  122.   data_byte|=temp;
  123. }
  124. return data_byte;
  125. }
  126. void receive()//接收數據
  127. {
  128. uchar T_H,T_L,R_H,R_L,check,num_check;
  129.    uchar count;
  130. start();//開始信號
  131. io=1;
  132. if(!io)//讀取DHT11響應信號
  133. {
  134.   count=2;
  135.   while((!io)&&count++);//DHT11高電平80us是否結束
  136.   count=2;
  137.   while((io)&&count++);
  138.   R_H=receive_byte();
  139.   R_L=receive_byte();
  140.   T_H=receive_byte();
  141.   T_L=receive_byte();
  142.   check=receive_byte();
  143.   io=0;//拉低延時50us
  144.   delay1();
  145.    delay1();
  146.   delay1();
  147.   delay1();
  148.   delay1();
  149.   io=1;
  150.   num_check=R_H+R_L+T_H+T_L;
  151.   if(num_check=check)
  152.   {
  153.    RH=R_H;
  154. RL=R_L;
  155. TH=T_H;
  156. TL=T_L;
  157. check=num_check;
  158.   }
  159. }
  160. }
  161. void main()
  162. {
  163. lcd_init();
  164. delay(10);
  165. while(1)
  166. {
  167.   receive();
  168.   delay(100);
  169.   display(0x00,'R');
  170.   display(0x01,':');
  171.   display(0x02,RH/10+0x30);
  172.    display(0x03,RH%10+0x30);
  173.   display(0x04,'%');
  174.   display(0x40,'T');
  175.   display(0x41,':');
  176.   display(0x42,TH/10+0x30);
  177.   display(0x43,TH%10+0x30);
  178. display(0x44,0xdf);
  179.   display(0x45,0x43);
  180. }
  181. }
程序.rar (29.75 KB, 下載次數: 344)
收藏收藏7 分享淘帖 頂1 踩
來自 2#
ID:427492 發表于 2019-7-14 21:35 | 只看該作者
我找到一個時序是對的,你們可以參考一下:
/*********************** DHT11測試模塊***************************************/
void start()//開始信號
         io=0;
         delay(18);//>18ms
         io=1;
         delay1();//20-40us
         delay1();
         delay1();
         delay1();
         uchari;
         for(i=0;i<8;i++)
             data_byte<<=1;        //循環左移
                  while(!io);        //每發送一位數據間隔50us低電平
                  delay1();delay1();delay1();delay1();        //延遲40us
                  if(io==1)
                    data_byte=data_byte|0x01;
                    while(io);
                   data_byte=data_byte|0x00;
         returndata_byte;
         ucharT_H,T_L,R_H,R_L,check;
         start();//開始信號
         io=1;
   while(!io) ;                                    //判斷輸出低電平
   while( io) ;                                                            //判斷輸出高電平
         R_H=receive_byte();
         R_L=receive_byte();
         T_H=receive_byte();
         T_L=receive_byte();
         io=0;
         delay1();delay1();delay1();delay1();delay1();//拉低延時50us
         io=1;
         if(R_H+R_L+T_H+T_L==check)                        //矯正
                  RH=R_H;
                  RL=R_L;
                  TH=T_H;
                  TL=T_L;
ID:299721 發表于 2018-3-30 23:51 | 只看該作者
厲害了
ID:77707 發表于 2018-3-31 08:45 | 只看該作者
不錯,通過編譯。需要溫度傳感器,才能實現測溫。
ID:299278 發表于 2018-3-31 10:54 | 只看該作者
有protues仿真圖嗎
ID:299931 發表于 2018-4-1 16:11 | 只看該作者
為啥數據顯示一直是0
ID:308121 發表于 2018-4-14 18:28 | 只看該作者
51宅男 發表于 2018-4-1 16:11
為啥數據顯示一直是0
你解決問題了嗎?
ID:382962 發表于 2018-8-11 16:54 | 只看該作者
顯示一直是0
ID:294657 發表于 2018-9-2 21:55 | 只看該作者
是1602顯示嗎,為什么我的沒有顯示呢
ID:303383 發表于 2018-9-2 22:55 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
ID:291850 發表于 2018-10-27 11:19 | 只看該作者
溫濕度一直是0是什么情況啊?小白不太懂啊
ID:291850 發表于 2018-10-27 13:25 | 只看該作者
貌似DHT11數據一直沒收到
ID:85740 發表于 2019-3-13 09:29 | 只看該作者
11.0592 stc89c52rc實測無法成功和dht11通信成功。
ID:368574 發表于 2019-3-16 15:37 | 只看該作者
beyonbirth 發表于 2018-10-27 13:25
貌似DHT11數據一直沒收到
我的也是只顯示0
ID:501427 發表于 2019-4-4 19:24 | 只看該作者
解決了嗎?我也顯示是0,什么情況啊
ID:243819 發表于 2019-4-5 13:02 | 只看該作者
先贊一個!
ID:182535 發表于 2019-4-27 15:20 | 只看該作者
正好需要。。。。。。。。。
ID:520461 發表于 2019-5-6 20:16 | 只看該作者
貌似DHT11數據一直沒收到
解決了沒
ID:545996 發表于 2019-7-2 22:16 | 只看該作者
顯示0怎么辦
ID:427492 發表于 2019-7-14 21:18 | 只看該作者
時序有問題,就一直顯示初始化時的值
ID:623338 發表于 2019-11-10 12:55 | 只看該作者
你們解決了嗎
ID:56204 發表于 2019-11-29 02:50 來自觸屏版 | 只看該作者
113333 發表于 2019-11-10 12:55
你們解決了嗎
學習一下,感謝分享
ID:631951 發表于 2019-11-29 10:34 | 只看該作者
楓樹566 發表于 2019-7-14 21:35
/*********************** DHT11測試模塊******************** ...
我用了你這個,也不好用 啊,一直顯示00
ID:638896 發表于 2019-12-5 20:25 | 只看該作者
不行,啥都不顯示,大家別看了,去找下一個。
ID:638896 發表于 2019-12-6 11:00 | 只看該作者
不行,顯示不了。
ID:791947 發表于 2020-6-29 16:09 | 只看該作者
為什么我的是什么都不顯示
