查看: 3294|回復: 0
STM32 BOOTLAOD源代碼工程學習
ID:288985 發表于 2018-3-8 00:09 | 顯示全部樓層 |閱讀模式
窗口看門狗
中斷中喂狗。如果沒有喂狗。就會產生復位
完整程序源代碼工程文件下載地址
  1. #include"public.h"
  2. const unsigned char *sysfile[1]=
  3. {
  4. "STM32.BIN"
  5. };
  6. u8 UpData(void);
  7. int main(void)
  8. {
  9.     u8 sd_check,fat_check,i;
  10.
  11.     Init_All();
  12.     while(1)
  13.     {
  14.         //如果SD卡FAT初始化OK了進入升級
  15.           if(SD_Initialize()==0)
  16.           {
  17.               LCD_ShowString(20,20,"Sd Check OK",WHITE);
  18.               sd_check=1;
  19.           }
  20.           else
  21.           {
  22.              LCD_ShowString(20,20,"Sd Check fail",WHITE);
  23.              sd_check=0;
  24.           }
  25.           if(FAT_Init()==0)
  26.           {
  27.              LCD_ShowString(20,40,"Fat Initial OK",WHITE);
  28.              fat_check=1;
  29.           }
  30.           else
  31.           {
  32.              LCD_ShowString(20,40,"Fat Initial fail",WHITE);
  33.              fat_check=0;
  34.           }
  35.
  36.           if(sd_check&&fat_check)
  37.             {
  38.                 LCD_ShowString(20,60,"Enter updata after 3s",WHITE);
  39.                 LCD_ShowString(210,60,"s",WHITE);
  40.                 for(i=3;i>0;i--)
  41.                 {
  42.                     LCD_Show_Num(190,60,i,2, 16, RED);
  43.                     delay_ms(1000);
  44.                 }
  45.                 LCD_Show_Num(190,60,i,2, 16, RED);
  46.                 if(UpData()==0)
  47.                 {
  48.                     LCD_ShowString(20,100,"UpData Success",WHITE);
  49.                 }
  50.                 else
  51.                 {
  52.                     LCD_ShowString(20,100,"UpData fail",WHITE);
  53.                 }
  54.                 LCD_ShowString(20,120,"Enter APP after 3s",WHITE);
  55.                 LCD_ShowString(210,120,"s",WHITE);
  56.                 for(i=3;i>0;i--)
  57.                 {
  58.                     LCD_Show_Num(190,120,i,2, 16, RED);
  59.                     delay_ms(1000);
  60.                 }
  61.                 LCD_Show_Num(190,120,i,2, 16, RED);
  62.             }
  63.            iap_load_app(FLASH_APP1_ADDR);
  64.     }
  65. }
  66. u8 temp[512];  //零時空間
  67. u8 UpData(void)
  68. {
  69.     u32 fcluster=0;
  70.     u32 i;
  71.         FileInfoStruct FileTemp;//零時文件夾
  72.         //得到根目錄的簇號
  73.         if(FAT32_Enable)fcluster=FirstDirClust;
  74.         else fcluster=0;
  75.     FileTemp=F_Search(fcluster,(unsigned char *)sysfile[0],T_BIN);//根目錄下查找BIN文件
  76.
  77.     if(FileTemp.F_StartCluster==0) {LCD_ShowString(20,80,"bin was lost",WHITE);return 1 ;}
  78.     LCD_ShowString(20,80,"find bin success",WHITE);
  79.
  80.     F_Open(&FileTemp);//打開該文件
  81.     i=0;
  82.
  83.     while(F_Read(&FileTemp,temp))//成功讀出512個字節
  84.         {
  85.                 if(i<FileTemp.F_Size)//不超過文件大小
  86.                 {
  87.                         iap_write_appbin(FLASH_APP1_ADDR+i,temp,512);//更新FLASH代碼
  88.                         //LCD_Show_Bar(50, 155, 15, 150,i, FileTemp.F_Size, RED,WHITE);
  89.                         i+=512;//增加512個字節
  90.                         if(i>FileTemp.F_Size) i=FileTemp.F_Size;
  91.             LED0=~LED0;
  92.             LCD_Show_Bar(50, 155, 15, 150,i, FileTemp.F_Size, RED,WHITE);
  93.             LCD_ShowString(125,170,"%",WHITE);
  94.             LCD_Show_Num(100,170, 100*i/FileTemp.F_Size,3, 16, RED);
  95.                 }
  96.         }
  97.         return 0;
  98. }
bootloader.rar (417.33 KB, 下載次數: 22)
