查看: 6253|回復: 2
stm32f107智嵌以太網IAP遠程更新附源代碼和說明文件
附IAP遠程更新源代碼和說明文件
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32_eth.h"
  3. #include "netconf.h"
  4. #include "main.h"
  5. #include "helloworld.h"
  6. #include "httpd.h"
  7. #include "tftpserver.h"
  8. #include "KEY.H"
  9. #include "stdio.h"
  10. #include "bkp.h"
  11. #include "LED.H"
  12. /* Private typedef -----------------------------------------------------------*/
  13. /* Private define ------------------------------------------------------------*/
  14. #define SYSTEMTICK_PERIOD_MS  10
  15. #ifdef __GNUC__
  16.   /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
  17.      set to 'Yes') calls __io_putchar() */
  18.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  19. #else
  20.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  21. #endif /* __GNUC__ */
  22. /* Private macro -------------------------------------------------------------*/
  23. /* Private variables ---------------------------------------------------------*/
  24. __IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */
  25. uint32_t timingdelay;
  26. typedef  void (*pFunction)(void);
  27. pFunction Jump_To_User_Application;
  28. uint32_t Jump_User_Address;
  29. /* Private function prototypes -----------------------------------------------*/
  30. void System_Periodic_Handle(void);
  31. void IAP_httpd_init(void);
  32. void IAP_tftpd_init(void);
  33. void MY_NVIC_Configuration(void);
  34. void NVIC_DeInit(void);
  35. void BKP_Configuration(void);
  36. void MCU_Reset(void);
  37. void EARES_SRAM(void);
  38. void NVIC_Configuration(void);
  39. /* Private functions ---------------------------------------------------------*/
  40. /**
  41.   * @brief  Main program.
  42.   * @param  None
  43.   * @retval None
  44.   */
  45.
  46. int main(void)
  47. {
  48.         unsigned int g_bUpdateFlag = 0;
  49.         NVIC_DeInit();
  50.         RCC_DeInit();
  51.         SystemInit();
  52.         BKP_Configuration();
  53.         NVIC_Configuration();
  54.         SEI(); //開全局中斷
  55.         g_bUpdateFlag = BKP_ReadBackupRegister(BKP_DR9);  //讀取更新標志
  56.         //if(!(KEY1 | KEY2 | KEY3 | KEY4)
  57.         if(g_bUpdateFlag  == 0x0)     //不需要升級,
  58.         {
  59.                 /* Check if valid stack address (RAM address) then jump to user application */
  60.                 if (((*(__IO uint32_t*)USER_FLASH_FIRST_PAGE_ADDRESS) & 0x2FFE0000 ) == 0x20000000)
  61.                 {
  62.                         CLI();                        //關閉總中斷,必須有、
  63.                         NVIC_DeInit();
  64.                         RCC_DeInit();
  65.                         /* Jump to user application */
  66.                         Jump_User_Address = *(__IO uint32_t*) (USER_FLASH_FIRST_PAGE_ADDRESS + 4);
  67.                         Jump_To_User_Application = (pFunction) Jump_User_Address;
  68.                         /* Initialize user application's Stack Pointer */
  69.                         __set_MSP(*(__IO uint32_t*) USER_FLASH_FIRST_PAGE_ADDRESS);
  70.                         Jump_To_User_Application();
  71.                         while (1);
  72.                 }
  73.                 else
  74.                 {
  75.                         //printf("非法SRAM\n");
  76.                 }
  77.         }
  78.
  79.    else         //初始化網絡模塊,等待用戶遠程登錄,更新固件
  80.    {
  81.                 /* Setup STM32 system (clocks, Ethernet, GPIO, NVIC) and STM3210C-EVAL resources */
  82.                 BKP_WriteBackupRegister(BKP_DR9,0x00);// 標志已經下載了程序了
  83.                 System_Setup();
  84.                 /* Initilaize the LwIP satck ip地址設置,mac設置,*/
  85.                 LwIP_Init();
  86.
  87.                 IAP_httpd_init();
  88.                 /* Infinite loop */
  89.                 while (1)
  90.                 {
  91.                       /* Periodic tasks */
  92.                     System_Periodic_Handle();
  93.                 }
  94.         }
  95. }
  96. void MCU_Reset(void)
  97. {
  98.         __disable_fault_irq();      // STM32 軟復位
  99.         NVIC_SystemReset();
  100. }
  101. PUTCHAR_PROTOTYPE
  102. {
  103.   /* Place your implementation of fputc here */
  104.   /* e.g. write a character to the USART */
  105.   USART_SendData(USART2, (uint8_t) ch);
  106.   /* Loop until the end of transmission */
  107.   while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET)
  108.   {}
  109.   return ch;
  110. }
  111. /**
  112.   * @brief  Inserts a delay time.
  113.   * @param  nCount: number of 10ms periods to wait for.
  114.   * @retval None
  115.   */
  116. void Delay(uint32_t nCount)
  117. {
  118.   /* Capture the current local time */
  119.   timingdelay = LocalTime + nCount;
  120.   /* wait until the desired delay finish */
  121.   while(timingdelay > LocalTime)
  122.   {
  123.   }
  124. }
  125. /**
  126.   * @brief  Updates the system local time
  127.   * @param  None
  128.   * @retval None
  129.   */
  130. void Time_Update(void)
  131. {
  132.   LocalTime += SYSTEMTICK_PERIOD_MS;
  133. }
  134. /**
  135.   * @brief  Handles the periodic tasks of the system
  136.   * @param  None
  137.   * @retval None
  138.   */
  139. void System_Periodic_Handle(void)
  140. {
  141.   /* Update the LCD display and the LEDs status */
  142.   /* Manage the IP address setting */
  143.   Display_Periodic_Handle(LocalTime);
  144.
  145.   /* LwIP periodic services are done here */
  146.   LwIP_Periodic_Handle(LocalTime);
  147. }
  148. #ifdef  USE_FULL_ASSERT
  149. ……………………
  150. …………限于本文篇幅 余下代碼請從51黑下載附件…………
智嵌以太網遠程更新.7z (6.42 MB, 下載次數: 176)
收藏收藏2 分享淘帖 頂1 踩
ID:319585 發表于 2018-12-9 14:10 | 只看該作者
這個不錯的,需要的,我還需要串口通信的例子
ID:272158 發表于 2021-8-9 14:57 | 只看該作者
我這里油串口通訊的》,智嵌
