查看: 2120|回復(fù): 0
STM32 16通道ADC
ID:287405 發(fā)表于 2018-3-4 12:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#define ADC1_DR_Address    ((u32)0x40012400+0x4c)
__IO uint16_t ADC_ConvertedValue;
//__IO u16 ADC_ConvertedValueLocal;
  * @brief  ê1ÄüADC1oíDMA1μÄê±Öó£¬3õê¼»ˉPC.0
  * @param  ÎT
  * @retval ÎT
static void ADC1_GPIO_Config(void)
        /* Enable DMA clock */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* Enable ADC1 and GPIOC clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC, ENABLE);
        /* Configure PA.0 - 7 as analog input */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        /* Configure PB.0 - 1 as analog input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* Configure PC.0  as analog input */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;;
        GPIO_Init(GPIOC, &GPIO_InitStructure);                                // PC0,êäèëê±2»óÃéèÖÃËùÂê
  * @brief  ÅäÖÃADC1μÄ1¤×÷Ä£ê½ÎaMDAÄ£ê½
  * @param  ÎT
  * @retval ÎT
static void ADC1_Mode_Config(void)
        DMA_InitTypeDef DMA_InitStructure;
        ADC_InitTypeDef ADC_InitStructure;
        /* DMA channel1 configuration */
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;                                 //ADCμØÖ·
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //Äú′æμØÖ·
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 320;  // DMAí¨μàμÄDMA»o′æ′óD¡ = N·ADC * ÿ¸öí¨μà×a»»′Îêy
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //íaéèμØÖ·1춨
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                  //Äú′æμØÖ·μYÔö
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //°ë×Ö
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;  //êy¾Y¿í¶è16λ
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Ñ-»·′«êä
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        /* Enable DMA channel1 */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        /* ADC1 configuration */
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;                        //¶àá¢ADCÄ£ê½
        ADC_InitStructure.ADC_ScanConvMode = ENABLE ;                                          //é¨Ãèģ꽣¬é¨ÃèÄ£ê½óÃóú¶àí¨μà2é¼ˉ
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                        //¿aÆôá¬Dø×a»»Ä£ê½£¬¼′2»í£μؽøDDADC×a»»
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //2»ê1óÃía2¿′¥·¢×a»»
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //2é¼ˉêy¾Yóò¶ÔÆë
        ADC_InitStructure.ADC_NbrOfChannel = 16;        //òa×a»»μÄí¨μàêyÄ¿1
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5);//Ñ¡Ôñí¨μà1,′ÎDò1,2éÑù239.5ÖüÆú
        ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_239Cycles5);//????1,??1,??239.5??
        ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 9, ADC_SampleTime_239Cycles5);//????1,??1,??239.5??
        ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 10, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 11, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 12, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 13, ADC_SampleTime_239Cycles5);//????1,??1,??239.5??
        ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 14, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 15, ADC_SampleTime_239Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 16, ADC_SampleTime_239Cycles5);
        /*ÅäÖÃADCê±Öó£¬ÎaPCLK2μÄ6·ÖÆμ£¬¼′12MHz*/
        RCC_ADCCLKConfig(RCC_PCLK2_Div8);
        /*ÅäÖÃADC1μÄí¨μà11Îa55.        5¸ö2éÑùÖüÆú£¬DòáDÎa1 */
        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
        /* Enable ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
        /*¸′λD£×¼¼Ä′æÆ÷ */
        ADC_ResetCalibration(ADC1);
        /*μè′yD£×¼¼Ä′æÆ÷¸′λíê3é */
        while(ADC_GetResetCalibrationStatus(ADC1));
        /* ADCD£×¼ */
        ADC_StartCalibration(ADC1);
        /* μè′yD£×¼íê3é*/
        while(ADC_GetCalibrationStatus(ADC1));
        /* óéóúûóD2éóÃía2¿′¥·¢£¬ËùòÔê1óÃèí¼t′¥·¢ADC×a»» */
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  * @brief  ADC13õê¼»ˉ
  * @param  ÎT
  * @retval ÎT
void ADC1_Init(void)
        ADC1_GPIO_Config();
        ADC1_Mode_Config();
void RCC_Configuration(void)
  SystemInit();//72m
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);        //GPIOA
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);                //AFIO
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);        //GPIOC
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);        //GPIOC
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);                //ADC
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);                                                //12M  ??14M
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);                 //??DMA??
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;//????
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;        //1
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                        //0
        NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;//????
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;        //1
/*********************************************END OF FILE**********************/
