查看: 1902|回復: 0
這是僅僅有一小部分功能的計算器程序,但液晶去沒反應;求各位指出問題
ID:284007 發表于 2018-3-7 13:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是僅僅有一小部分功能的計算器程序,但液晶去沒反應;求各位指出問題;
  #include<reg52.h>
sbit rs=P2^6;
sbit wr=P2^5;
sbit len=P2^7;
uchar annum,num,date;
uchar dis[16];
void delay(uint z)
        uint x,y;
        for(x=z;z>0;x--)
                for(y=110;y>0;y--);
void  write_com(uchar com)
        rs=0;
        P0=com;
        delay(5);
        len=1;
        delay(5);
        len=0;
void write_date(uchar date)
        rs=1;
        P0=date;
        delay(5);
        len=1;
        delay(5);
        len=0;
void keyscan()
        uchar temp,key;
        P3=0xfe;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                         temp=P3;
                        switch(temp)
                                case 0xee:
                                num=0;
                                break;
                                annum++;
                                case 0xde:
                                num=1;
                                annum++;
                                break;
                                case 0xbe:
                                num=2;
                                annum++;
                                break;
                                case 0x7e:
                                num=3;
                                annum++;
                                break;
                        while(temp!=0xf0);
                                P3=temp;
                                temp=temp&0xf0;
        P3=0xfd;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xed:
                                num=4;
                                annum++;
                                break;
                                case 0xdd:
                                num=5;
                                annum++;
                                break;
                                case 0xbd:
                                num=6;
                                annum++;
                                break;
                                case 0x7d:
                                num=7;
                                annum++;
                                break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
        P3=0xfb;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xeb:
                                num=8;
                                annum++;
                                break;
                                case 0xdb:
                                num=9;
                                annum++;
                                break;
                                case 0xbb:
                                num=10;
                                break;
                                case 0x7b:
                                num=11;
                                break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
        P3=0xf7;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xe7:
                                num=12;
                                break;
                                case 0xd7:
                                num=13;
                                case 0xb7:
                                num=14;
                                break;
                                case 0x77:
                                num=15;
                                break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp&0xf0;
uchar keysuan(uchar date)
          if(num==0)
                date=date+(num*annum*10);
        if(num==1)
        if(num==2)
        if(num==3)
        if(num==4)
        if(num==4)
        if(num==5)
        if(num==6)
        if(num==7)
        if(num==8)
        if(num==9)
                {date=date+(num*annum*10);}
                return date;
void jisuan()
        write_com(0x80+0x40+16);
        dis[0]=date%10+0x30;
        dis[1]=date/10%10+0x30;
        dis[2]=date/100%10+0x30;
        dis[3]=date/1000%10+0x30;
        dis[4]=date/10000%10+0x30;
        dis[5]=date/100000%10+0x30;
        dis[6]=date/1000000%10+0x30;
        dis[7]=date/10000000%10+0x30;
        dis[8]=date/100000000%10+0x30;
        dis[9]=date/1000000000%10+0x30;
        dis[10]=date/10000000000%10+0x30;
void display()
  uchar i=0;
        write_com(0x80+0x50);
        while(dis[i]!='\0')
                write_date(dis[i]);
                i++;
        i=0;
void init()
    date=0;
        wr=0;
        write_com(0x38);
        write_com(0x0f);
        write_com(0x04);
        write_com(0x01);
        init();
          keyscan();
          keysuan();
          jisuan();
          display();
